#1063328 - 08/27/19 03:09 AM
Re: Engine Swap
[Re: NolesAlumni]
Depending on the labor rate at the chosen shop, guessing at $100 p/h and a flat rate of 16 hours, adds up to $1600.00 if there are no other problems. Good luck!
#1063335 - 08/27/19 01:28 PM
Re: Engine Swap
[Re: 86ttop]
upflying
Add another $2000-$2500 for the "mild 350 crate engine" to the labor charge.
#1063379 - 08/30/19 01:15 AM
Re: Engine Swap
[Re: NolesAlumni]
There must be some car club members you can talk to, have you gone to any cruise spots??
#1063380 - 08/30/19 01:46 AM
Re: Engine Swap
[Re: NolesAlumni]
BadSS
86 has the right idea. I'd also suggest going to the local race track - doesn't have to be quarter mile either. Check out the faster running cars and drop by the pit area and complement them on how well the car is running then ask who does their machining and engine work. Most don't mind telling you and I'll bet you'll find most all the faster cars are using the same place. Good luck with the swap!
#1063383 - 08/30/19 01:57 PM
Re: Engine Swap
[Re: NolesAlumni]
upflying
Make sure you keep the 305 to keep the "numbers matching" drivetrain intact. Could be important when you sell the car.
#1067498 - 08/03/20 12:39 AM
Re: Engine Swap
[Re: NolesAlumni]
Your local Chevy dealer should have access to the goodwrench 350 engine. Check with local machine shops too!!
#1067504 - 08/03/20 01:13 PM
Re: Engine Swap
[Re: NolesAlumni]
Travis Jones
I'm going to be the guy that says in 2020 putting money into a Gen I small block is a waste of money.
Get a 5.3 LS, you can find running motors for $200-$300, the other components will cost more, but you could complete the swap for $3000-$4000
#1067506 - 08/03/20 03:26 PM
Re: Engine Swap
[Re: Travis Jones]
1 Slow SS
Get a 5.3 LS, you can find running motors for $200-$300, the other components will cost more, but you could complete the swap for $3000-$4000 X2, Everyday I regret not buying a LS7 for the Camaro back in 2018, I just cold fork up a complete swap at the time.
#1067507 - 08/03/20 04:54 PM
Re: Engine Swap
[Re: Travis Jones]
Buick Runner
Get a 5.3 LS, you can find running motors for $200-$300, the other components will cost more, but you could complete the swap for $3000-$4000 I am going to be that guy that says in 2020, putting money into a poorly and cheaply built, outdated 1980's grannymobile is a waste of money. Better to sell it off and use the money towards a used factory LS powered car which will be completely better in every regard. Also I am going to be that guy that says in 2020, LS engines are so passe, LT (Gen 5) engines are the new hotness. In reality, $200-300 running LS engines are rare, the price is more likely going to be triple that or more for even a 5.3. In my area you can't even get a non running 5.3 core to rebuild for less than $800. Gotta pay more than the smelters. 50k is just a drop in the bucket for a 305, pretty silly to swap a good motor with that amount of miles out. Just change the fluids and run some Marvel Mystery Oil in the crankcase to clean up any sticky parts. The biggest concern is if there is any Jerry rigging in the car. Especially in a emission hating Southern state, there is very likey going to be a lot of Jerry rigging to sort out. 059 Vortec heads will bump that 305 into the 300 hp range. A head swap is a lot easier than a complete engine swap, especially engines not designed for the car.
#1067508 - 08/03/20 05:31 PM
Re: Engine Swap
[Re: Buick Runner]
Travis Jones
Get a 5.3 LS, you can find running motors for $200-$300, the other components will cost more, but you could complete the swap for $3000-$4000 I am going to be that guy that says in 2020, putting money into a poorly and cheaply built, outdated 1980's grannymobile is a waste of money. Better to sell it off and use the money towards a used factory LS powered car which will be completely better in every regard. Also I am going to be that guy that says in 2020, LS engines are so passe, LT (Gen 5) engines are the new hotness. In reality, $200-300 running LS engines are rare, the price is more likely going to be triple that or more for even a 5.3. In my area you can't even get a non running 5.3 core to rebuild for less than $800. Gotta pay more than the smelters. 50k is just a drop in the bucket for a 305, pretty silly to swap a good motor with that amount of miles out. Just change the fluids and run some Marvel Mystery Oil in the crankcase to clean up any sticky parts. The biggest concern is if there is any Jerry rigging in the car. Especially in a emission hating Southern state, there is very likey going to be a lot of Jerry rigging to sort out. 059 Vortec heads will bump that 305 into the 300 hp range. A head swap is a lot easier than a complete engine swap, especially engines not designed for the car. I can get 5.3's all day up here in Michigan for $219+tax, the local you pull is full of race engines. LT gen5 engines can't be easily swapped on a budget. If the 305 is running my advice is to drive it for the time being and save for an LS swap. The problem with Modern LS powered vehicle is their weight. 500-700lbs heavier, weight spoils everything.
#1067511 - 08/03/20 05:51 PM
Re: Engine Swap
[Re: NolesAlumni]
Buick Runner
Prices do seem to vary by region, most of my local junkyards want $800 or more frim for a bare high mileage LS engine, less than that they rather smelt it. Supply and demand I suppose. One article I found on LS engine prices says that in some areas, used high mieage 5.3s go as high as $1,600 from yards.
#1067512 - 08/03/20 06:10 PM
Re: Engine Swap
[Re: Buick Runner]
Travis Jones
Prices do seem to vary by region, most of my local junkyards want $800 or more frim for a bare high mileage LS engine, less than that they rather smelt it. Supply and demand I suppose. One article I found on LS engine prices says that in some areas, used high mieage 5.3s go as high as $1,600 from yards. Those are crazy prices. Maybe i should start pulling engines and selling them in those areas. Summit has a $3499 450HP 5.3 crate motor. Considering GM wants $2399 for their base 350 that makes ~250hp. There's nothing else that even comes close in $ to power figure.
#1067513 - 08/03/20 06:50 PM
Re: Engine Swap
[Re: Travis Jones]
Buick Runner
Prices do seem to vary by region, most of my local junkyards want $800 or more frim for a bare high mileage LS engine, less than that they rather smelt it. Supply and demand I suppose. One article I found on LS engine prices says that in some areas, used high mieage 5.3s go as high as $1,600 from yards. Those are crazy prices. Maybe i should start pulling engines and selling them in those areas. Summit has a $3499 450HP 5.3 crate motor. Considering GM wants $2399 for their base 350 that makes ~250hp. There's nothing else that even comes close in $ to power figure. A crate 350 has the benefit of bolting right in keeping original factory parts and systems, an LS crate will require additional parts to adapt it in and some custom fab work, mostly exhaust which ups the final cost. The cheapest LS swap would be carb, but then you downgrade from the factory computer Qjet on the SBC to a aftermarket gas dumper. Keeping the LS EFI makes more sense but adds to the complexity and cost. They do sell some direct plug and play LS crates like the Erods, but those are not cheap. In the end, high HP isn't cheap. We are sidetracking the OP's thread. Considering the OP wants to hire out for a swap, he is kind of at the mercey of whatever the installer wants to do. Likely the installer will want to rip everying out and install whatever his jobber is pushing him to install. With a SBC, he will likely want to ripout the CCC and instally a Holley carb or aftermarket EFI of some kind as he will likely not have the training, knowledge, skills, tools, and other equipment for working on CCC cars, nor would he even want to have any of it.
#1067517 - 08/03/20 09:49 PM
Re: Engine Swap
[Re: NolesAlumni]
Buick Runner
Do you plan to keep it CCC Qjet or switch to non CCC carb or EFI? Most modern mechcanics are clueless about carbs and helpless with anything that predates OBD2.
#1067521 - 08/04/20 01:11 AM
Re: Engine Swap
[Re: NolesAlumni]
I have a carb guy that is awesome, www.customrebuiltcarbs.com I use and recommend him, turnaround is usually about 7-10 days!!
#1067522 - 08/04/20 02:19 AM
Re: Engine Swap
[Re: NolesAlumni]
Buick Runner
Whatever is the most cost effective/reliable. I’d prefer carb since that’s what’s already in place, but I’m not close minded about it. The stock fuel system is the CCC Qjet which is a computer controlled carburetor setup. Even a rebuilt CCC Qjet will need final fine tuning on the engine which requires special tools and equipment that are discontinued. Most important is a analog dwell meter which are no longer made but can still easily found used. You would also need idle jet adjusting tool and a TPS adjusting tool. A non computer carburetor setup requires less special tools, but requires more parts such as non CCC distributor swap and some sort of lockup control. This conversion will reduce power and gas mileage besides easily snowballing. This is what a professional mechcanic will likely push on you. It still will require final fine tuning but less specialized tools will be needed. EFI conversion isn't cheap or easy. You could go with either GM EFI systems such as TBI or TPI or go aftermarket EFI. This route has the most options and expense. This conversion can snowball even more than a non CCC carb conversion as it requires the most parts. There are no real easy choices.
#1067525 - 08/04/20 01:27 PM
Re: Engine Swap
[Re: NolesAlumni]
Hunter79764
If you want to stay carb, I think the general consensus would be to keep the CCC. Putting a carb on an LS is generally more money and more work than leaving it EFI. If you are going to go EFI, it will be more money and work to put it on an SBC than it would to swap to LS. I hear you on not wanting a used engine, but just keep in mind that the newer stuff can have 150K, get thrown into a swap with maybe a new water pump and spark plugs, maybe valvesprings, as "cheap insurance" and go many many miles without issue. Most folks are looking at 300k before even thinking about bearings or rings being worn.
Having a shop do the work opens a big can of worms. It really depends on who they are, what they are used to, and what they charge. Generally I'd say you can do the swap for $2000+ engine/transmission and that should give you a nice setup. Doing everything yourself can get the cost including engine to $2000, but that's tricky. $2000 plus a $1500 takeout engine/trans puts you at about the price of a crate motor SBC, then you have labor. Overall tough call but enjoy it either way.
#1067530 - 08/05/20 04:09 AM
Re: Engine Swap
[Re: NolesAlumni]
Buick Runner
Thanks for the info. I’d love to do the work myself, but I don’t have the time, tools, or space to do it.
I do find it fascinating that in 2020, it still costs thousands of dollars to get a small carborated pushrod motor installed in a 34 year old car.
I’ll keep my eyes out for anything, I figured by now their be a default 350 sbc swap everyone does on these cars. For now it’ll just sit and continue to collect dust That is part of the reason, few mechanics are able yet alone willing to work on old carbed engines in 30+ year old cars. They manly only want to work on current stuff as they often lack the tools and equipment to work on old stuff. There is nothing wrong with driving a 305 poweredcar around. Don't believe all the 305 bashing on the net, as the net likes to blindly bash everything. Most of its based on the low CR early LG4s, your SS has the high CR L69. Headers with a O2 sensor bung, Bitflipper's ZZ4 chip, and a heated O2 sensor will wake that 305 up, plus they can be transferred to a 350 later on. Even just building a dual snorkel aircleaner will add 10 hp. 305s can easily last to 300k with good care. The biggest issues with these cars are not the powertrains, its the weak floppy frames and poor front suspensions.
by clyde
by Ted88SS
by FuzzyDnkn
by ls1_monte
by montess406
