#1063659 - 09/29/19 02:07 AM 9 inch rearend swap question
doublemonte Offline
doublemonte  Offline
Ottawa, Ontario CANADA
I need to replace the rearend on my 84 and will be going with a GM 9 inch. I have fairly new brakes so was curious whether I can bolt the existing brakes, rotors, etc to this set up: https://www.quickperformance.com/QP-GM-1978-1987-G-Body-9-Inch-Housing-Axle-Package_p_63.html
Or do I need the complete reared package: https://www.quickperformance.com/9-Ford-Complete-Rearend-GM-G-Body-78-87_p_20384.html
Thanks!!!!
'84 SC - Hot Chocolate Metallic exterior, Dark Briar Brown interior, orig. 305ci, headers, custom dual exhaust
'02 SS Pacecar - competition yellow (TOTALLED)
http://www.cardomain.com/id/doublemonte
#1063661 - 09/29/19 01:22 PM Re: 9 inch rearend swap question [Re: doublemonte]
It's a Ford 9" , the rotors/calipers I have on mine are from a Ford Explorer. The axles are drilled 4.75 on 5 to run GM wheels.
I bought the whole kit unless you already have the gears and center carrier. GM brakes won't fit on a Ford axle.
#1063669 - 09/30/19 01:12 AM Re: 9 inch rearend swap question [Re: doublemonte]
MC96 Offline
MC96  Offline
St. Johns MI
Ive built 5 this year, if you can weld you can put any brakes you want on them
Did some with metric calipers and some with wilwood calipers
86 SS
In progress
#1063719 - 10/06/19 10:38 PM Re: 9 inch rearend swap question [Re: doublemonte]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I would suggest you buy the complete package. No parts to hunt around for. Just need to assemble it. There are videos online that show how to assemble a Quick Performance 9 inch. Good luck.
#1063756 - 10/11/19 06:28 PM Re: 9 inch rearend swap question [Re: Fred SS]
Yep, the rear comes in a bunch of boxes so it can ship UPS unassembled.
500/thumbs/Image8.jpg
by hotrodmc
500/thumbs/jace_car.jpg
by clifford clavin
671/thumbs/ebay_014.jpg
by woodss
550/thumbs/small118.JPG
by stonecoldtim
523/thumbs/DSC_0617.jpg
