#1063396 - 08/31/19 06:49 PM OD trouble
Markz83 Offline
Markz83  Offline
Buffalo, NY
My transmission doesn’t want to shift into overdrive at highway speeds 55+ mph. It will when driving around town/ low speeds. It’s the stock 200R4 with 91,000 miles on it and the transmission fluid is topped up and in good shape. Any ideas?
#1063404 - 09/01/19 12:57 AM Re: OD trouble [Re: Markz83]
Have you checked to see what the TPS voltage is during highway driving??
#1063407 - 09/01/19 05:03 AM Re: OD trouble [Re: 86ttop]
Markz83 Offline
Markz83  Offline
Buffalo, NY
I have not. Didn’t even think to lol.
#1063410 - 09/02/19 12:50 AM Re: OD trouble [Re: Markz83]
High TPS voltage keeps the torque converter from engaging lockup at least. How is the engine temp at highway speeds??
#1063411 - 09/02/19 01:04 AM Re: OD trouble [Re: 86ttop]
Markz83 Offline
Markz83  Offline
Buffalo, NY
Engine temp is normal. I’ll test the tps when I the time, maybe Thursday
#1063418 - 09/03/19 12:35 AM Re: OD trouble [Re: Markz83]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
Just to clarify, you are talking about overdrive (fourth gear) and not torque converter lock up? Seems weird that your trans will go into fourth at low speeds and not at highway speeds. It normally works the other way round.
If yes to it being a fourth gear issue, as well as checking the TPS as Leo suggested, also ensure that the TV cable is set correctly as that can also affect shift points. An out of adjustment TV cable can cause all sorts of shift issues as well as potentially damaging the trans in extreme circumstances.
1986 Monte Carlo SS
#1063465 - 09/06/19 07:18 AM Re: OD trouble [Re: ChasUno]
Markz83 Offline
Markz83  Offline
Buffalo, NY
Thanks, I’ll look into all that next week. Yes it doesn’t shift into OD at highway speeds but will when just cruising around town.
500/thumbs/BrakeCablesR.jpg
by John B
500/thumbs/ls_convet1.jpg
by tonys57chevy
500/thumbs/ss_plate.JPG
by JP86SS
500/thumbs/monte_carlo_0015.jpg
by 85lolo
500/thumbs/1984MonteCarlo_Medium_.jpg
by 1NJIMID8TOR
