#1062253 - 06/08/19 08:45 PM Fuel Line to carburetor
ROAD RAGE RENE Offline
Union City,NJ
Hey guys have problem need to know if someone has a part # or the size of fitting i need to run a line from here to the carburetor. what it had before rubber got brittle and the set up doesnt look to reliable it was a piece of rubber hose clamped around a braided fuel line with 2 clamps. First picture is the braided line the rubber end is whats connected to the second picture thats the line https://ibb.co/k4X37d6
https://ibb.co/2nLvrh3
#1062277 - 06/09/19 09:10 AM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
Please explain "from here to carburetor"
First picture is the hose with the AN fittings.
Second picture I don't know what your showing.
#1062330 - 06/11/19 10:16 PM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
Union City,NJ
Hey Richie thanks for the reply the breaded fuel rines to the carburetor the rubber clamped hose at the end was around the fuel oine thatvrun under the car https://ibb.co/jgQPnbr i wanna see what set up i can run to replace this since it was hitting the alternator
#1062365 - 06/12/19 10:33 PM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
88ss408 Offline
88ss408  Offline
miramichi, NB
Looks like you need the proper fitting to go on your fuel pump and connect to your pump. Most aftermarket pump has 1\4 inch npt.
Stock pumps have flared fittings ( like brake lines)
1988 monte carlo ss 408 sbc
1984 monte carlo cs 400 sbc
#1062377 - 06/13/19 09:24 AM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
Do you have a mechanical fuel pump mounted below the alternator or are you using an electric pump ?
#1062405 - 06/15/19 02:48 AM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
Union City,NJ
He Richie went to a local speedshop and got the problem resolved got a compression fitting and two 90° angle fittings and some braided fuel line for $75 smh https://ibb.co/gvy8Lwx. https://ibb.co/mcYXFNj
#1062408 - 06/15/19 11:10 AM Re: Fuel Line to carburetor [Re: ROAD RAGE RENE]
Glad you fixed your problem.
859/thumbs/star1.jpg
by Rocco373
737/thumbs/small_DSC00335.jpg
by McNamee
1188/thumbs/4_-_Copy.jpg
by mclellan83
500/thumbs/87mcss-2.jpg
by 87z16
500/thumbs/IMAG0117.jpg
by 86 monte carlo ss
