Page 2 of 2 1 2
#1055951 - 02/17/18 05:05 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
#1055961 - 02/18/18 08:02 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
maybe I missed something so refresh me : that pic above me, what spindle is that and brake set up onebadbowtie86 ?
#1055965 - 02/18/18 08:47 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
Stock modified spindle with the ls1 brake setup. only difference is I'm running the gto/c6 calipers.
#1055967 - 02/19/18 12:11 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: Onebadbowtie86]
What size rotor you have there?? 12"? I would like to run at least a 13" rotor but I also have the ATS spindles.
I'm selling the house and buying the new one soon. Then building my nicer garage about double the size I have now. I will buy a lift for sure this time, I'm done crawling on the floor!
#1055970 - 02/19/18 03:39 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
If you plan to run the C5 (C6/GTO should be the same size essentially IIRC) calipers with the 13” rotors you should be fine, per Year One when fitting the template from Kore 3 and also mondotti’s first hand experience. The only question is if the Year One wheels changed something over the years in how they are made that isn’t letting them clear. Marcus had experience where they didn’t, Year One as of last week says it works, we hopefully get confirmation from Year One that nothing, or nothing that physically changed on the wheels, to prevent them from working together.
If you already have ATS spindles, do you have the 17” N90’s too?
#1055977 - 02/19/18 01:48 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: PB86SS/87LS]
If
Yes I have both ATS spindles and the year one wheels.
#1055978 - 02/19/18 02:38 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
How long ago did you buy the Year One wheels?
#1055992 - 02/20/18 01:14 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: PB86SS/87LS]
I bought mine before they were released on a pre order special. So I have the very first production run made.
Kind of funny how long I have stock piled parts to build this car.
#1055994 - 02/20/18 02:53 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
Those are the 12” 98-02 Camaro brakes on my car, only difference is I’m using the 06 gto caliper instead of the Camaro.
Just send those 17” n 90’s I’ll let you know how they fit 😀
#1056013 - 02/21/18 02:02 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
So, do you know if that same adapter bracket will work on the jimmy/blazer spindles. ? And where did you get your adapter bracket ? BTW, I called Kore 3 today and was suggested that the 12.8''/C5 kit would work on the N90-17'' 4.25 '' back space rims with a 1/4" or 5/16" spacer.what you all think about using one if it were billet?
#1056018 - 02/21/18 03:00 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
I'll have to do some research to where I bought these brackets. I originally was going to do the c5 front brakes, I even bought the 2wd blazer spindles to do them but Tobin at Kore3 informed me that they wouldnt clear my wheels with out a spacer, probably alot like the n90. Thats why I ended up doing the slightly smaller ls1 camaro front setup.
Heres my thread from when I did the brake swap. It has the info from where I got the brackets.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=1019733&page=1
#1056027 - 02/21/18 02:21 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
And Year One confirmed the wheels will clear when using the template from Kore3 that is for that, C5 calipers and the 12.8" rotors. So much confusion laugh . At some point there will be a clear cut answer.
#1056030 - 02/21/18 08:38 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: PB86SS/87LS]
I'll sell my new N90 Wheels and tires Jason. I'm going with forged 18's.
#1056031 - 02/21/18 08:56 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: 1 Slow SS]
If Jason passes I might be interested.
#1056033 - 02/21/18 09:49 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: 1 Slow SS]
AkronAero Online content
AkronAero  Online Content
Which Forged 18's, we ask?
#1056037 - 02/21/18 10:31 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: 1 Slow SS]
I'd love to but I just spent my car money for the year on coil overs. If you have them next winter id buy them from you.
#1056040 - 02/21/18 11:46 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: Onebadbowtie86]
They aren't going anywhere.....I have one more car to wrap up before I start the Monte again.
#1056043 - 02/22/18 12:15 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: PB86SS/87LS]
axld Offline
axld  Offline
lakeland,fl
Well I am going to pull the trigger on the KORE 3 C5 12.8 kit. If I have to space it so be it. I have already bought the spindles .Next i am giving Marcus a call for the stage 2 arms/ kit .thanks everyone for helping me out , maybe see yang at Holly LS Fest!
#1056061 - 02/22/18 02:06 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
Sounds good. So you have the AFX/ATS spindles, KORE3's C5 brakes and will be running the N90's as well?
#1056069 - 02/23/18 12:59 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
all that except I have the jimmy/blazer spindles. once I order the parts ( I am in the middle of a engine build also ) I will mock it up and test it on the wheel. I will call Tobin tomorrow and get the ball rolling. I noticed I said "yang" which should have been ya'll. lol.
#1056194 - 03/02/18 12:27 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
Ok, KORE3 C5 kit is on the bench, my spindles are out for powder coat. Will be doing a mock up with my N90 wheels when they get back.
#1056195 - 03/02/18 12:30 AM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
Cant wait for pics!
#1056220 - 03/03/18 08:17 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
Well they fit with about 3/4" to spare between the caliper and rim, I am using blazer spindles [img]https://imgur.com/a/zFpwK[/img]
#1056221 - 03/03/18 10:32 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
Outstanding. Thanks for sharing the pic!
#1056452 - 03/18/18 12:44 PM Re: BIG BRAKE / N90 WHEELS 17'' [Re: axld]
axld Offline
axld  Offline
lakeland,fl
ok. installed the ZQ8 spindles with new moog hubs and the Kore3 kit. had to relocate the tabs for the braided lines ( used the stock self tapping bolts) . bedded in the pads , looks really good with the N90 wheels. Have new N555 G2's so going out today and hit some twisty roads . pics to follow.
Page 2 of 2 1 2
500/thumbs/mcttop.jpg
by javi05
568/thumbs/86whl12.JPG
by battz89
527/thumbs/88SS_clearmarker.jpg
852/thumbs/B_W.jpg
by PoorBoysRacing
500/thumbs/CAM00142.jpg
by JMonte7892
