#1059918 - 11/19/18 05:46 AM TOWING QUESTION
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Towing my Monte Carlo to Florida from New York City.Question is should I remove drive shaft or would it be ok to leave on?Trip is about 1400 miles.never towed anything that far before.
Bust your asx during the week..bust your knuckles on the weekend
350 with vortec heads,Edelbrock intake,headers with 2.5"exhaust,SS sway bars,SS rims,spoiler,3:73 wit a POWERTRAX,tubular rear control arms,JEG'S trany,GBODY front brace,umi rear chassis brace.
http://www.cardomain.com/ride/3193776
#1059922 - 11/19/18 12:22 PM Re: TOWING QUESTION [Re: pacheco]
200kSS Online goatee
200kSS  Online Goatee
Bloomsdale, MO
You are flat towing (all 4 of the monte's wheels on the ground) for that long? What are you using for a tow vehicle and dolly/tow bar device?
#1059923 - 11/19/18 12:58 PM Re: TOWING QUESTION [Re: pacheco]
ss4ever Online mwink
ss4ever  Online Mwink
Shelbina, Missouri
If you are towing it that long then yes, disconnect the driveshaft.
#1059925 - 11/19/18 02:04 PM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Towing with a 2007 suburban using a tow bar, Monte will have all 4 wheels on ground
#1059933 - 11/19/18 07:54 PM Re: TOWING QUESTION [Re: pacheco]
Pull the driveshaft for sure. Unless you want a good reason to buy a new transmission...
#1059934 - 11/19/18 09:01 PM Re: TOWING QUESTION [Re: pacheco]
Post a photo of the tow bar you are using, I have never seen a G-Body flat tow on all four. Make sure the steering is unlocked. Suburban will have a tough time braking, take it slow.
The Monte will also need to be legally registered.
#1059939 - 11/20/18 12:12 AM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
https://i5.walmartimages.com/asr/25...amp;odnHeight=undefined&odnBg=ffffff
This is bar I’m using.just need to bolt bracket to bumper
#1059943 - 11/20/18 01:23 PM Re: TOWING QUESTION [Re: pacheco]
carlss Offline
carlss  Offline
Glen Ellyn Il.
Could you rent a flat bed trailer to put it on and tow that ? It sounds like that would be a lot less hassle, no DS removal and what not,,, that's what I did when I had to tow my daily driver 1000 miles home when it blew a head gasket in Colorado, drove it on, strapped it down and hit the road with a rented tow vehicle.
#1059944 - 11/20/18 01:34 PM Re: TOWING QUESTION [Re: pacheco]
Are the bumper shocks safe to pull on?
#1059945 - 11/20/18 02:30 PM Re: TOWING QUESTION [Re: pacheco]
What part of the bumper does this tow bar "bolt" to? Past experience with RV's towing dinghy vehicles, the tow bar attaches to welded baseplates to the frame behind the bumper. You need a solid attachment or the Monte will sway and swerve. Consider putting the car on a U-Haul trailer behind the Suburban.
Check BlueOx for baseplates..
http://www.blueox.com/recreational-commercial-flat-towing/tow-bars/
#1059953 - 11/20/18 10:26 PM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Uhaul wants $400.00 for tow dolly and I still have to remove driveshaft.Tow trailer is $800.00 dollars.Transporters want $900 to $1200.It's snow bird season so rates are high.(Crooks).
#1059954 - 11/20/18 10:49 PM Re: TOWING QUESTION [Re: pacheco]
You could buy a car trailer like this for $2000 in New York and sell it when you get to Florida for the same price.
https://newyork.craigslist.org/wch/tro/d/car-trailer-in-excellent/6749132738.html
#1059956 - 11/21/18 02:33 AM Re: TOWING QUESTION [Re: pacheco]
Find someone to drive the car, or the Burb if you don't trust anyone to drive the Monte!!
#1059958 - 11/21/18 05:03 AM Re: TOWING QUESTION [Re: upflying]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
If I had $2000.00 I’d have it shipped.just moved and moneys tight.
#1059960 - 11/21/18 05:27 AM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Also won’t drive because just installed NEW engine.with less than 40 miles on it,not broken in or proven road worthy.small issue alternator belt came of for no apparent reason.Its is a 350 with vortec heads
#1060316 - 12/27/18 05:15 AM Re: TOWING QUESTION [Re: SSLance]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
No issue.pulled it all the way down.drove under 65 mph,limit was 70.
#1060317 - 12/27/18 05:25 AM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Had to remove front bumper cover then drill 4 holes to mount brackets.didn’t want to cut cover.i did not remove drive shaft snow and freak’n cold.will drive car tomorrow after I disconnect tow bar.hopeing for the best.
#1060320 - 12/27/18 01:39 PM Re: TOWING QUESTION [Re: pacheco]
Crusher Offline
Crusher  Offline
Jersey Shore
Yikes is all I can say. No way would I have done that.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
http://SSMonteCarlo.com
#1060336 - 12/29/18 03:50 PM Re: TOWING QUESTION [Re: pacheco]
I be worried that the NYC car will have hidden rust issues. Especially since all the mid Atlantic cities go apecrap with road salt at the slightest chance of a snow shower. Expect tbat at least the number 2, passenger sidd body mount to require repair work. Even my 08 CVPI needed a little rocker repair from rust.
#1060342 - 12/30/18 04:16 AM Re: TOWING QUESTION [Re: pacheco]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
Did replace passenger side floor already,driver side has to be done next.no body rust everything on floors.
1142/thumbs/Monte_72.jpg
by djones27
500/thumbs/DSC04215.JPG
by bullet187
500/thumbs/DCFN0028.JPG
by madmax74
500/thumbs/84montess1.jpg
by ls1_monte
500/thumbs/NoseEmblem.jpg
by LXXXIV SS
Rob Forbes
techjay
