Page 7 of 7 1 2 3 4 5 6 7
#1047015 - 01/10/17 08:42 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
BStewart84SS Offline
Myrtle Beach, SC
PM Sent, looking for a GM shaft.
400sbc, TH350 w/shift kit
#1047487 - 01/24/17 02:08 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
PM and email sent. I need a shaft
Justin
1986 Black SS
#1049774 - 04/09/17 01:33 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
MC87SS Offline
MC87SS  Offline
Tallahassee, Florida
Have a couple more Solids in stock.
#1049860 - 04/12/17 02:42 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: ChasUno]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Originally Posted by ChasUno
Quick question - does the rubber isolator shaft offer any advantages/ disadvantages over the totally solid shaft?
If your just cruising, No. The stock shaft is fine for normal street driving. If you push the handling of your Monte, then Yes. Provides more accurate steering without the slop of the rag joint.
#1049979 - 04/15/17 03:36 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: Fred SS]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
Received mine (solid GM shaft) the other day. Looks great, very well packaged and lightning fast delivery too. Many thanks Ken! thumbs
Thanks for the info. Fred, though I meant advantages/ disadvantages of the upgraded GM rubber isolator shaft vs the upgraded solid shaft. I should have read the whole thread as Ken did explain in a previous posting that the rubber isolator shaft is supposed to reduce vibration, but GM only supplied it for a year. I thought that maybe the rubber isolator shaft used rubber/ plastic bushings, hence being wary of them. It appears that that particular shaft might just use a chunk of rubber surrounding part of the shaft to absorb vibrations (please correct me if my assumption is incorrect.)
With regards to my OE rag joint, I came back from a drive recently and had noticed a knocking from the steering, plus a lot of steering slop noticeable at highway speeds. Grabbing the shaft by hand showed a lot of play, which indicates that the rag joint is shot. It was a no brainer to order one of these solid GM shafts, and I am looking forward very much to getting it fitted and tightening up the steering. It will be nice to take high speed bends on the interstate without my having my Monte not knowing when to actually start steering!
1986 Monte Carlo SS
#1049981 - 04/15/17 12:28 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: ChasUno]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
What a difference these make. All slop and drifting was gone after the install. Not even sure that I need to replace the tie rods and ball joints like the mechanic said now.
Justin
1986 Black SS
#1051147 - 05/29/17 02:25 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
CocaColaPistola Offline
Lawrence, KS
Any shafts still available? Are they adjustable in length?
#1052172 - 07/11/17 02:54 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
shaner85 Offline
shaner85  Offline
Ottawa Ontario
Hey...any way a Canadian kid can get one? Or pm me what other options I have.
Thanks.
350 vortec roller on its way...just need to get it together...
#1052496 - 07/21/17 06:16 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Crusher Offline
Crusher  Offline
Jersey Shore
I need a solid shaft. Installed the isolator one and the isolator damn near touches my header tube. Credit card barely makes it inbetween them. Big block header goes around steering shaft. Let me now if any come available.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
637 RWHP 587 TQ
http://SSMonteCarlo.com
#1053856 - 10/14/17 10:32 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
axld Offline
axld  Offline
lakeland,fl
sent a PM and a e-mail to you . the jeep shaft isolator rubs my #5 header tube, the GM shaft looks like it will clear. ready to buy.
thanks, axld.
#1053877 - 10/15/17 05:19 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
axld Offline
axld  Offline
lakeland,fl
still making them? smile
#1054423 - 11/15/17 02:06 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
ArturHawk Offline
ArturHawk  Offline
Middletown, Pa
Interested in a solid shaft if they are still available.
Charles
#1054546 - 11/24/17 07:57 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Griffin84ss Offline
Griffin84ss  Offline
Georgetown ky
Interested in one if you are still making them preferably a GM for my 84ss Monte Carlo. Thanks
#1054547 - 11/24/17 07:59 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Griffin84ss Offline
Griffin84ss  Offline
Georgetown ky
#1054630 - 11/30/17 04:16 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
BlueBoy84 Offline
BlueBoy84  Offline
Northern KY
Likewise
#1054638 - 11/30/17 11:57 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
MC87SS Offline
MC87SS  Offline
Sorry guys don't know how i missed these.
Let me see what i can work out.
#1054922 - 12/20/17 10:35 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
JesusCPenney Offline
Fort Worth, TX
If you have any more of these available I'd like to grab one!
#1055543 - 01/29/18 03:10 AM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Fort Worth, TX
Just got mine! It looks great, packed very securely, and even came with directions. Thanks!
#1055896 - 02/14/18 01:17 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: JesusCPenney]
B5tmike Offline
B5tmike  Offline
Waynesburg OH
Do you have any steering shafts available?
#1056098 - 02/26/18 01:48 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
Torn151 Offline
Torn151  Offline
Borden,IN
#1056224 - 03/04/18 09:44 PM Re: Steering Shaft Upgrade (Better Then Jeep Shafts) [Re: MC87SS]
84WhiteTrashSS Offline
Kokomo IN
Do you still have some?
614/thumbs/2008_Trunk_Enclosure_Pictures_014.jpg
by StripedSS
500/thumbs/IMG_1007s.jpg
by Turbo5
1104/thumbs/375368_10200235155830020_977019592_n.jpg
500/thumbs/20200422_222519.jpg
by Rodney
500/thumbs/db_Latham_Greens_8-13_0261.jpg
by nymonte
