#1056909 - 04/15/18 12:50 AM Will a 200 metric transmission fit my 85 monte
est85monte Offline
est85monte  Offline
Phoenix, Arizona
My trans started slipping reverse and no 4th found some guy local that has a couple that came off mid 80s Cadillacs said they have like 80k on them says they have universal bellhousing fit sbc I can't find any off a monte anywhere, any recommendations,suggestions,comments please let me know I'm so anxious to get my car back on the road thanks guys is it the same trans is basically what I'm asking guys
#1056911 - 04/15/18 02:03 AM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
A universal fit will bolt in, are you sure it's a 200 series trans??
#1056917 - 04/15/18 03:34 PM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
upflying Online content
upflying  Online Content
I would avoid the weak TH200, you are better off using a TH350.
Why not have your TH200R4 rebuilt?
Here is a chart of what fits what.
http://www.maliburacing.com/auto_tranny_id.htm
#1056919 - 04/15/18 04:43 PM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
Hey-O Offline
Hey-O  Offline
St Charles , Mo
Had a TH200 in a new 1978 Oldsmobile Firenza GT with a Chevy 305 engine. Had to sign a waiver because it had a Chevy engine in an Oldsmobile, yes, the good old days, NOT!! Drove it of the show room floor and after 34,000 the transmission was shot. Biggest piece of junk I have ever owned. Do yourself a favor and stay away from that mess!! They were built to handle 4 cylinder cars and didn't hold up to them either!!
#1056921 - 04/15/18 07:24 PM Re: Will a 200 metric transmission fit my 85 monte [Re: Hey-O]
It sounds like you had an Oldsmobile Starfire, the Firenza was a FWD J-car pos.
The Starfire was based on the Chevy Vega, the Chevy version was called the Monza. I heard the 305 engine had to be raised to remove the #8 spark plug in those cars.
#1056923 - 04/15/18 10:13 PM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
est85monte Offline
est85monte  Offline
Phoenix, Arizona
What would I need to do to put a 350 instead of the stock 200r4 I'm just looking to be a good reliable car what would I need to change for the 350?
Thanks for all your feedback I really appreciate it fellas I just wanna drive my car this AZ weather is perfect right now
#1056924 - 04/15/18 11:16 PM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
The TH350 is the exact same size and length as the TH200R4, it bolts right in. You loose overdive and some fuel mileage with the TH350.
#1056925 - 04/16/18 02:46 AM Re: Will a 200 metric transmission fit my 85 monte [Re: upflying]
thepezking639 Offline
Livonia, MI
Uh... you may want to research that. I don't think that is correct... http://chevellestuff.net/tech/automatic_trans_dimensions.htm
My advice is to build th200-4r. Best 4 speed auto GM made next to the 4l80E.
#1056931 - 04/16/18 03:03 PM Re: Will a 200 metric transmission fit my 85 monte [Re: thepezking639]
Are you saying a TH 350 won't bolt right in? And I agree, the TH 2004R is the best option fr the OP.
#1056934 - 04/16/18 08:45 PM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
Hey-O Offline
Hey-O  Offline
St Charles , Mo
https://en.wikipedia.org/wiki/Oldsmobile_Starfire
Robert, check the silver car at the bottom of the list of pictures, that's the car I had, color and all. It was a Vega dressed up. You're right, the motor had to be lifted up on one side to get to the one plug. It ran good, but they came with a TH200 or TH350. They told me which transmission you got was based on what was available that day, I got screwed, LOL !! They had problems with control arms breaking at the frame due to the extra weight.
#1056941 - 04/17/18 01:42 PM Re: Will a 200 metric transmission fit my 85 monte [Re: Hey-O]
Ok, looks like the Firenza was a sporty appearance package on the Starfire. Confusion occurred because Olds named their J-car the Firenza. I almost bought a new Vega but I chose the Pinto instead. Lot's of bad cars in those days.
#1056942 - 04/17/18 01:58 PM Re: Will a 200 metric transmission fit my 85 monte [Re: Hey-O]
Livonia, MI
Not to mention these things were built in lordstown, in which General Assembly and the Body Shop are represented by two different UAW locals, I've has some friends that worked there, and it made things "Interesting"
#1056964 - 04/20/18 03:22 AM Re: Will a 200 metric transmission fit my 85 monte [Re: est85monte]
est85monte Offline
est85monte  Offline
Phoenix, Arizona
Thanks guys for your input its really helpful and awesome to get a response from you guys I think I found one in a private junkyard that has Montes and grand nationals in there hopefully I get a good one I'll update you guys if I get one thanks fellas
500/thumbs/e451b39e800fffc05f708f67acaa66c80_large.jpg
by crazyhorse1983ss
500/thumbs/06150112201.jpg
by GP'S 84 SS
1119/thumbs/000_0070_350x262_.jpg
by EMann
500/thumbs/DSC_0429.JPG
by Leon
500/thumbs/car7.jpg
by FrankOC
OneOwner85
