#1063136 - 08/13/19 12:13 AM Digi-Tails in an 86 SS
killianz79 Offline
killianz79  Offline
Detroit, MI
Anyone have any suggestions on how to separate the tail light housing in our SS's? I looked for a thread on here but didn't see one.
LS2, 4L70E, 8.5 GN rear end,
1986 Monte Carlo SS
http://www.cardomain.com/ride/3061483/1986-chevrolet-monte-carlo/page-1
#1063147 - 08/13/19 02:44 AM Re: Digi-Tails in an 86 SS [Re: killianz79]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I have been wanting to replace my taillight lenses for some time now. So I bought a spare set and messed around with that one. I separated the lens from the housing by using a razor and cutting the sealant all around then carefully using a thin flat blade screwdriver and prying the housing loose a little at a time. Take your time. The sealant is flexible. After you get the two parts separated, use needle nose pliers or tweezers to pull off the remaining sealant. Not sure what to use when re-assembling them though.
#1063155 - 08/13/19 01:26 PM Re: Digi-Tails in an 86 SS [Re: killianz79]
This kit requires separation of the lens from the housing?
https://digi-tails.com/1986-ss-monte-carlo-sequential-led-tail-light-kit
#1063192 - 08/17/19 03:44 AM Re: Digi-Tails in an 86 SS [Re: killianz79]
ss4ever Offline
ss4ever  Offline
Shelbina, Missouri
I talked to Mikes Montes about it, he sends to kits to the place that builds his new lenses and they install them during the building process, seems like best case scenario to me.
#1063400 - 08/31/19 09:16 PM Re: Digi-Tails in an 86 SS [Re: killianz79]
84ss355*4spd Offline
Edmonton,AB,Canada
Would be a nice mod
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
500/thumbs/DSC_0014.JPG
by wanadrv
500/thumbs/Roof_Damage.JPG
by Duramonte
500/thumbs/Photo71.jpg
by Chief's Babe
500/thumbs/By_the_pond.jpg
by Billys88SS
500/thumbs/IMG00280_1.jpg
by BadHabitSS
