#1060134 - 12/02/18 02:53 PM Exhaust Recommendations
Nate1976 Offline
Nate1976  Offline
Twin Lake MI
I am purchasing a 1984 Monte Carlo SS in 2 weeks and it will need exhaust and headers. What exhaust package is good and fits? I will take recommendations on mufflers as well. Thanks
#1060145 - 12/03/18 03:51 PM Re: Exhaust Recommendations [Re: Nate1976]
Hi Nate, it sounds like a car that "needs" headers and exhaust probably needs other stuff too. What are your performance, appearance and sound priorities? What condition is the rest of the car? Why does it need exhaust, is it rotted out? Will you need AIR fittings on the headers, will you need an O2 bung on the headers, will you need cats?
#1060146 - 12/03/18 07:18 PM Re: Exhaust Recommendations [Re: upflying]
Nate1976 Offline
Nate1976  Offline
Twin Lake MI
The exhaust that is on it doesnt look too bad. I wanted to see what packages where available for my year that would fit well. And getting headers. I am going to purchase a cowl induction hood for it and paint the car blue in the spring. I am going to keep the 305 because it only has 78,000 original miles on it. I plan to put a cam, intake, and heads on it. A guy I know works on race cars and is a mechanic. Those mods would put me about 350 hp. It will be a summer daily driver.
#1060147 - 12/03/18 08:26 PM Re: Exhaust Recommendations [Re: Nate1976]
Ok, it sounds like you are removing the CCC, so you will be doing a distributer change too. There aren't that many headers made for SBC G-bodies and I think the emissions legal TES headers are no longer made. Someone will eventually have a header suggestion and recommendation. I would have an exhaust shop bend up a custom system to your liking once the mods are done, that's what I did after my LS swap. You will need to buy a double hump transmission cross-member to make the headers fit.
Just keep in mind the small bore, poor breathing 305 is not the best performance platform when adding heads, intake, cam, carb and headers. Those power adders work better with the 350.
See more in this thread.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=245007#Post245007
#1060148 - 12/04/18 01:02 AM Re: Exhaust Recommendations [Re: Nate1976]
tomh115 Offline
tomh115  Offline
Russellville, AR
Hooker makes a cat back system that changes the exit location from behind the bumper to side exit behind the rear wheel (grand national style). I've got it on my SS. Heard a lot of horror stories about Pypes systems so I'd avoid them (search them on the forum to read about the issues). If you are removing the CCC system you probably don't have to worry about finding the headers for the AIR pump system like the hooker and edlebrock TES obsolete parts so any good header would work just size the primaries right. True dual or like the stock single cat system? The hooker system is a bolt on for those of us still running the single cat in stock location system.
Lots of questions but welcome to the best forum.
1987 Monte Carlo SS Aerocoupe
Objects in mirror are losing
#1060150 - 12/04/18 03:44 PM Re: Exhaust Recommendations [Re: Nate1976]
Most of the direct fit performance parts for these cars were discontinued 10 years ago. However, you can weld O2 sensor bungs, AIR pump manifolds, and Thermac heaters onto any headers. There is a forum member named bitflipper who sells a performance chip for CCC systems, but if requires using a 87 or 88 computer. The valve shrouding issue with 305s doesn't start until 6,500 rpm, which is very high rpms for a street motor. It would be a problem for race track motors or with d*** measuring contests.
350 hp is wishful thinking, 300 hp is about the practical limit for a 305. That is with using 059, 58cc vortec heads.
#1060151 - 12/04/18 06:29 PM Re: Exhaust Recommendations [Re: Nate1976]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I use a set of hooker long tubes right into 2.5 inch straight pipe from summit, then electric cutouts, then flowmaster 40's( i think), with flowmaster g-body 2.5 inch tailpipes
Keep the carb, computer and O2 sensor. It's easy to weld a sensor bung into a header collector and use a heated O2.
I also recommend one of Bitflipper's chips and an 87 ECU.
You can ditch most things while retaining the computer and get a fairly empty engine bay that isn't a rat's nest of wires
Justin
1986 Black SS
#1060152 - 12/05/18 12:52 AM Re: Exhaust Recommendations [Re: Nate1976]
tomh115 Offline
tomh115  Offline
Russellville, AR
http://montecarloss.com/technical/
Don't know if you have found the link above but it looks like you should be able to get the power you want at the flywheel if you follow a build guide.
#1060153 - 12/05/18 02:42 AM Re: Exhaust Recommendations [Re: Nate1976]
Headers really wake up the L69 engine!!
#1060164 - 12/07/18 09:08 PM Re: Exhaust Recommendations [Re: Nate1976]
Nate1976 Offline
Nate1976  Offline
Twin Lake MI
Thanks for all the recommendations. I am going to do some more research and read the articles from the links on this thread. Thanks for the info gentelmen.
#1060349 - 12/31/18 01:25 AM Re: Exhaust Recommendations [Re: Nate1976]
ghustler Offline
ghustler  Offline
Southern Indiana IN
I added Flowtech headers to my 86, be prepared to undo the motor mount on the drivers side and lift the engine about 3 inches along with taking off the oil filter and plugging the oil sending unit off above the oil filter and moving it next to the distributor with a little brass 45 degree kit off ebay.
1986 Monte Carlo SS
by BaerMonteSS83
by djones27
500/thumbs/Driverspan.JPG
by 1NJIMID8TOR
500/thumbs/DSC02868web4.jpg
by proaction14
984/thumbs/Souza84SS17.jpg
by HI85WH1
OneOwner85
