#1056906 - 04/15/18 12:01 AM MSD 8366 Distributor Modules are JUNK!
Dan The Man 920 Offline
East Rockaway, NY
I am sure that there is already threads on this subject, but I want to share my personal experience with everyone and hopefully help someone avoid the same problems I have faced. 2 winters ago(yes I drove my car in the snow) I purchased an MSD 8366 Pro-Billet Distributor to replace my Jegs small cap HEI unit which had a bad pickup coil and had the magnet severely rusted. Initial impressions were that the MSD unit was a very well built piece. Full billet housing, .500" diameter shaft, MSD's style of mag pick up trigger and an MSD brand module. I did not have a single issue up until last September where my car backfired and died driving down the parkway. The car had no spark or a cranking signal(tach was not moving when engine cranked). It turned out that my nearly new MSD distributor module was dead. After contacting MSD, they did right by me and replaced the module free of charge. I drove the car for about another 4 weeks and put it away for the winter(I got a winter beater for this year). Yesterday, I took it out for the first time this spring and it started right up and ran great. Today however, it was about 80 degrees and sunny so I took it out again. As I was cruising along, the car shut off and I was unable to re fire the car. Thankfully, I had an original, 30 year old ignition module with me that I swapped in on the side of the road. Sure enough, the car fired right up. IT KILLED ANOTHER MODULE! A brand new piece from MSD was dead with less than 24 hours of run time on it. Is there anyone out there who has had this same experience with MSD products? I thought they were better than this.
1987 Monte Carlo SS, Flowtech Headers, True Duals Jet stage 2 chip, KN filter Accel 300+ ignition, M/T ET Streets
Best E.T. 15.415@87.39mph
#1056908 - 04/15/18 12:32 AM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
supernova455 Offline
tampa, fl usa
Been there, done that, story is too long to type here. I learned long ago it is DAM hard to beat the GM ffactor HEI big or ssmall cap distributor!! Especially the moduels !
#1056912 - 04/15/18 02:08 AM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
You found out that MSD is junk. let me find a good thread and I'll post it.http://www.chevelles.com/forums/18-engine/1051057-exaust-popping-after-i-added-external-ignition-coil-video-post-2.html Dave Ray is the one to read, he's been in the ignition business for many years, good luck!!
#1056918 - 04/15/18 04:42 PM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
Intmdatr3 Offline
Intmdatr3  Offline
North Central Wisconsin
I had the same problem last year with the Monte. The Monte died on us driving home from car show. Thought I fixed it when I replaced module but died on me again. Finally replaced the whole distributor will not have another MSD one again pure junk........
#1056920 - 04/15/18 06:24 PM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
Small town USA
I also used MSD for many years with great success. Since I have moved to DUI for my newer builds.
#1056940 - 04/17/18 01:23 PM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
thepezking639 Offline
Livonia, MI
Yeah, I'd never willingly spend money on anything that MSD makes. Unless you spend time over 7K rpm, spray or shove boost down an motor. A GM HEI is all you need. And If you do use the bottle or boost, I recommend using LS coil near plug with a microsquirt and a reluctor wheel.
#1056948 - 04/18/18 02:20 PM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
Bitflipper Offline
Bitflipper  Offline
Las Vegas, NV
You're lucky you were only blowing modules. When my MSD distributor went it started creating a massive backfire due to misfiring. This ended up creating serious damage across my car including blowing out the catalytic converter, intake manifold gasket, and who knows what else I haven't found to this day. The thing that really kills me about the experience is that I went to the junk yard, found a Cadillac with an OEM distributor that looked to be in really good shape, swapped it in and the backfiring disappeared. I'm still running that distributor from the Cadillac donor.
So I definitely agree, those MSD distributors are junk and will cause thousands of dollars of damage beyond the distributor failure itself. Their ignition modules are also crap, they overheat and will leave you on the side of the road on a hot summer day after around 20-30 minutes of driving until they cool down, then fail again every few minutes until you finally get home.
#1057038 - 04/26/18 01:43 AM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
East Rockaway, NY
I'm just thankful that I was close to home when they both failed. Although the second time I was fully prepared with my old gm module. The first time I needed a tow, which was a fiasco in itself.
#1057080 - 04/29/18 08:18 PM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
Generally with HEI ignition modules, the dist housing acts as a heat sink. This is why you use special heat sink paste for electronics to coat the bottom of ignition modules.
#1057084 - 04/30/18 01:24 AM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
AkronAero Offline
AkronAero  Offline
Two years ago had an MSD ignition module and rotor failed (carbon button exploded). Replaced with DUI cap, coil and rotor and MSD 6AL ignition control box. Epoxy in the coil cracked after maybe 1000 miles and I replaced all with AC Delco. Have a complete spare cap, rotor and coil assembled and in the trunk now.... we shall see. Some guys change theirs out every spring just to be safe. Lots of old school guys debating non-conductive paste vs no paste.
#1057107 - 05/01/18 12:07 AM Re: MSD 8366 Distributor Modules are JUNK! [Re: Dan The Man 920]
You don't use non conductive paste (dielectric grease), you must use special heat conductive paste, totally different stuff. Putting a module on dry is a guaranteed rapid failure, no matter the brand.
500/thumbs/e451b39e800fffc05f708f67acaa66c80_large.jpg
by crazyhorse1983ss
500/thumbs/06150112201.jpg
by GP'S 84 SS
1119/thumbs/000_0070_350x262_.jpg
by EMann
500/thumbs/DSC_0429.JPG
by Leon
500/thumbs/car7.jpg
by FrankOC
OneOwner85
