#1060252 - 12/20/18 12:27 PM Temperature sender installation
mikem Offline
mikem  Offline
Cleveland, OH
I need to replace the temperature sender (in the driver's side head -- not the ECM temp sensor that sits above the thermostat) and am wondering whether any thread sealant should be used. Unlike the sensor, which comes with a sealant pre-applied, the sender has no sealant on the threads. I don't want it to leak, but I don't want to interfere with the grounding of the sender. Also, how much (if any) coolant should be drained before removing the old sender? (Hope the sender comes out okay -- it's never been removed.)
87 SS, totally stock, original owner.
#1060253 - 12/20/18 01:46 PM Re: Temperature sender installation [Re: mikem]
tomh115 Offline
tomh115  Offline
Russellville, AR
My sensing unit came out fine. I did the stupid thing of thinking I could replace it with out draining.. I did but made a mess. Didnt use any sealant as I had to plug a hole puking antifreeze on me and the ground. Not saying I'd do it differently as the drain petcock is a PITA on my car to access just food. FWIW it didnt fix my issue of the gage not functioning
1987 Monte Carlo SS Aerocoupe
Objects in mirror are losing
#1060254 - 12/20/18 02:22 PM Re: Temperature sender installation [Re: mikem]
Drain at least a gallon out. The new sender has brass threads and will make a seal when you tighten it in. You can put a light coat of thread sealant on it if you want and it will work fine.
#1060266 - 12/21/18 01:07 PM Re: Temperature sender installation [Re: mikem]
mikem Offline
mikem  Offline
Cleveland, OH
Thanks to both of you. What happened was that the blade on the sender that the connector slides onto broke off. I noticed that it left a small round metal nub. What I've done in the meantime is to run a short test wire (with alligator clips at both ends) from that nub to the connector wire. It works, so I may put this job off for a bit. Jerry rigged? Yeah, but I'm afraid that the sender might break upon removal since it's been in there 31 years. I once had a spark plug snap off while being removed, and removing its remains was a royal pain.
#1060268 - 12/21/18 02:35 PM Re: Temperature sender installation [Re: mikem]
Witness86SS Online content
Witness86SS  Online Content
Hatfield, PA
Solder it on
Justin
1986 Black SS
#1060272 - 12/21/18 11:08 PM Re: Temperature sender installation [Re: mikem]
Mine came off years ago. I used a speaker terminal connector - slips right over the nub and holds tight. Seems like I had to open up the gap a little at the green arrow to get it to slide on though.
#1060274 - 12/22/18 08:31 AM Re: Temperature sender installation [Re: mikem]
As it's been said K.I.S.S. Use the correct size 6 point socket and remove it, install a new sender and you're done.
500/thumbs/Crash_Bandicoot_026.JPG
by Dave84
500/thumbs/Copy_of_DSCN0035.jpg
by thomto
1056/thumbs/IMG_1750.JPG
by Jeff wida
1192/thumbs/10400294_529896840617_4080_n.jpg
by DLV555
585/thumbs/DSC00179.JPG
by kaz
OneOwner85
