#1059519 - 10/21/18 05:11 AM Functional SES after LS swap
jmireles Offline
jmireles  Offline
El Paso, Tx
Until today, I hadn't connected the MIL wire to the Monte's SES circuit. I check the 411 PCM every now and then to check for codes but the only one that appears is for the MIL circuit. I want to make the SES light functional. Unless mistaken, the computer provides the ground for the circuit to complete and the SES light on the dash turns on, correct? I used the yellow wire under the dash (old ALDL port). I checked first by grounding the wire and the SES light came on. I connected the 411 PCM MIL wire to the yellow but nothing happens when you turn on the ignition. What am I doing wrong?
Any help is appreciated.
in '08. 3K
#1059528 - 10/21/18 09:46 PM Re: Functional SES after LS swap [Re: jmireles]
Following. I haven't made any changes on mine either, but if you get it all figured out, I might actually get around to wiring mine up too.
#1059531 - 10/22/18 03:57 AM Re: Functional SES after LS swap [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
I found this on YouTube. It hasn't worked for me, so tomorrow I'll call PSI and see what they suggest.
https://www.youtube.com/watch?v=8XrBaMVqGW4&t=2s
in '08. 3K
#1059532 - 10/22/18 08:27 AM Re: Functional SES after LS swap [Re: jmireles]
What pin and plug number did you use for the MIL on you PCM ?
#1059534 - 10/22/18 07:25 PM Re: Functional SES after LS swap [Re: jmireles]
Mine doesn't work either, never thought about needing it. I think my Dakota Digital cluster has a CEL, I'll look the next time I start it.
#1059536 - 10/22/18 08:57 PM Re: Functional SES after LS swap [Re: jmireles]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
You have to remove the stock lamp driver module. The LS PCM has it built in. I'm looking for instructions that I used.
#1059537 - 10/22/18 08:59 PM Re: Functional SES after LS swap [Re: jmireles]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Here is the instructions I used:
All carbureted computer controlled cars use a Lamp Driver module between the computer and the “service engine soon” or “Check Engine” light. TBI or TPI computer vehicles do not use a lamp driver, instead, are wired directly from computer to SES light. (through the IP harness connector). It will be necessary for you to wire around this lamp driver to make your SES light work correctly with TPI. The Lamp Driver module is taped to the IP harness near the computer harness connector (white plastic 15 pin on my harness) It has four wires going to it. Clip the yellow one, and the white with green stripe wires and join them together. Solder and tape this splice. Now your SES engine light should work correctly with TPI.
Trace one of the two wires you are connecting together back to the stock ecm, & then wire that to the LS PCM wire to drive the CEL.
#1059544 - 10/23/18 05:04 AM Re: Functional SES after LS swap [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
Success!
I was using the wrong wire. I traced all the wires back to the PCM. PSI said it would be the dark brown wire. Sure enough, I had it labeled. It's been two years since the swap, so I have forgotten details. I cut the tan wire (oil pressure for digital readout) from the yellow wire and connected the dark brown wire to the yellow wire, which was part of the old ALDL port under the dash.
As soon as I turned on the ignition, the SES light came on and back off after a few seconds!
I had mistakenly connected the tan wire.
in '08. 3K
1068/thumbs/rafa_5.jpg
by Thumper
500/thumbs/Getting_ready_for_dyno.jpg
by 396 MonteC
500/thumbs/DPA30.jpg
by RocknSS
1113/thumbs/BadAssFender7.jpg
500/thumbs/053009_1933_00_.jpg
by doughboy24
