#1059988 - 11/24/18 06:39 AM Ordered New Gauges for the SS
Bit the bullet and pulled the trigger on the Speedhut gauges for the Monte. I was hoping for a 30% off sale this year but had to settle for 20%. I really didn’t want to spend as much as I did, but I’m used to and love the gauges in my G8 GT and wanted something similar in the Monte.
I struggled on whether to balance things out with a 4.5” speedometer. However, since I find myself looking more at the digital speedometer in the G8 than the analog gauge, I figured I’d go with an AEM GPS digital speedometer - that way I could keep all the gauges I needed in the center section.
This is what I ended up with:
4-1/2” 8,000 rpm Tachometer with shift light
2-1/16” 0-160 mph Digital GPS Speedometer
2-1/16” 0-100 psi Oil Pressure w/warning light
2-1/16” 60-260F Water Temp w/warning light
2-1/16” 0-60 psi Fuel Pressure w/warning light
2-1/16” 8.5-18 AFR Wideband w/warning light
2-1/16” 0-18V Voltage w/warning light
2-1/16” Programmable Fuel Level for stock sensor
2-1/16” 0-2000psi Nitrous Pressure w/warning light
Here’s about how it should look once I’m done. I found some vinyl wrap that looks like it should match up pretty good to the stock black brushed/grain used in the 1985. So,,, I can’t wait to get started on it. I’m going to keep looking for another bezel trim – so far all I’ve seen are in pretty bad shape.
#1059995 - 11/24/18 02:57 PM Re: Ordered New Gauges for the SS [Re: BadSS]
Nice, but is there enough real-estate for that many 2 1/16" holes? The structural integrity of the panel could be compromised as you assemble it. The stock bezel is pretty brittle and flimsy.
#1059997 - 11/24/18 04:09 PM Re: Ordered New Gauges for the SS [Re: BadSS]
AkronAero Offline
AkronAero  Offline
Kevin - I have 8 Speedhut Revolution gauges sitting in the box awaiting arrival of the dash. Adding transmission temp and A/F WB, which I will probably mount under the dash near the center console. I so look forward to having a 270 degree sweep with meaningful numbers rather than the 90 degree "suggested indications". I added directionals and high beam indicator lights to the Speedo, but can still use the current locations on the shadow box if I prefer. Gauges look even better in real life. X2 on making the mounting surface a more solid structural piece. Keep us posted. This will be an intersting build. Where will you mount the A/F bung?
#1059998 - 11/24/18 09:28 PM Re: Ordered New Gauges for the SS [Re: BadSS]
Agree to all accounts. It’s a tight fit for sure, but doable - attached measurements are not exact but close. Still, it looks like I may have to put spacers behind the gauges so the spin rings won’t interfere with each other as they appear to stick out a little more than the gauge bezels (2.27” and 4.5” with 2.05” and 4.22” cut outs). I’m planning on using 1/8” or 3/16” aluminum for the insert panel and will figure out a way to add some additional anchor points and support for it other than just the instrument cluster bezel.
Gordon, I’ll have a bung for the wideband O2 welded in the driver’s side collector (1.875” long tubes). Transmission temp was the only other gauge I would have liked to have. I still could have utilized the “pod” to the right, but if you mount a gauge at the top right, the steering wheel would cover about half of it and I didn’t think it would look right with them offset to the rest of the gauges. The picture is a little off scale, but does well as a representation of what you’d see from the driver’s seat.
I do have a Sport Comp Autometer trans temp gauge left over from my old speed shop. So, I may do some sort of under dash flip down bracket for it once I get everything else up and running.
I literally can’t wait to get back on the car. Six surgeries in 18 months tend to take a while to recover. For me I guess it took about 6 months since I’ve felt better in the last three weeks than I’ve felt in over 2 years.
#1059999 - 11/25/18 04:49 AM Re: Ordered New Gauges for the SS [Re: BadSS]
spacemanspif Offline
Swedesboro, NJ
Another thought would be to use the classic dash panel if you find that you don’t have enough real estate. You pay extra for units that don’t have gauge holes in them already but a a sheet of aluminum gets you back to a blank blank slate. Then you can use the warning light area of a gauge and the dash vent area as well.
I love the speedhut idea and tach with built in shift light, and warning lights but my friend has a set that has been nothing but problems while my autometers have worked perfectly. I want speedhut tech with auto meter reliability
-Mike
Killed a few cones too
#1060032 - 11/26/18 03:23 PM Re: Ordered New Gauges for the SS [Re: BadSS]
thepezking639 Offline
Livonia, MI
Two WB's?
#1060392 - 01/08/19 01:31 AM Re: Ordered New Gauges for the SS [Re: BadSS]
AkronAero Offline
AkronAero  Offline
Kevin - just stumbled on this direct fit bezel from autometer - Has two 5" holes and four at 2-5/8" (to fit autometer gauges). Marketing guys - Who would have known it even exists?
One loses the left A/C vent and the alarm panel but interesting.
https://www.autometer.com/direct-fit-chevrolet-malibu-el-camino-monte-carlo-82-87-5-2-5-8-black.html
If yours comes out, keep the plans and offer to others. And keep us posted.
MIke - Just read your post and had never heard of Classic Dash Panels - seems to be the same as the autometer site, or darn close, but cheaper (so the source for autometer?)
Thanks for posting - here is the link: https://classicdash.com/product/198...-speedo-and-tach-with-auto-meter-gauges/
Fun times
#1060399 - 01/10/19 02:17 AM Re: Ordered New Gauges for the SS [Re: BadSS]
Swedesboro, NJ
Hey Gordon, yup thats the one. I didn’t know autometer sold them, I’m guessing they are rebadging classic dash units as classic has offered them for years. Any progress pics yet?
-Mike
#1060400 - 01/10/19 02:23 AM Re: Ordered New Gauges for the SS [Re: AkronAero]
Fun times
I had seen the Autometer offering, but didn't want to give up the A/C vent and just didn't think it was worth the money they want for it.
Speedhut shipped the gauges the other day and while UPS is estimating a Monday delivery, I'm hopeful they may make it here Saturday. I went ahead and ordered the AEM X-Series GPS Speedometer so it would be here about the same time. Hopefully the gauge bezels will match up fairly well or I can get them to match up (they look fairly close by the limited pictures I could find).
I'll update with some pictures once the gauges arrive and I've made the template.
#1060447 - 01/16/19 02:33 AM Re: Ordered New Gauges for the SS [Re: BadSS]
Well,,,, the gauges arrived and I love the SS logo on the tach. I arranged them on the template and they're going to fit. It'll be a little tighter than the rendition but still doable. The AEM Speedometer bezel is a lot thicker and the gauge is slightly larger. Not sure if I'm going to stick with it, but I really wanted that digital GPS readout and it was the closest match as I could find. If I don't go with something else, I'll have to be real careful on the cutout and recess it to keep it from sitting higher than the rest of the gauges..
1142/thumbs/Monte_72.jpg
by djones27
500/thumbs/DSC04215.JPG
by bullet187
500/thumbs/DCFN0028.JPG
by madmax74
500/thumbs/84montess1.jpg
by ls1_monte
500/thumbs/NoseEmblem.jpg
by LXXXIV SS
Rob Forbes
techjay
