#1058160 - 07/08/18 10:11 AM NEED HELP ON HVAC SWAP
axld Offline
axld  Offline
lakeland,fl
ok, i have replaced evaporator / condenser/dryer . I have a LSX with a Sanden compressor. I know the low pressure switch is on the Dryer. I have no high pressure switch , was it on the original compressor (I cant remember been so long ago since i had one)? do i need a high switch? where to put it? BTW , I am going to have to have custom lines made as I swapped out to a IROC condenser ( both lines on pass side where my compressor is).
#1058161 - 07/08/18 02:07 PM Re: NEED HELP ON HVAC SWAP [Re: axld]
The only pressure switch in my system is the one on the dryer.
#1058165 - 07/08/18 04:35 PM Re: NEED HELP ON HVAC SWAP [Re: axld]
Are you using the PCM to control the fans?
Using a stand alone controller for the fan I installed a high pressure switch in the high pressure test port. It's purpose is to turn off the fans when the system pressures are low. Such as on a cold day when you need defrost and don't need the fan running to cool the rad and A/C system pressures are low, or running down the highway at 70 mph when the fans would normally be off and you have very good air flow across the condenser and rad, A/C system pressures are also low.
The high pressure switch used would need to be appropriate for the type of freon used, the system high/low pressures vary with different freons. I'm running R12, switch is a 125-190 in my system. A 134 system would need high limits.
#1058172 - 07/09/18 01:57 PM Re: NEED HELP ON HVAC SWAP [Re: axld]
High pressure switch is nice but not required. Low pressure switch is required.
On the high side, your compressor likely has a Pressure Relief Valve that will vent refrigerant if pressure goes too high. If you want, you can put a pressure switch that will cut the compressor clutch before you get to that point. You can also control fans like Bob is doing. Factory systems now use a high pressure SENSOR to tell the ECM to kick on fans or not (along with vehicle speed etc).
#1058175 - 07/09/18 04:19 PM Re: NEED HELP ON HVAC SWAP [Re: axld]
axld Offline
axld  Offline
lakeland,fl
Thanks guys, originally I had the 411 PCM controlling the fans. with the 2nd fan also wired into the AC on switch. With the new engine /trans swap I am installing a FITECH LS SYSTEM. which does the same controlling I believe. ( I am starting on installing that today) . Then on to the HVAC. Have any of you heard of using a Binary switch ( I take it does both?)
#1058176 - 07/09/18 04:58 PM Re: NEED HELP ON HVAC SWAP [Re: axld]
The binary switch has two terminals, can be selected to be used as a high pressure cutout for the system if pressures get to high. It can also be used as in my install for turning the fans on and off dependent on pressure. A trinary switch has three terminals, can control fans and also shut down A/C if pressures get to high.
Here['s a very helpful PDF from 4Seasons, pages 1070-1090 lists all the A/C switches.
I run a 36663 fan switch in the stock high pressure port, R12 used. 134 pressures are higher
http://www.smpbuyersguide.com/4seasons/app.php?RelId=6.11.10.0.9
That's my take on this.
#1058187 - 07/10/18 08:32 AM Re: NEED HELP ON HVAC SWAP [Re: axld]
axld Offline
axld  Offline
lakeland,fl
Thanks Bob . I will look into it.
585/thumbs/DSC00179.JPG
by kaz
500/thumbs/rollingcouch2.jpg
by rollingcouch
933/thumbs/On_the_Trailer_still.JPG
by Sherdep
740/thumbs/The_Monte7.JPG
by 88MonteLSguy
500/thumbs/DSC05278.JPG
by MARIO87SS
Rob Forbes
techjay
