Page 30 of 30 1 2 28 29 30
#1028409 - 08/22/15 03:02 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
My T56 is a 2.97 1st gear.
Here's the 1st gear calculations.
Input gear is 38 tooth which turns a 29 tooth on the counter shaft. On the other end of the counter shaft a 19 tooth gear which turns a 43 tooth gear on the output shaft.
So ratio is;
38 divided by 29 X 43 divided by 19 = 2.9655 which is 2.97 1st gear.
Liberty Trans treated me very well for parts, ask for Paul.
With only about 4K miles on my brand new T56 a decade ago I broke the 3/4 keys in the 3/4 synchro, this was years before solid keys were available from all the venders today. Called Tremec factory tech and was told only the stamped steel keys were available. Luckily found a guy who had a direct connection into the parts shelves of the old Borg Warner plant in Indiana, (Tremec, Mexico, had already bought out Borg Warner and moved production to Mexico), and was adapting solid keys from other trans into his T56 rebuilds. He sent me a set for 1/2 and 3/4 along with the necessary springs. Also installed the 3/4 steel fork, new 3/4 synchro assemble, and new a 1/2 fork with a steel insert on the 2nd gear side of the fork, another trick the builder was doing. My T56 has been very good since, only recently have I given thought to taking it apart again and freshening the 3/4 synchros, 3rd gear seems to be the gear that takes the most abuse.
If you don't have a hard copy of the T56 service manual here it is on PDF.
http://www.ttcautomotive.com/anexos/TRSM_T56_0711.pdf
#1028412 - 08/22/15 03:26 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
mymonte-ss Offline
mymonte-ss  Offline
Salisbury NC
thanks had the manual otherwise I wouldn't have dove into this. Had to recount gear teeth, I've got a 2.66 so that helps parts searching.
87 Monte,TPI conversion eng/trans from an 89 IROC had a paxton on it, its for sale! LS1 brakes and 9" rear finished, 3.56 with a locker to be tested. Been sitting since I graduated in 04 on the verge of resurrection. http://www.cardomain.com/ride/3192829
#1028603 - 08/26/15 01:55 AM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
JERMzSS Offline
JERMzSS  Offline
Fort Smith, Arkansas
I'm about to jump into a LS/t-56 swap and I'm so glad to see so many have done this already. I have to admit I am alittle worried about being in over my head but I really want a manual transmission in my car.
Is there any tips or tricks that you guys ran into that you didn't expect that you care to share?
#1028955 - 09/06/15 02:45 AM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
mymonte-ss Offline
mymonte-ss  Offline
Salisbury NC
Finding the internals needed to be replaced. After some digging there are several suppliers out there, I'm prob around 3k into this trans, it was 1200-1500 for the trans several years ago, then about 425 (including shipping) to get the tail housing modified. Then about another grand in rebuild parts. Not including modding th cross member(easy) installing the pedal assay, not hard but took some time, still have to put it all back together and see how she works. Hard to do when your job has you on the road at random times.
#1038237 - 04/23/16 11:18 AM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
Hurst Monte SS Offline
Akron, OH
1986 NWC T5
Chevy SBC Gen I w/Holley 670 Street Avenger
'78-'81 Elcamino pedal assembly and z bar assembled w/Speed Direct spherical Rod ends. 1983 Camaro Bellhousing, lightweight flywheel and RAM clutch
Hurst shifter and modified Lokar boot
2" drop spindles with Bilstein B6 all the way around
Nitto 450 255/50/17 front 275/50/17 rear on Hurst Dazzler 17x8 wheels
#1038244 - 04/23/16 02:58 PM Re: The Official Manual Monte Cult Register [Re: Hurst Monte SS]
clean8485 Offline
clean8485  Offline
Lindsay, Ontario
HurstMonteSS, do you have any photos of your swap? Are you using headers on your SBC, and if so, what brand of headers are you using with the mechanical clutch linkage? How do you like the Speed Direct clutch parts? Thanks in advance.
#1054590 - 11/27/17 07:53 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
Phil87SS Offline
Phil87SS  Offline
Gilbert, Arizona
1993 F-body T-56 with hydraulic activation, Hurst short-throw shifter, 50% ratio in 6th.
#1054595 - 11/28/17 12:03 AM Re: The Official Manual Monte Cult Register [Re: clean8485]
TURNA Offline
TURNA  Offline
New York, NY
When I had a T5 in my old Malibu with mechanical linkage I used the Mr Gasket headers that have now been replaced by Headman Headers 68310
1980 Malibu Classic Big Block T-56
1988 Monte Carlo
The beauty of the Second Amendment is that it will not be needed until they try to take it.
#1056488 - 03/20/18 01:24 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
walshie Offline
walshie  Offline
Croton on Hudson, NY
I am in the process of doing the conversion...Auto transmission is OUT. Next steps:
- Add pilot bearing
- Change the flywheel
- Install pressure plate and clutch
- Raise transmission in place and mark holes to cut the tunnel
- etc, etc, etc
Questions:
1) What size bolts do you think I will need to bolt the Tremec T5 NWC to the manual transmission housing (e.g. bell housing)?
- I couldn't find a kit.
- I did order kits for the clutch to flywheel and flywheel to engine
2) What fluid? After alot of research,
- I believe NWC wants 50wt gear lube
3) What is the best way to measure the drive shaft?
- I'm thinking slip ALL THE WAY into the transmission, measure how much has to be cut
- Back out as much as I can, measure again
- Split the difference?
#1056660 - 03/28/18 06:17 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
walshie Offline
walshie  Offline
FYI = the bolts needed to bolt the transmission to the bell housing were....12MM. I bought 1.75" long but 1.5" is probably better.
#1056827 - 04/09/18 05:43 PM Re: The Official Manual Monte Cult Register [Re: zombiedeth]
walshie Offline
walshie  Offline
Transmission, driveshaft, cross member, shifter are in!
I'm ready to tackle the pedals and hydraulics.
I had to cut my driver's side header, it's where the slave cylinder wants to be.
Once together I will bring it to a pro in order for the exhaust to be re-worked as needed.
I can't wait to drive this puppy!
500/thumbs/Monte_41.JPG
by Chevyman540
500/thumbs/090116_111913.jpg
by 87Aerocoupe87
500/thumbs/Scott_86SS_sig.jpg
by Scott_86SS
500/thumbs/28398_455414548661_7038195_n.jpg
by UNOH_MONTE
500/thumbs/bluerim.jpg
by Mr-SShadow
