#1063115 - 08/12/19 10:57 AM Rear axle oil
Headstrong Offline
Headstrong  Offline
boston, ma.
Hello.
My SS has been sitting way to long,
it has 80k on it,
I plan on servicing the rear end
What grade gear end "gear oil"
should I be using.
It is a G80 so it has a posi.
Do I use a gear oil that has listed having a posi additive , or should I still use the stand alone posi additive and if so, what one.
Also, syn or from the ground?
will I need to replace the axle seals before running syn gear oil if that is a better option.
Have a great day
Mark
#1063122 - 08/12/19 01:29 PM Re: Rear axle oil [Re: Headstrong]
T5montecarlo Offline
Lederach, PA
In my experience, using just the oil that claims to be for limited slip makes the rear chatter. Adding the GM additive made the chatter stop. I bought the additive from the Chevrolet dealer.
#1063140 - 08/13/19 01:14 AM Re: Rear axle oil [Re: Headstrong]
86ttop Online grandpa
86ttop  Online Grandpa
What T5montecarlo said, put the additive in first and use a gasket on the cover, not silicone!
#1063179 - 08/14/19 02:24 AM Re: Rear axle oil [Re: Headstrong]
I like to pre mix the additive into the oil before putting it in the rear.
#1063183 - 08/15/19 01:02 AM Re: Rear axle oil [Re: Headstrong]
suit yourself!
#1063307 - 08/25/19 01:10 AM Re: Rear axle oil [Re: Headstrong]
Kawaiikeno Offline
Kawaiikeno  Offline
Vassar,Mi
GM additive
Daughter's 1984 Monte Carlo SS
Car Craft Magazine Humble Pie engine build
200-4r trans.
8.5" 4:10 Grand National rearend
500/thumbs/indo_black_006.jpg
by Hailhorror77
500/thumbs/Tranny-2.jpg
by MAP
500/thumbs/MVC-015S.JPG
by hot rust
500/thumbs/10_08_09_1987_Monte_Carlo_SS_017.jpg
by BlueStreak In Spring
500/thumbs/mcall.jpg
by donzss
