#1063696 - 10/02/19 10:03 PM rocker adjustment
Krazyjay23 Offline
Krazyjay23  Offline
Brooklyn NY
hey guys what is a good way to adjust my rockers. i have the original 305 when i did it on my cutlass years back i just ran it without my covers and snugged them until it quietened up but with this car i have to remove my ac compressor and bracket to remove my cover so i didnt want to run it like that if i didnt have to i replaced my valve seals on the drivers side next weekend im going to do the other side. i spun the motor by hand and adjusted them till there was no play for now but now it has a slight misfire so im assuming they are too tight . on the good side I didn't get cloud of smoke when i started it lol just a little puff . ans fyi its a pain doing it with rope wish my compressor worked lol .thanks in advance
#1063698 - 10/03/19 02:02 AM Re: rocker adjustment [Re: Krazyjay23]
On a old school SBC with somewhat stock cam the simplest way to do it is this method. In most of the old Motors or Chiltons Manuals that was the method prescibed. Several other methods but that should work for you.
Not sure how much preload you should put on the lifter after zero lash has been set, been a long time since playing with a 305. But would think factory was 3/4 to 1 turn. Most of the aftermarket parts would be closer to 1/4 preload.
https://www.jalopyjournal.com/forum/threads/tech-a-simple-way-to-adjust-valves.168345/
#1063699 - 10/03/19 02:38 AM Re: rocker adjustment [Re: Krazyjay23]
84ss355*4spd Offline
Edmonton,AB,Canada
I like the opposites of the firing order method .works the best for me .ensures your on the "heel" of the cam .
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1063716 - 10/06/19 11:27 AM Re: rocker adjustment [Re: Krazyjay23]
Krazyjay23 Offline
Krazyjay23  Offline
Brooklyn NY
thanks guys i actually went back out 20 min after posting this to readjust lol i loosened them till they started tapping then slowly adjusted till it stoped then i just did half turn im going to do the other side wednesday then ill adjust them all the right way lol
#1063721 - 10/07/19 12:57 AM Re: rocker adjustment [Re: Krazyjay23]
a half turn is fine, no need to readjust that side!!
#1063811 - 10/18/19 09:36 PM Re: rocker adjustment [Re: Krazyjay23]
Krazyjay23 Offline
Krazyjay23  Offline
Brooklyn NY
thank you
500/thumbs/mc71.jpg
by McCall72
500/thumbs/0501082051a.jpg
by QuickSSilver
500/thumbs/Tail_of_the_Dragon_4_.JPG
by NC87AERO
500/thumbs/DSC_0023.JPG
by wanadrv
903/thumbs/slab2.jpg
by Heavy Chevy
