#1063147 - 08/13/19 02:44 AM
Re: Digi-Tails in an 86 SS
[Re: killianz79]
Fred SS
Glassboro, NJ
I have been wanting to replace my taillight lenses for some time now. So I bought a spare set and messed around with that one. I separated the lens from the housing by using a razor and cutting the sealant all around then carefully using a thin flat blade screwdriver and prying the housing loose a little at a time. Take your time. The sealant is flexible. After you get the two parts separated, use needle nose pliers or tweezers to pull off the remaining sealant. Not sure what to use when re-assembling them though.
#1063155 - 08/13/19 01:26 PM
[Re: killianz79]
upflying
by SSLANE
by LXXXIV SS
by Jay84
by myfirstmontess
by 83/84/86*2/87ss
