#1056301 - 03/09/18 05:22 PM Console screw size
Joe87monteSS Offline
Memphis,TN
Does anyone know the thread pitch and size of the console screws (2) that mount the rear of the console to the floor? I misplaced mine, and this is all I need to mount the console after the 4 speed swap.
Thanks!
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#1056318 - 03/10/18 03:49 PM Re: Console screw size [Re: Joe87monteSS]
84ss355*4spd Offline
Edmonton,AB,Canada
If i remember correct i think they are 1/4 " fine thread bolts . 4 speed nice nothing like a stick ! Good luck.i will try amd look for the console bolts and post a pic .i dont have a way to measure them
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1056325 - 03/10/18 09:13 PM Re: Console screw size [Re: Joe87monteSS]
Memphis,TN
Thanks, that helps. I will see if those fit.
Joey
2004 Silverado
Facebook
#1056333 - 03/11/18 04:01 PM Re: Console screw size [Re: Joe87monteSS]
Edmonton,AB,Canada
Did that work out for you .hope i remember right
86 ss gone
85 ss new
85 z28 tpi
#1056334 - 03/11/18 05:41 PM Re: Console screw size [Re: Joe87monteSS]
PB86SS/87LS Online beer
PB86SS/87LS  Online Beer
If you need a pair still let me know, I have so many bolts from part outs, I’d think I have those and can match them up from my consoles. IIRC the rear bolts aren’t as unique as the front bolts to the shifter.
#1056349 - 03/12/18 06:18 PM Re: Console screw size [Re: Joe87monteSS]
Memphis,TN
That was not the correct size. The holes appear to be a bit smaller than a1/4 inch. Most likely metric...
Joey
2004 Silverado
Facebook
#1056415 - 03/16/18 12:14 AM Re: Console screw size [Re: Joe87monteSS]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
It Paul can't help you out, check out the fastener section in Lowes. They carry all manner of automotive fasteners in there huge selection if general fasteners, including for trim parts. Almost certain that you will find what you need there. Home Depot may carry them also, and you could also try Ace Hardware.
1986 Monte Carlo SS
#1056419 - 03/16/18 01:49 AM Re: Console screw size [Re: Joe87monteSS]
I found two extra that are identical to the ones in both of my Monte’s and I believe are the original style. I can post a pic if that helps and/or just toss them in the mail, should take a small padded envelope.
#1056421 - 03/16/18 02:13 AM Re: Console screw size [Re: Joe87monteSS]
Memphis,TN
I did check Lowe's, and they didn't have anything. I started trying any bolts that I had lying around. The only thing I had that would closely fit was a holley float bowl bolt which is 12-24. And it was loose.
Joey
2004 Silverado
Facebook
#1056852 - 04/10/18 02:08 PM Re: Console screw size [Re: Joe87monteSS]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
The bolt heads are 10mm but the thread pitch is kind of goofy-its like a damn deck screw almost lol
gbodyparts1234@yahoo.com
HARNESSWORX
by PoorBoysRacing
500/thumbs/engine.jpg
by Wisconsin
946/thumbs/mcss23.jpg
by rigo84
500/thumbs/Driver_Side_400x_201.jpg
by SS87
500/thumbs/MonteEFIprogress6small.JPG
Rob Forbes
techjay
