#1062154 - 06/04/19 01:25 AM Time For New Mufflers
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
I have been looking at mufflers the last few weeks and narrowed it down to Borla ProXS (40351) or Dynomax Ultra-Flo Welded(17226). The Borla mufflers are oval shaped but the Dynomax are more rectangular when looking at them from the In/Out pipes. I am leaning towards the Dynomax mufflers but I am concerned that I may be too close to the ground since they are more rectangular shaped. My car is lowered by 2" all around and my existing mufflers are oval shaped like the Borla's. Anyone using the Dynomax Ultra-Flo mufflers with their car lowered 2"? The Dynomax mufflers are 4.5" high while the Borla are 4" which is another concern for me.
Thanks for any help you can give me.
86 Monte Carlo SS W/T-Tops 'Original Owner'
355 CI, Hooker Super Comp Headers, True Dual Exhaust, Comp Cam Roller Cam (XR276HR-10), Q-Jet Carb 795CFM. 200-4R Transmission. 2" Lowered Suspension.
#1062331 - 06/11/19 11:17 PM Re: Time For New Mufflers [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Anyone using either the Borla ProXS or the Dynomax Ultra-Flo Welded muffler? Just curious as to how they sound. I plan on going with 2.25" pipe since most of the existing exhaust is 2.25".
#1062338 - 06/12/19 02:24 AM Re: Time For New Mufflers [Re: Cos86SS]
AkronAero Offline
AkronAero  Offline
Hey, Cos - I have a 383 with a big cam. I am running Hooker Comp 1-5/8" headers and custom bent 3" 304 SS true dual pipes with Borla XR-1 Multicore mufflers (40575) on each side with a 4.25" depth. Yes, they are loud. If I did it again, I might some of the newer Borla offerings/combinations. I am about 2" lower also with little problems (we were careful on the contours when bending). Exhaust comes out the back with pipes very close to the bumper, yet they did scuff the asphalt a few times. No problems under the car except I found one scratch/dent on one muffler where we ran over something.
#1062342 - 06/12/19 06:41 AM Re: Time For New Mufflers [Re: Cos86SS]
Lugan87 Offline
Lugan87  Offline
Seattle WA
Cos, like Akron, I also have Borla mufflers, but in 2.5in diameter, dual, no cats behind a decently powerful 350 and 1 5/8 headers. I'm looking to add cats to my exhaust, to cut down on smell and in the mean time, see if they'll also cut down on sound volume. The exhaust is not unreasonably loud, but it is louder than I'd like. No drone at any engine speed, and with the windows up I can keep a conversation going without issue, including with my toddler. With the windows down driving around town I have to raise my voice a bit to be heard.
On my first Monte SS, approx 20 years ago, with the stock 305, I added Edelbrock TES headers, stock routing to the single cat, Dynomax Super turbo mufflers to
2.5 in Flowmaster tail pipes to the rear bumper. I liked the sound a lot. Much quieter than the borla setup: understated, but a touch throaty.
Best of luck and let us know how it turns out.
#1062350 - 06/12/19 12:19 PM Re: Time For New Mufflers [Re: AkronAero]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Akron, Thanks for the info. It looks like Borla or Dynomax mufflers will work out based on your setup. My exhaust pipes are Al. and also come out the back. The only time I hit the asphalt is going up my driveway (inclined) with my kids in the back seat. If I come in at an angle I can make it without touching. Still trying to decide which ones to go with. I'll post once I have them installed.
#1062351 - 06/12/19 01:05 PM Re: Time For New Mufflers [Re: Lugan87]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Lugan, Welcome to the Forum. Which Borla Mufflers do you have? I too considered the Flowmaster mufflers but kept reading that they are restrictive. The Borla and Dynomax are straight through pipes which are less restrictive. Thanks for the input and will post once I decide which way to go.
#1062353 - 06/12/19 01:25 PM Re: Time For New Mufflers [Re: Cos86SS]
I am a huge fan of the Jones MaxFlo 3 inch mufflers, they are pretty much a magnaflow copy and sound excellent.
#1062357 - 06/12/19 02:31 PM Re: Time For New Mufflers [Re: Cos86SS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
I will check them out. Never heard of them before. Thanks.
#1062363 - 06/12/19 08:03 PM Re: Time For New Mufflers [Re: Cos86SS]
Google muffler shootout. I had the Dynomax welded mufflers on my old IROC and they were comparable to the magnaflow mufflers. Realatively quiet at idle and cruise and pretty loud once you get on it. The Borla XS mufflers appears to be pretty quite compared to the others in that shootout. That’s probably what I’d run on anything around or under 400 HP. If you think you might step up in power later you might want to go ahead and get some 2.5” mufflers and run reducers on then to hook up to your current 2.25” exhaust.
#1062371 - 06/13/19 02:09 AM Re: Time For New Mufflers [Re: Travis Jones]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
Just checked them out. Wow, price is 1/3 of the Borla and Dynomax mufflers. They are made in China but they have great reviews.
#1062372 - 06/13/19 02:12 AM Re: Time For New Mufflers [Re: BadSS]
Cos86SS Offline
Cos86SS  Offline
Westfield, MA
I like the idea of going with 2.5" for future expansion. Something to think about. Thanks.
500/thumbs/20150311_181116.jpg
by MANDS480
500/thumbs/IMG_5668s.jpg
by monteperformance
500/thumbs/party_048.jpg
by pennsburg mike
500/thumbs/before1.jpg
by spazzz86
500/thumbs/Motortopia_BroncoMonte_Edit3_Cropped2.jpg
by 84 ZZ4
