#1063663 - 09/29/19 07:38 PM Mixture Control Solenoid
Sparky Offline
Sparky  Offline
Gilbert, AZ
Getting ready to take my car in for some work. Have not ran it for a while due to bad cam. Tried to get it started but was unable. Noticed my MCC was not making the usual ticking sound when I turned on the ignition. Plugged the MCC harness into another junk carb I had laying around, an it made the clicking sound. Do these things just go bad all of a sudden, get stuck? Any thing I should try before having it replaced? Carb as rebuilt around 10 years ago.
Second owner of an 88ls with 62k miles, everything original (except radio and rims, but I have those) including window sticker from dealership
#1063705 - 10/04/19 04:43 PM Re: Mixture Control Solenoid [Re: Sparky]
Rocco_Q Offline
Rocco_Q  Offline
Rhode Island
check the resistance between the terminals on the solenoid should read 25 ohms +/- 5 ohms
#1063706 - 10/04/19 04:51 PM Re: Mixture Control Solenoid [Re: Sparky]
Bitflipper Offline
Bitflipper  Offline
Las Vegas, NV
I have replaced my MCS 2-3 times with the same symptom. Last time I did it, I forked out the cash for a genuine AC Delco one - hopefully it will last longer. The Mixture Control Solenoids and the Ignition Modules seem to be the Achilles Heel in our cars.
#1063709 - 10/05/19 01:07 PM Re: Mixture Control Solenoid [Re: Sparky]
T5montecarlo Offline
Lederach, PA
After mine had not run for some years, the MCC was also not clicking. I stuck a narrow punch into the hole in the top of the carburetor, where the MCC travel is measured, and pressed down on the plunger. Now the MCC clicks. The plunger was just stuck inside the MCC.
Try this trick first before opening the carburetor, yours might be OK.
#1063712 - 10/05/19 07:09 PM Re: Mixture Control Solenoid [Re: Sparky]
It may just be sticky after sitting around for a long time. Carb parts can gum up from old gas sitting in the carb for extended periods. You have to be careful not to strip the M/C solenoid adjusting screw as it can ruin the carb and repair kits are no longer available.
500/thumbs/81_MC7.jpg
by MikePEI
557/thumbs/Daytona1600x1200.jpg
500/thumbs/DSC01631.JPG
by sideways
500/thumbs/DSC02761.jpg
by Regal80.5
500/thumbs/The_Kids14.jpg
