#1060034 - 11/26/18 08:02 PM Starter recommendations
Ethan Offline
Ethan  Offline
North Babylon, NY
Looking for starter recomendations for my 10.5:1 compression 400 with long tube headers.
It needs to be a offset bolt pattern on the starter.
I've burned thru a couple of part store starters so I tried power master starter and that one turned out to be defective, so looking for some ideas of what to go with.
Thanks in advance
#1060035 - 11/26/18 08:33 PM Re: Starter recommendations [Re: Ethan]
What is going on with the engine crank that is causing you to burn out starters? Heat from the headers might also damage the starter.
#1060036 - 11/26/18 09:20 PM Re: Starter recommendations [Re: Ethan]
AkronAero Online content
AkronAero  Online Content
Ethan,
How long did the first starter run (years?) and was anything done electrically/mechanically beforehand that might have set it off?
What were the symptoms and how long did each starter run?
How are your electricals? Weak or corroded battery? Poor connections?
Can Autozone or others run diagnostics during crank (they do on the battery side).
10.5 doesn't seem too high, but I went to a high-torgue (mini-starter) as an upgrade when I took mine to a 9.9:1 compression.
#1060037 - 11/26/18 09:31 PM Re: Starter recommendations [Re: Ethan]
Thanks Akron, this was the point I was trying to make. OP should find out what is killing the starters and fix that before searching for a more durable starter. Is it a long no start crank due to weak ignition parts or carburetor flooding/ air fuel mixture issues or is the starter bumping up against a compression stroke because the timing is too advanced.A hot engine with pre-ignition is also hard on a starter.
#1060040 - 11/26/18 11:00 PM Re: Starter recommendations [Re: Ethan]
Ethan Offline
Ethan  Offline
North Babylon, NY
The first 1 lasted well over a year. The second one was a defect, the solenoid came apart cuz it was loose.
And this last one makes a sound like it's spinning internally. Since I put it in. And it's a high torque mini starter.
Right now the distributor is unplugged so the engine isn't even trying to fire when i try to crank it.
I might just throw another part store one in since I got a decent run out of the first one, and they've worked for me in the past.
I was just curious to what you guys use.
The battery is brand new as well. And all my connections are clean and tight
#1060045 - 11/26/18 11:53 PM Re: Starter recommendations [Re: Ethan]
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
Go with a GM mini starter. I ran quite a few of these over the years and they work good. Just make sure you get one that matches the flexplate size and starter bolt pattern you need.
I'm not suggesting you buy it from here, but this is the style of starter I'm referring to.
https://www.amazon.com/Chevy-Racing...mp;psc=1&refRID=98VGZSZJP5HTADDQD4PE
#1060046 - 11/27/18 12:38 AM Re: Starter recommendations [Re: MY FYN 79]
Ethan Offline
Ethan  Offline
North Babylon, NY
Yea that one looks like the one I had that worked for over a year and had previously that worked for over 2 years b4 I burnt it up when my battend cable hit my header. These car quest ones I've been using look similar but just seem to lack the quality.
Did you have to shim yours? I've never had to shim my previous 2 good ones but the power master that was crap needed to be shimmed
#1060048 - 11/27/18 02:49 AM Re: Starter recommendations [Re: Ethan]
find a 350 starter and take it to a starter shop and tell them what you are trying to crank, make sure it's a long body starter and not the short body 305 starter and good luck!!
#1060050 - 11/27/18 05:29 AM Re: Starter recommendations [Re: 86ttop]
Ethan Offline
Ethan  Offline
North Babylon, NY
It's definitely not a 305 starter I've been using haha. The power master starter was suppose to be good for a higher compression than what I have. But I probably just got a defect. It happens
#1060051 - 11/27/18 05:55 AM Re: Starter recommendations [Re: Ethan]
Check you negative ground cable, I had a problem with my mini starter burning up the little memory saver negative wire that goes to the fender. Moved the thick negative battery cable to one of the starter's mounting bolts and no more problems. Stock location for the negative cable is one of the front mounting brackets but after 30 years of rust, they do not conduct ground as well as they used too and it would be a major PITA to dissemble all the brackets to clean every mounting point.
#1060052 - 11/27/18 09:23 AM Re: Starter recommendations [Re: Buick Runner]
Ethan Offline
Ethan  Offline
North Babylon, NY
My negative cable mounts to my head, and I have the little wire on the inner fender.
Is the inner fender area what you mean when you said it rusts?
I'll have to check on the little wire and see if it's burnt up
#1060074 - 11/27/18 11:49 PM Re: Starter recommendations [Re: Ethan]
I meant the thick cable, on my engine the main negative cable was originally mounted to the alternator bracket, and it was just rusty enough to interfere with amp flow. So the starter tried to pull the amps through the little wire instead, which couldn't handle it and burnt up. Moved the thick cable to a starter mounting bolt and no more burnt little wire.
#1060081 - 11/28/18 11:31 AM Re: Starter recommendations [Re: Ethan]
MY FYN 79 Offline
MY FYN 79  Offline
N/E WI
I never had to shim one of the gm style starters like linked above.
#1060086 - 11/28/18 11:59 PM Re: Starter recommendations [Re: Ethan]
My starter did not require any shims either
#1060132 - 12/02/18 07:43 AM Re: Starter recommendations [Re: 86ttop]
jmireles Offline
jmireles  Offline
El Paso, Tx
If he can find a place to take his starter...they're becoming more difficult to find.
in '08. 3K
#1060142 - 12/03/18 02:34 AM Re: Starter recommendations [Re: jmireles]
True frown
#1060825 - 02/19/19 08:00 PM Re: Starter recommendations [Re: Ethan]
Ethan Offline
Ethan  Offline
North Babylon, NY
Okay so I bought the recomended gm style starter, worked great sounded fine. Let the car idle, took it to a gas station then went to start it again and it sounded horrible.
Sounded horrible and wudnt crank the car. Left it for a few hours so I could push it home with no traffic. When I went back to it I cranked it and it started right up. Got it home, went out the next day and it's making horrible noises and won't crank. I'm thinking maybe the heat from the headers is killing my starters.
What do you guys think?
#1060826 - 02/19/19 10:50 PM Re: Starter recommendations [Re: Ethan]
Click but no turn? Check for good wiring connections and battery.
But if by not cranking to you mean you hear the starter turning (and spinning) but not engage or maybe grinding? Then its perhaps alignment.
#1060827 - 02/20/19 12:33 AM Re: Starter recommendations [Re: Ethan]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
You could be like me. Sluggish cranking, groaning and ignition clicking like crazy when the starter is hot. Heat soak on a cheap starter, poor wiring and grounds and an undersized battery for the win.
Justin
1986 Black SS
#1060828 - 02/20/19 01:25 AM Re: Starter recommendations [Re: Ethan]
Ethan Offline
Ethan  Offline
North Babylon, NY
The starter is spinning and grinding. Like not engaging. But it was doing perfectly fine when I first put it in. Until i let the car run for a while and then shut it off at the gas station. And this is the second starter this exact thing has happened with.
The fact that it worked after sitting for a few hours made me think I got hot than cooled. But now it's not engaging again. Maybe the heat damaged it and it had one good crank left in it. Idk.
So I'm lost. Maybe it's wiring but I've checked thru it and it all looks good.
Im just confused at this point. Battery is new and higher cranking amps then the battery I used for 5 years too
#1060829 - 02/20/19 01:47 AM Re: Starter recommendations [Re: Ethan]
I actually had a bend flex plate (flywheel) and sometimes it would engage and sometimes it wouldn't. maybe take a few tries. Had power but depending on where it was on the rotation, it would engage immediately, grind or not engage at all (spin free).
Swapped out flex plate and all is well.
Thoughts?
#1060838 - 02/20/19 07:33 AM Re: Starter recommendations [Re: AkronAero]
Ethan Offline
Ethan  Offline
North Babylon, NY
I thought about that, but when I first put the starter in I cranked it without the distributor plugged in to see if it made any weird sounds on the flywheel and it was fine. Probably made 4 or 5 full rotations.
The issues seem to start after the car is running for a bit
And the flexplate doesn't have any obvious damage, but anything is possible.
I'm open to all suggestions haha
#1060842 - 02/20/19 04:55 PM Re: Starter recommendations [Re: Ethan]
Pull the starter down and look at the teeth on the Brendix. Are they damaged ? Are you using shims between starter and block ?
#1060843 - 02/20/19 06:14 PM Re: Starter recommendations [Re: Richie Cat]
Ethan Offline
Ethan  Offline
North Babylon, NY
Haven't check this starters teeth upclose yet, from under the car they look fine. The last starters teeth were fine. The teeth on the flexplate seem fine too.
This one doesn't have shims, the last one I tried with all types of shims after it started to make noise and they didn't help at all. It sounded great when I first put it in so I figured no need for shims.
#1060844 - 02/20/19 07:22 PM Re: Starter recommendations [Re: Ethan]
If it is bent, the position of the flexplate will sometimes be good and engage easily and other times not at all.
My Bendix and flexplate teeth did not look that bad at a distance but on closer inspection did show non-uniform wear.
My warp was probably 3/4" out of line so if the high spot stopped at the starter it was difficult / random to get engagement as the Bendix gear did not extend that far.
It sometimes took several tries, and then grabbed.
If you can get under easily, measure distance to flexplate and turn and measure again. get a number of these and see how close they are grouped.
by BaerMonteSS83
by djones27
500/thumbs/Driverspan.JPG
by 1NJIMID8TOR
500/thumbs/DSC02868web4.jpg
by proaction14
984/thumbs/Souza84SS17.jpg
by HI85WH1
OneOwner85
