Page 3 of 3 1 2 3
#1064004 - 11/03/19 08:54 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
A tricky aspect was the TV cable for the 200r4 transmission. They're very picky about location to get proper shifting, as it turns out.
I'd bought a retaining nut and wrench for my Makita 90-degree 4" grinder, as my old nut was missing. The tip of the wrench happened to be about the right thickness and hole I needed, so I snipped off the end of it, shaped it to fit the stocker throttle-body, and just had to make sure it got welded in the exactly correct location.
Then, moving on to finish the cold-air induction, I bought another 90-degree elbow off EBay, trimmed up the aluminum tube I had, and came up with the following:
I used the stock throttle-cable bracket, bolted directly to the modified intake at approximately the right angle. The throttle cable and TV cable were "replacement" items offered on Amazon for ~$40 each. The catch was to measure the actual length, cross-reference cable lengths to OEM applications, and then use Amazon prime. Easy-peasy. The $200+ "kits" to adapt the TV cable to the throttle-body, custom throttle-cables and like, IMHO, are nothing short of robbery. It ticked me off, looking at the "offerings."
Moving on to accessories, they're ALL truck accessories, with no exceptions. The truck power steering pump was a little tight, but worked without having to buy any extra "stuff"... it just bolted up. Same for the alternator, water pump, etc. Sorry, I forgot to take a pic of what hose I used for the uppper... basically I went into the back of the local Pep-Boys (who I spend WAY too much money at), and dug around until I found something to work.
After all this, I filled the cooling system. If you don't know, there's a special process for this compared to "old-school," so be sure to look it up.
#1064005 - 11/03/19 09:08 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
At this point, the engine pics basically end. But it's NOT the finish to the story, not by a LONG shot....
For starters, the work to modify the harness to properly fit the car, took me... I'd say 40-50 hours of time. I wanted it CLEAN, so I pulled all the un-necessary wiring. Next, you have to route the wires exactly where they'll be in the final iteration, and either shorten or lengthen them so they're routed properly, without kinks or breaks. Next, you'll have to do continuity checks of every wire up through the sensor plug. Finally, there WILL be wires that are colored wrong, or sensor plugs that are broken or otherwise unusable. It takes a lot of time to make the install clean.
If I was bucks-up, I would have taken the easy way out, and bought a "pre-built" harness. And that would have been a mistake.
WHY?
First of all, for the harness to properly fit wherever you want it, there's no WAY you can route the wires to be the exact length required. And with wire bundles, the lengths have to accommodate bends for proper routing, again making a good fit unlikely.
Next, if you build the harness yourself, you'll be educated on it for troubleshooting any time in the future.
So, while I spent many an evening grumbling about how a big-block Chevy would have been easier, I was stuck with what I had. No turning back now...
#1064006 - 11/03/19 09:18 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
When I got to where I thought I was ready to turn the key for the first time... I was pretty nervous. NOTHING was stock on this, I'd touched every wire in the harness, was running a "mail-order" tune... A LOT of things could go wrong.
A handly little device was given to me, from a guy I gave my old 6.0 pistons and rods (they were disgustingly filthy, but otherwise serviceable). He gave me an ELM327 bluetooth adapter... They can be bought for ~$10 on Amazon, and there's an app at the Google Play store called "Torque Lite," available for FREE. A quickie intro is here:
[video:youtube]https://www.youtube.com/watch?v=GMYZNal9Wpk[/video]
I download the app, and now I can read nearly all my sensors. I'm monitoring the computer through the Torque app, as I turn the key for the first time... and it STARTS.
And then it dies. Won't stay running.
Using the Torque app, I go through the sensors, find I wired the throttle position sensor backwards... I correct the flaw, and now it runs without issue.
So with a $10 adapter (which was given), plus a free app, I was able to diagnose a problem that could have taken me days or WEEKS to find... Not a bad first day of the car being alive... wink
#1064008 - 11/03/19 09:41 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
So now I try running the engine, to at least get it warm, and verify operation of the fans, 165F T-stat, check to make sure everything holds when the engine is warmed up, and so on.
I discover that the fans will NOT come on, no matter what. I check the wiring three separate times, and the conclusion is that there's no signal from the PCM to trigger the fans. The tuner who programmed the PCM said, in effect, "duh, it's from a truck, you didn't say you wanted fans..." I'm like, WTF? I'd spent $150 for him to do the tune, and now I blow another $80 for him to alter the programming to start the fans. Another annoyance, the factory tach doesn't read the engine RPMs, so it's basically dead.
Two weeks go by, and now I have the PCM again.... and the fans STILL won't start... and the tach is still dead.
At this point, I discover that the 2003-2007 PCMs don't interchange with the 1999-2002 units. And the 2003+ PCMs use very different protocols, using a 1 mB processor vs. the 512kB processor in the older units. Newer ones (with a few exceptions) are drive-by-wire, not drive-by-cable as my car is... and there's no hardware inside to drive the idle-air controller... so basically, at this point, I'm hosed, with regard to the PCM. It's just NOT compatible for my configuration, and my "tuner" wasn't sharp enough to know it. pissed
After burning somewhere are $230 for a "tuner," I'm right back at zero. I'm NOT gonna' pay someone else to do this again; I could screw it up that bad for FREE, right?
There HAD to be another way to do this, without paying EFILive or HPTuners ~$300 (plus vehicle "credits") to get a functional PCM that would run my car...
Enter www.tunerpro.net.
It turns out there've been a group of guys working on building open-source software, to allow a person to do exactly that, with GM computers. The software is free to download, the required adapter is $50-60, and you now have the ability to program your own PCM without having to go to some "tuner" who may know nothing... LOTS of information available, both on blogs, videos, etc., on how to use the gear, what to do, etc.
Bottom line: for $200, I have TWO PCMs to play with, and all the gear to program them as I see fit.
I've now got my car running very smooth, still have some work to do on the idle air controller (which I suspect has either a loose connection or I simply wired incorrectly- the original IAC plug was destroyed, I had to use a spare). Other than that, it flat-out hauls xxxx . I've suddenly found the 18" wheels and tires to be a bit inadequate when I stomp on the gas pedal. And the trans is clearly not configured to handle an engine that can REALLY pull past 6000, like the fresh 6.2 can... so I'm a little worried about putting it on a dyno, as the trans may not survive...
So I'm happy to just cruise in it for now. I'm still working on getting good data logging, but at least I'm getting a handle one what's happening with my engine, instead of relying on some knucklehead in a different state to get useful information...
I haven't tallied up the expenses for all of this.... but my guess is around $5k, all-in, including the programming gear... I'll try to figure it out later, and post it. But for now...? Hope this gives everyone something useful.
#1064016 - 11/04/19 01:39 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
You know it's only been a little over a year since you started this project, turned a nice stocker into something special. I've followed the build, the setbacks and got to hand it to you, you are persistent.
One of these days we need to meet at WAWA for coffee.
#1064017 - 11/04/19 01:48 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: mmc427ss]
Breathial Offline
Breathial  Offline
Chester Springs, PA
It would be a pleasure. smile
Still working on idle air... determined wiring is correct, no vacuum leaks... so it's got to be something in software configuration... a parameter, something DUMB that I'm missing... LOL
It never ends.
Send me a PM when you're of a mood to have some java. wink
#1064025 - 11/05/19 01:04 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
So here's the cost breakdown of this build. Parts prices were shopped aggressively online via Ebay, Amazon, Rockauto.com, etc., with the goal of getting reasonably good quality items for the very best price possible. As always, YMMV.
core engine with fresh heads $800.00
LS-7 Roller lifters plus 4 guides (EBay) $108.99
Blue GM Beehive LS springs (EBay) $65.00
Another short-block 6.0 LS $500.00
Valve Stem-seals (beehive style) $18.99
Valve locks $9.52
Machine shop- disassemble, hot-tank, polish crank, check-hone cylinders $380.00
LS3 pistons $120.00
2nd Intake with computer and full harness $100.00
Enginetech bearings (buy) $48.34
Moly piston rings (Enginetech) $86.99
gasket set ( Enginetech) $221.33
Timing Chain set (Enginetech) $54.86
Chinesium exhaust manifolds $175.90
Computer reprogram (Ebay seller AMSRACING) $70.00
Rocker Trunion Kit $90.00
GM LS Push Rods (Set of 16) $34.99
Harmonic Damper bolt (OEM style replacement $8.07
Replacement Knock Sensors (2) $19.34
LS Cylinder head alignment dowels $9.99
Oil flow restrictor $13.99
Truck LS intake manifold bolt kit $16.99
LS Engine Swap M16 1.5 Adapter to 1/8 NPT $9.99
1/8" NPT Steam Port Adapter to Top Radiator Hose LS Swap $14.99
EDGE INDUSTRIAL 1/4" Hose ID to 1/8" Male NPT MNPT 90 Degree Elbow $8.90
MSD 3301 Spark Plug Wire Boot & Terminal (2) $10.91
MSD 3304 Spark Plug Wire Boot & Terminal, (2) $14.19
Waterproof Relay Fuse Block w/7 Relays, 10 Fuses $32.99
OBD2 Dash Port/Wire Pigtail Connector Plug In $11.99
4" Performance Cold Air Intake Kit With Filter $62.98
LS Water Pump & Thermostat Bolt Kit $10.99
Teckpak USA GM 200-4R & 700-R4 Detent Cable 1978-1992 $18.99
Air Flow Sensor Meter MAF 25318411 $29.66
TRUPARTS Oxygen Sensor O2 SG277 (2) $32.59
Motorad 379-160 Thermostat $22.57
IACV IAC Idle Air Control Valve 17113598 $19.99
ACDelco 213-912 GM TPS $32.51
200R4 Chrome Flexible Stainless Transmission Dipstick $51.94
4" Inch 102mm 90 Degree Elbow Silicone Hose $12.24
75-81 CAMARO FACTORY UPPER RAD SUPPORT (Used, Ebay) $45.00
1998-1999 CAMARO LS1 ACCELERATOR CABLE W/O TRACTION CONTROL GM 12565559 $30.68
Dorman Help 41040 Control Cable Retainer $11.01
Edelbrock 8018 1968-Up GM TH350 Transmission Kickdown Stud $6.95
LS1 PCM ECM ECU Mounting Bracket 15995679 $15.00
LS1 Swap Fuel Filter Regulator Fuel Pump & Fitting Kit MSD $199.99
LS1 Conversion 1" Set Back Motor Mount Plates $36.00
Serpentine belt, tensioner and idler kit (Pep Boys) $65.00
Radiator hoses (approximate cost) $40.00
Oil, filter, spark plugs, other misc. crap $80.00
total $3,881.34
There were several other costs not listed- fresh water pump, a serpentine tensioner/pulley assembly, another radiator when my trans cooler line threads came out, and so on... Of coure, there were also a few minor pieces-parts that I didn't use for whatever reason, and $270 worth of exhaust manifolds I can't friggin' get RID of. So an honest number would be... right at $4000 for a fresh engine, with all the tools to tune it myself, and dial it in as my knowledge grows.
Now, the problem is that there are a few special tools to make this work, that you simply can't do the job without....
engine stand (Advance Auto) 84.99
books (Amazon, free shipping) 39.74
Coil spring compresser 19.99
Piston ring compressor (special 6.2 item) 70.00
Engine Hoist (HF, Craigslist) 100.00
Torque-angle wrench (2, since 1st broke) 25.00
Tools, bondo, paint for intake manifold 100.00
OTC 4681 Power Steering Pump/Alternator Remover/Installer Tool 37.26
12V 2A Power Supply Wall Plug Adapter 7.99
OBDLink MX 69.99
ECM pigtails 54.98
2 0411 PCMs 169.42
Cost of Tools 779.36
You can clearly save on some, borrow and beg on others, or (as I did) have to buy them outright. Again, YMMV.
All-in, from soup to nuts... about $5K, no BS.
#1064337 - 12/02/19 02:57 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Just catching up on this, nice when these builds are updated/documented like this, helps others out. Nice job following through and sticking with it, seems like you did it all in pretty good time considering the normal "life" things that are priority, little things like work, family, etc. laugh . Looks good and appears to run really good too, beer .
#1064541 - 12/22/19 10:38 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
Had to replace the gear-box, decided to do the Jeep steering-shaft conversion. As with everything done on this car, it took far longer than anticipated- an honest 8-10 hours... the pitman arm refused to budge, broke several tools, finally resorted to heating the arm to get it off the gearbox. FINALLY got it done, not pretty happy with the tighter steering (and not weaving down the road like a drunk sailor). laugh
Next item of business is the suspension. It sits like this, right now:
At the tops of the wheel-wells, it stands at 27.5" in the front, 28.5" in the rear. The front already has the Belltech 2100 2" drop spindles, and it still sits way too high. I'd like to have the tops of the wheels about even with the fenderwell. So I need to drop the front 1.5" front, 2.5" rear.
So looking at the spring options, including the S10 springs, and the various discussion including this Monte Carlo Drop Springs write-up, I was still not satisfied with the different options available. For starters, I wanted to have 40% higher spring rate (+/-10% as long as it was consistent), while dropping the front ~2" in front and 3" in the rear. I also don't want to have to cut coils, as the spring rates tend to get higher the more you cut, and the results can be unpredictable. So I need something that will give me that much drop at the minimum, and then I can use urethene coil spacers to fine-tune for the exact height I need. This way the spring rate stays constant, and I have a bit of adjustment versus the "cut and hope it wasn't too much" approach. I did that kind of stuff 30 years ago, and it just don't get it, anymore.
Ok, now that we have some goals, it was time to download the entire Moog spring inventory, and start using table filters to slice-and-dice the data.
The rear springs have a factory rating of 142#/inch, so a 40% increase in spring rate (+/-) puts me at 198.8#/inch. The Moog 3229 fits the bill nicely, with a 200#/inch spring rate, and should drop the rear of the 2.95", by my calculations. The Moog 3229 spring comes stock in the 97-06 Jeep Wranglers of various trim levels, and can be found used for as little as $40, if you're on an anorexic budget. I found some new ones on EBay for $55 shipped to my door.
For the front, again looking for a 40% increase in spring rate puts me at 588#/inch versus the factory 422#/inch. The typical S-10 spring options, Moog 5658 or 5660, are both close, but both fail to drop the nose sufficiently. If I cut the springs to get the right height, I now have no idea what the spring rate is, so... that's a non-starter for me. Again digging for several days into the Moog inventory, I came up with spring #80908. This delivers 644#/inch, while dropping the nose ~2.2 inches. The inner diameter is a little tighter than the G-body usually has, but it matches Chevelle springs I.D., so I doubt it will be a problem. They are are available for $84 on EBay, with free shipping. So at this point, I've got stiffer springs that drop the car where it should be (give or take a little adjustment), for a grand total of $139.
IF I need to have the urethene spacers put into fine-tune the height, I can buy them from Amazon, such as the $30 3/4" rear spacers HERE, or the $17 1/2" spacer (equaling 1" of rise in the front) HERE.
The drop shocks are another issue altogether, as well as the inner fenderwell. I'm considering whether I can use a heat-gun on the front inner fenders to gain clearance. A modern version of the old-school BFH to clearance sheet metal...
#1064546 - 12/23/19 02:15 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Car looks great(I agree, drop it a bit) and you clearly have done your homework. 26.0” is a good height, might be pushing how low you want to go but should be fine. I had my SS at 25.0 in front and 26.0 in rear using that same form of measurement(ground to center of wheelwell lip), 25.0 in front is way too low, rubbing/hitting the wheelwell plus shock travel, worse bump steer, etc. Rear at that height has been pretty good, although I might bump my rear up to 26.5 while trying to get the front to somewhere between 26-26.5. I might have to look up that front spring you reference.
#1064548 - 12/23/19 07:51 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Eric it will be a game playing with ride height to get it just where you want it to be.
In the front upping the spring rate is a good thing, not as noticeable ride quality change as in the rear. Also the front with the now LS swap is almost 100 lb lighter.
As far as cutting front springs it's pretty simple as far as rate change. Rate is determined by wire size, wire length and number of coils. If 10 loops in a coil and you cut one off it's a 10% rate increase. If the spring wire is 100 inches and you cut off 10" it's a 10% rate increase. Not exact science but close.
The front spring on a G are tangential on the bottom and square on top. The LCA seat requires using a 5.5" OD, 4.085 ID spring so it sits on the seat properly.
Having no experience with a 2" drop spindles I can only speak about about I'm seen and read. They can be a problem with tire rub in the top of the wheel well if dropped to low. All that depends on how you drive the car.
Also the wheel wells aren't available anymore. Don't think heating the plastic will resolve any rub problem.
First work on getting the front height where you want it then adj the rear to your liking.
As far as the rear springs go a 200 rate will let you know it's back there. 75% of ride quality comes from the rear suspension. And I think the stock SS rear spring was only about a 120 rate.
The Moog 3229 is a very short spring, 11.29" @200. I figure the load each spring sees is about 600 lb. So that spring will compress 3" to a compressed length of 8 1/4". Measuring the distance between the rear springs pocket in the frame to the rear's spring mount is about 14" depending the shock install. The shocks determine full droop. You will end up with a 2 3/4" gap between the top of the spring and the upper frame pocket at full drop. Because the 3229 is a double pigtail spring, you can't cut it, it makes it much more difficult to shim the top or bottom to adjust ride height. And anything you add to the top or bottom of the spring will effect ride height. Those springs will drop out of the seats pretty easily and would require very short shocks or cables to limit droop travel. But also how you drive the back roads will depends on whether you can live with a very short spring that may drop out.
have fun
#1064579 - 12/26/19 05:52 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Eric, weather looks pretty nice for a week or so, got time for a Wawa?
#1064607 - 12/29/19 04:50 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Took the 86 out today for a 20 mile run, possibly the last one for 2019. Made a trip out 113 south, made the mistake of turning right onto Chester Springs Rd and following it out to Pughtown Rd. Now there is a road to see how much you like a 200 rate spring in the back.
#1064987 - 02/02/20 09:01 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: mmc427ss]
Breathial Offline
Breathial  Offline
Chester Springs, PA
So.... after several weeks of messing around with the springs, I finally have the suspension where I want it. The Moog #80908 front springs compared to the factory ones:
Putting these in dropped the car to 25.5" at the front:
Too low, was rubbing on the fender wells, just wasn't working out. So I installed a set of Moog K160058 Coil Spring Insulators on top of the springs:
It brought the final ride height to 26.25". And the rear springs, Moog 3229's, were also installed, which brought down the rear 1.5" (I forgot to subtract the unsprung weight).
Final ride-height as of now: 26.25" front, 27" rear.
I had to replace the front shocks, went with KYB Gas-Adjust units. Overall, very happy. No more rubbing. The ride is firm, but not brutally so, and it seems to be very flat in the corners.
#1065004 - 02/04/20 01:34 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
That's about perfect IMHO
#1065010 - 02/04/20 06:57 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
MUCH BETTER!!!
Eric and I met up at Starbucks on a cold Sat morning a little more than a month ago. He was playing with springs and ride height then, car was way to low in the front. Glad to see it's dialed in now.
Those Moog 3229 rear springs are very short at 11.283". Make sure you don't full droop the rear when running down the highway. Are you still going to do cables to
restrict rear droop?
#1065032 - 02/05/20 07:49 PM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: mmc427ss]
Breathial Offline
Breathial  Offline
Chester Springs, PA
I haven't decided what to do about that, yet. Had the creepin' crud for the last two weeks, so I haven't really thought much about this.
#1065055 - 02/07/20 01:53 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Breathial Offline
Breathial  Offline
Chester Springs, PA
A family situation has come up, where I need to sell the Monte Carlo. sick
Will post some pics in an ad on Craigslist for $12k, but would sell to a forum member for $10k straight up. (I'm into it for ~$13k at this point.)
Runs fine (actually, traction is my biggest issue right now), just... have to shift funds around.
Anybody interested, please PM me.
#1065059 - 02/07/20 05:00 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
Sorry to hear that. Family first.
#1065070 - 02/08/20 01:03 AM Re: Breathials' '87 MCSS Build- Cheap Street Driver [Re: Breathial]
T5montecarlo Offline
Lederach, PA
Me, too, Eric. I hope it is not too serious.
Marc
Page 3 of 3 1 2 3
500/thumbs/engine6.jpg
by meddac
622/thumbs/rr4.jpg
by cj84ss
500/thumbs/0501082051a.jpg
by QuickSSilver
558/thumbs/Z65_Paul-15HQ1024x768.jpg
500/thumbs/l_b8a8e1a9217b416d9d69be56e19b324f_1_.jpg
by Stunt Man
