#1057748 - 06/13/18 03:59 PM Where is temp gage sensor
Bowtiejc Offline
Bowtiejc  Offline
Swannanoa, NC
Is the sensor for the temp gage on the dash in the thermostat housing ? There are 2 sensors in it , what are these for ? Thanks
#1057749 - 06/13/18 05:09 PM Re: Where is temp gage sensor [Re: Bowtiejc]
carlss Offline
carlss  Offline
Glen Ellyn Il.
What year Monte ? Mine is on the pass.side of the block on my 84SS, green wire
#1057750 - 06/13/18 06:00 PM Re: Where is temp gage sensor [Re: Bowtiejc]
Bowtiejc Offline
Bowtiejc  Offline
Swannanoa, NC
Oh sorry it’s a 1988 SS . The thermostat housing has 2 sensors in the top of it
#1057754 - 06/13/18 06:59 PM Re: Where is temp gage sensor [Re: Bowtiejc]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Those aren't for the gauge. There is something resembling the head of a medium sized nail poking out of the side of the block. That is the temp sensor for the gauge
Justin
1986 Black SS
#1057756 - 06/13/18 09:36 PM Re: Where is temp gage sensor [Re: Bowtiejc]
Bowtiejc Offline
Bowtiejc  Offline
Swannanoa, NC
Oh ok thanks man. What are the 2 sensors in the thermo housing?
#1057762 - 06/14/18 01:37 AM Re: Where is temp gage sensor [Re: Bowtiejc]
one is for the computer temp sensor for it to go into closed loop so you can achieve lock up with your converter and so the O2 sensor can adjust the fuel trim, the other is usually a thermal vacuum switch for the EFE(heat riser) valve.
#1057764 - 06/14/18 01:45 AM Re: Where is temp gage sensor [Re: Bowtiejc]
pacheco Offline
pacheco  Offline
Spring Hill,Fl
It’s located on passenger side cylinder head between #1&3 cylinder
Bust your asx during the week..bust your knuckles on the weekend
350 with vortec heads,Edelbrock intake,headers with 2.5"exhaust,SS sway bars,SS rims,spoiler,3:73 wit a POWERTRAX,tubular rear control arms,JEG'S trany,GBODY front brace,umi rear chassis brace.
http://www.cardomain.com/ride/3193776
#1057766 - 06/14/18 02:09 AM Re: Where is temp gage sensor [Re: Bowtiejc]
Bowtiejc Offline
Bowtiejc  Offline
Swannanoa, NC
Thanks bud. but isn't #1 and #3 on driver side . just making sure. thanks for the help.
#1057768 - 06/14/18 02:21 AM Re: Where is temp gage sensor [Re: Bowtiejc]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
As Leo correctly stated, the two senders on the thermostat housing are a temperature sender for the ECM and a vacuum thermoswitch that is part of the emissions system.
The L69 CCC engine used two temperature senders. The sender in the thermostat is exclusively for the ECM. The sender for the instrument cluster gauge is between cylinders #1 and #3 (front of engine), on the driver's side.
1986 Monte Carlo SS
#1057771 - 06/14/18 11:43 AM Re: Where is temp gage sensor [Re: Bowtiejc]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
If your wire is cut off like mine was, dig through the harness to find the clipped wire. Then splice a few more feet on. Does not require a special connector. Can twist the wire on to sensor head and get reading. I'd find a connector of some sort though.
Justin
1986 Black SS
#1057952 - 06/26/18 03:32 PM Re: Where is temp gage sensor [Re: Bowtiejc]
Griffin84ss Offline
Griffin84ss  Offline
Georgetown ky
What if you have done away with the ccc do you still have to use a thermostat housing with the 2 openings or can you put a regular one on there?
#1057995 - 06/28/18 03:21 AM Re: Where is temp gage sensor [Re: Griffin84ss]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
If you have ALL the CCC system removed, and emissions equipment, then you won't need either of the two thermostat fittings (ECM temp sender and ported vacuum switch). You could use a thermostat housing with no holes at all. But, if you are still using the factory distributor and ECM with an aftermarket carb, the temperature sender is still needed for the system to go into closed loop. It would still have issues with not having feedback from the Q-Jet, but at least you would get some ignition advance.
1986 Monte Carlo SS
#1058002 - 06/28/18 11:36 AM Re: Where is temp gage sensor [Re: Bowtiejc]
Griffin84ss Offline
Griffin84ss  Offline
Georgetown ky
Thanks ChasUno for the advice I have new distributor, new carb, new intake. Where or how do I get it to read temp gauge is there a spot on the 305sbc for a temp sensor?
#1058003 - 06/28/18 12:03 PM Re: Where is temp gage sensor [Re: Griffin84ss]
Left side of engine (drivers side) on cylinder head between #1 &3 exhaust ports. Find a dark green wire, that will be for OEM dash temperature gauge.
1142/thumbs/Monte_72.jpg
by djones27
500/thumbs/DSC04215.JPG
by bullet187
500/thumbs/DCFN0028.JPG
by madmax74
500/thumbs/84montess1.jpg
by ls1_monte
500/thumbs/NoseEmblem.jpg
by LXXXIV SS
Rob Forbes
techjay
