#1041605 - 07/18/16 03:15 PM Ramcharger / Intrepid fan pigtail
Lobito Offline
Lobito  Offline
North Bergen, NJ
Hello,
Does anyone know the part number for the ramcharger / intrepid fan pigtail? Can't seem to find a part number or where I could buy one from.
#1041609 - 07/18/16 04:50 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
I've got them....did u message me earlier? I build harness kits for them so I keep an inventory of the terminals/connectors and such.
gbodyparts1234@yahoo.com
HARNESSWORX
#1041615 - 07/18/16 06:05 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
Lobito Offline
Lobito  Offline
North Bergen, NJ
yes, sent you another text.
#1041671 - 07/19/16 11:26 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
I bought my Z28 fan pigtail from Pic N Pull. Snip, snip.
Should be a bunch of Intrepids and similar at your local wreckers.
#1041704 - 07/20/16 10:40 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Just to give you guys an idea on my ramcharger fan harness kits, this is a recent reply by a 3rd gen fbody owner after using one of my fan assemblies w/control harness using a BMW 180/195 dual temp switch:
Originally Posted by 89gta383
No ac on the car, when did you ship?
I shipped it early this morning-tracking # is 776697377182
If you don't have AC (I added the AC override thinking u were using it being as it gets HOT down there lol) but you can use a trigger too if need be for a manual override before the engine gets to temp....you probably won't need it often but it's there just in case.
i put the fans in and the car stays around 183-187 when driving when it is 95 degrees outside. Used to run around 207-215, so that is an improvement. Thanks for your help. After letting the car heat soak in the parking lot after driving for awhile, the fans pull the temp down from 205 to 185 in about 5 seconds. Old fans never could bring the temp down once it got up there. I hooked the red battery cable to the battery, ground to fan #1 ground and switched 12v to other hot in the same fan #1 plug. I will use the a/c wire as a manual fan switch. You put alot of extra wire on that wiring loom, so I will cut and solder what i don't need. The fan shroud needs a little bit of clearancing to get it to fit in front of the steering gear rack and the edges of the fan shroud need to be sanded so they both fit inside the radiator flush, other than that, this is the slimmest fan/shroud combo I could find that works. thanks again
HARNESSWORX
#1041749 - 07/22/16 04:20 PM Re: Ramcharger / Intrepid fan pigtail [Re: upflying]
Lobito Offline
Lobito  Offline
North Bergen, NJ
Wish there was a Pic N Pull in this area. lol
#1041753 - 07/22/16 09:15 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
This is what I'm building now with regards to these fans. I'm stocked up on clean and tested OEM fan assemblies vs new China sourced fans.
HARNESSWORX
#1043305 - 09/08/16 02:00 PM Re: Ramcharger / Intrepid fan pigtail [Re: gmachinz]
William J Offline
William J  Offline
Perry MI
possibly interested in a kit.
What is included and price?
#1063442 - 09/04/19 06:46 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
Hello, are you still selling the Harness kits for the Intrepid fans?
87 Aerocoupe,Rapp Racing 383.Leather interior. headers, flowmasters, k&n filter,MSD Ing, 17x8 iroc w/ 245/45/17 s.s.b.c.calipers & cross drilled rotors. Kenwood sound system..
#1063453 - 09/05/19 02:01 PM Re: Ramcharger / Intrepid fan pigtail [Re: Lobito]
You can try to reach Jabin on his facebook page. He hasn't spent much time on this forum lately.
https://www.facebook.com/Harness-Worx-1287413924675503/
#1063454 - 09/05/19 02:14 PM Re: Ramcharger / Intrepid fan pigtail [Re: mmc427ss]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
500/thumbs/New.jpg
by Billys88SS
500/thumbs/img016.jpg
by paul8584
1009/thumbs/parts_car_driver_side.jpg
by DSMonteSS
527/thumbs/87SS_glovebox_bracket.jpg
1166/thumbs/106662_180f1f8ea4_low_res.jpg
by lonk
