#1038981 - 05/11/16 08:54 PM
Re: A clutch pedal with an OEM feel!
[Re: SickSpeedMonte]
BladeOfAnduril27
Doylestown, PA
~ Matt H.
#1039210 - 05/16/16 12:57 PM
SickSpeedMonte
#1040839 - 06/28/16 01:07 AM
Congrats, it is a great part.
85 - ZZ383, 6-speed, 8.5" 70 - Stock, 35k miles. Scratch that, no longer stock.
#1058825 - 08/28/18 02:39 PM
[Re: Keithss]
SSLance
Keith, this is still the best clutch setup available... I believe Bernie has made a few improvements here or there on the design but overall the function is still the same. http://www.sickspeedmonte.com/Pedal.htm
#1058828 - 08/28/18 03:51 PM
#1060664 - 02/06/19 08:04 PM
Travis Jones
by mclellan83
by Blown Monte
by 87 monte
by 2montes
by sslos
