#1025284 - 06/05/15 12:09 AM SS RIM CLEANER
Ubowl Offline
Ubowl  Offline
Hudson, NH
I had some really dirty wheels kicking around I mean really grimed up thick brake dust covered rims. Tried cleaning one with about three different wheel cleaners. Not impressed with any of them. My neighbor told me to go to the grocery store and get easy off oven cleaner. Spray it on and leave it there for a half hour then with a med bristle brush. Give it a good brushing. Then rinse it off with a hose. I couldn't believe these rims. They look brand new. Best 4.99 I ever spent. SO EASY. Hope this saves you guys some time
#1025291 - 06/05/15 02:09 AM Re: SS RIM CLEANER [Re: Ubowl]
ls1_monte Offline
ls1_monte  Offline
Eastern Iowa
You'll have to look it up but I believe oven cleaner is hard on aluminum, if it was me I wouldnt use it on them again without checking for sure.
#1025297 - 06/05/15 05:14 AM Re: SS RIM CLEANER [Re: Ubowl]
Ubowl Offline
Ubowl  Offline
Hudson, NH
Well I used it on 4 rims now and all I saw was the brake dust and all stains just run off and leave a perfectly clean wheel. Didn't damage the rims at all. The only bad thing I forgot to mention was be careful with the brushing with splashing back on you. Oven cleaner will give you a burning sensation. But the wheels look perfect. I will definitely will use it again. Thanks for your feedback lsmonte.
#1025368 - 06/07/15 11:11 PM Re: SS RIM CLEANER [Re: Ubowl]
LXXXIV SS Offline
LXXXIV SS  Offline
Lower Peninsula, Michigan
Is there any chance the oven cleaner didn't contact the aluminum itself?
The reason I ask is that many aluminum products are clear coated.
#1025405 - 06/08/15 03:43 PM Re: SS RIM CLEANER [Re: Ubowl]
tkruger Offline
tkruger  Offline
Rochester, NY
I have had aluminum sheet pitted by oven cleaner. The other worry I would have is what does it do to rubber? Or paint? No madder how careful you are there will be a little over-spray to other areas.
#1025701 - 06/13/15 09:35 PM Re: SS RIM CLEANER [Re: Ubowl]
Ubowl Offline
Ubowl  Offline
Hudson, NH
I stripped the clear coat off the non painted part of the rims and polished those parts. Oven cleaner didn't bother those parts at all.
#1035966 - 03/06/16 05:02 PM Re: SS RIM CLEANER [Re: Ubowl]
GotGrunt Offline
GotGrunt  Offline
Long Island, NY
I usually don't let my wheels get dirty enough to have the brake dust bake on but this is a good tip to know just in case.
#1037066 - 03/30/16 01:09 PM Re: SS RIM CLEANER [Re: Ubowl]
benen Offline
benen  Offline
Fort Wayne, IN
What wheel cleaners have you used? I use Adam's Wheel Cleaner (online only) and it is very powerful stuff and gets dust off every time. Just don't let the stuff stay on for too long or it will ruin the wheels.
#1041083 - 07/04/16 11:59 PM Re: SS RIM CLEANER [Re: Ubowl]
crunkz06 Offline
crunkz06  Offline
hampton, VA
great tip
#1043152 - 09/04/16 09:38 PM Re: SS RIM CLEANER [Re: Ubowl]
upflying Online content
upflying  Online Content
I posted a wheel cleaning thread a long time ago, I will try to find it.
15 year old thread..
http://www.montecarloss.com/community/ub...8727#Post218727
#1044643 - 10/24/16 02:31 AM Re: SS RIM CLEANER [Re: Ubowl]
Lights,Shift,Go Offline
Omaha, Ne
Black magic. Aluminum cleaner or even all wheel cleaner. Sprayed it, waited 2 minutes, hose it off. Clean and shiny.
Couldn't believe I was spending 30-40 minutes a morning scrubbing wheels.
Spraying it on initially, started breaking down the brake dust. Highly recommend it.
#1045423 - 11/15/16 06:17 PM Re: SS RIM CLEANER [Re: Lights,Shift,Go]
Witness86SS Online content
Witness86SS  Online Content
Hatfield, PA
I tried Black Magic this weekend and it did nothing. Left it on for 2 minutes, left it on for 45 minutes, scrubbed it with steel wool and it made very little difference.
A few weeks ago I used Evapo-Rust on the car. I spent 24 hours constantly spraying every part of the car that I could see rust on or had scraped the rust off of. Basically kept it wet the whole time. Be careful if you use it under the hood. I gummed up my choke and it took 2 weeks for that to operate correctly again.
Anyways the Evapo-Rust worked extremely well on the wheels, but only to a point. I had brake dust just streaming off of the rims. Prior to this I used degreaser, scrub brush and a power washer and had very poor results.
The rear rims are almost completely clean now. Probably a lot less brake dust exposure since they are drum.
This is what I have left on the front after degreaser, power washer, Evapo-Rust, Black Magic and steel wool. I'm considering blacking out the rims until I replace them with some ralleye wheels or a very cheap clean and local original set.
Justin
1986 Black SS
#1046093 - 12/06/16 12:42 AM Re: SS RIM CLEANER [Re: Witness86SS]
Wow, it looks like the wheel has terrible pitting of the clear-coat.
I had a set that 2 were damaged by rear brake cylinders leaking brake fluid, they were a real mess.
You could try using Navy Gel/paint stripper to strip all paint on it, scuff the painted areas and re-paint them, and polish up the machined surface with some Mother's Billet polish.
Here's one that serves as inspiration for some work to be done, but the results can be great!
More pics here, courtesy of 85_SS
http://www.montecarloss.com/photopost/showgallery.php?cat=508
#1053262 - 09/07/17 01:48 PM Re: SS RIM CLEANER [Re: Ubowl]
T-Top Tom Offline
T-Top Tom  Offline
Gilbertsville, PA
Looks Great!
#1056651 - 03/27/18 10:32 PM Re: SS RIM CLEANER [Re: T-Top Tom]
pantherw126 Offline
pantherw126  Offline
New York, NY
So, I'm at the point where I can't handle my wheels anymore. Is the consensus kind of in favor of Over Cleaner to get stock SS rims back to life?
#1056654 - 03/28/18 02:21 PM Re: SS RIM CLEANER [Re: pantherw126]
Heavy duty paint stripper worked for me. I did this 17 years ago, my wheels still look like new. Here is the thread.
www.montecarloss.com/community/ubbt...;Main=24372&Number=218727#Post218727
#1056879 - 04/13/18 03:16 AM Re: SS RIM CLEANER [Re: upflying]
pantherw126 Offline
pantherw126  Offline
New York, NY
I think i'm going to try the Stripper next. Oven Cleaner did some good but the wheels need to just get brought back to where they started,
#1059451 - 10/17/18 12:53 AM Re: SS RIM CLEANER [Re: Ubowl]
2ndss Offline
2ndss  Offline
Evansville in.
Windex works well too to clean rims
500/thumbs/e451b39e800fffc05f708f67acaa66c80_large.jpg
by crazyhorse1983ss
500/thumbs/06150112201.jpg
by GP'S 84 SS
1119/thumbs/000_0070_350x262_.jpg
by EMann
500/thumbs/DSC_0429.JPG
by Leon
500/thumbs/car7.jpg
by FrankOC
OneOwner85
