#1059699 - 11/03/18 04:35 PM Question for you LS guys
Hi
Found videos of people shaving the top of truck intakes. After doing that, how much clearance would you have compared to a car manifold ?
#1059710 - 11/05/18 03:15 AM Re: Question for you LS guys [Re: Richie Cat]
spacemanspif Offline
Swedesboro, NJ
Shaving truck intakes is only for looks. You might gain 1.5” of clearance but that would be it. Car intake barely sits higher than the coil packs. But if you can fit it, the late model truck intake is the best stock option for area under the curve.
-Mike
Killed a few cones too
#1059714 - 11/05/18 01:43 PM Re: Question for you LS guys [Re: Richie Cat]
Thanks for your answer.
#1059715 - 11/05/18 02:45 PM Re: Question for you LS guys [Re: spacemanspif]
MC96 Online content
MC96  Online Content
St. Johns MI
Would that be the "TBSS intake" (trailblazer ss) or is that a separate intake?
86 SS
In progress
#1059717 - 11/05/18 04:42 PM Re: Question for you LS guys [Re: Richie Cat]
Stock early truck intake and cheap adapter plates on mine, the "Vortech" cover doesn't fit, and I had to trim about 1/8-1/4" off of the tallest bosses to fit under the hood bracing. I had more clearancing to do with the alternator than the intake. "Shaving" is for appearance, although it does take care of any potential clearance issues.
Not sure about TBSS vs later trucks, I think they are similar but I don't remember one way or the other.
#1059755 - 11/08/18 06:11 PM Re: Question for you LS guys [Re: spacemanspif]
86SS86LS Offline
86SS86LS  Offline
Eastern SD
Even the shaved truck intakes look ugly. Its like putting lipstick on a pig......if you are going to run the truck intake....just run it as is IMHO.
#1059756 - 11/08/18 06:15 PM Re: Question for you LS guys [Re: Hunter79764]
86SS86LS Offline
86SS86LS  Offline
Eastern SD
Richard Holdener tested both on his engine dyno.......I believe the TBSS intake was the better performer of the 2.....but not by much.
#1059759 - 11/08/18 06:41 PM Re: Question for you LS guys [Re: 86SS86LS]
thepezking639 Offline
Livonia, MI
By about 10-12 hp and torque. especially now that they are common in junkyards.
https://www.hotrod.com/articles/20-ls1-intake-manifolds-tested/
TBSS intake fits under a stock hood with holley mounts with 0 modification.
It's generally the best "stock" intake for most applications up to 7k
#1059760 - 11/08/18 07:05 PM Re: Question for you LS guys [Re: Richie Cat]
MC96 Online content
MC96  Online Content
St. Johns MI
Next question I have just from seeing build threads and whatnot, isnt there a Dorman replacement for the TBSS if so does it meet the OE numbers?
86 SS
In progress
#1059763 - 11/08/18 07:21 PM Re: Question for you LS guys [Re: MC96]
Livonia, MI
I dont believe there is a dorman replacement, but all 08-11 5.3 intakes are "TBSS" intakes, so there are millions of them out there.
#1059768 - 11/09/18 01:53 AM Re: Question for you LS guys [Re: MC96]
Swedesboro, NJ
Pezking just answered this. The intake started out on the TBSS but when the big engines went rectangle port heads, they used this intake on all the 5.3s that still used cathedral port heads. Early truck intakes can look pretty good with a shave but there isn’t much hope to make the TBSS intake look good...it’s just a big blob.
-Mike
500/thumbs/dcp01322.jpg
by gilrdguezss
1019/thumbs/DSC01332.JPG
by 88monteSScarlo
500/thumbs/frnt-side1.jpg
by Carl
500/thumbs/dusty_monte_shake_down.jpg
by aggieranch
500/thumbs/Multimedia_message.jpg
by Frankie
Rob Forbes
techjay
