Page 2 of 2 1 2
#1038981 - 05/11/16 08:54 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
BladeOfAnduril27 Offline
Doylestown, PA
~ Matt H.
#1039210 - 05/16/16 12:57 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
#1040815 - 06/27/16 12:04 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
#1040839 - 06/28/16 01:07 AM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
Congrats, it is a great part.
#1044540 - 10/20/16 12:33 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
Eric'sMonteSS Offline
Abington,ma
Question..
Thanks..
#1045664 - 11/22/16 06:30 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
#1058820 - 08/28/18 10:58 AM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
Keithss Offline
Keithss  Offline
Jackson,mi
Keith
#1058825 - 08/28/18 02:39 PM Re: A clutch pedal with an OEM feel! [Re: Keithss]
#1058828 - 08/28/18 03:51 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
#1059037 - 09/11/18 10:39 AM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
#1060664 - 02/06/19 08:04 PM Re: A clutch pedal with an OEM feel! [Re: SickSpeedMonte]
Page 2 of 2 1 2
Moderated by  Z65_Paul
500/thumbs/nightmare_5.JPG
by NIGHTMARE
500/thumbs/IMG_0550.JPG
by montesleeper83
by SickSpeedMonte
500/thumbs/20150423_185351.jpg
by MANDS480
500/thumbs/IMG101.jpg
by dub562
