#1055191 - 01/06/18 06:50 PM 17" tires
What brand of tire do you like in 17" ?
#1055193 - 01/07/18 01:48 AM Re: 17" tires [Re: Richie Cat]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
I'm running the Firestone Firehawk Indy 500 in 245/45-17 in the front and 255/45-17 in the back. They are summer tires. They really stick to the pavement like glue. But because they are summer tires, I have to put my Monte in winter sleep when the temp gets to about 40 degrees. I have driven on these tires for several years now and I do push them hard from time to time. I would recommend them to anyone looking for a summer performance tire.
87 SS, Harwood cowl induction hood, UMI trailing arms. Edelbrock TES Headers (Jet Hot Coated). GM Goodwrench 350, TPI & Trick Flow 56cc alum heads, SLP runners, ported plenum, Comp Cams 260AH-12 cam, Trick Flow 1.5 roller rockers, Bilsteins, TCI 2400 stall converter, Ramcharger fans, SLP ZR1 rims.
#1055194 - 01/07/18 03:39 PM Re: 17" tires [Re: Richie Cat]
Lots of choices with 17s, just depends on what you want the tire to do, Summer only to studded snows, and how much you want to spend.
I'm liking the BFG Comp 2 tires on the 86, an "Ultra High Perf Summer" tire that seems to wear good, good traction and is also good in those very few times I drive the car in the wet. Ran an autox in the rain recently and was surprised how well they did.
#1055196 - 01/07/18 06:19 PM Re: 17" tires [Re: Richie Cat]
Does anyone know of a RWL 17" tire?
#1055206 - 01/08/18 07:54 PM Re: 17" tires [Re: Richie Cat]
thepezking639 Offline
Livonia, MI
Bridgestone Potenza RE71R 245/45/17 all the way round. The Hankook Ventus V12 is also a good less aggressive choice.
#1055525 - 01/28/18 01:40 AM Re: 17" tires [Re: Richie Cat]
csmith4153 Offline
csmith4153  Offline
Mi
I have 245/45ZR17 BFG G-Force Sport Comp-2 on mine.
1983 Blue SS
1985 Black SS
1986 White SS
1986 Black SS
1987 Silver SS
#1055554 - 01/29/18 03:58 PM Re: 17" tires [Re: Richie Cat]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
I'm a 255/45 all the way around guy on an 8 inch wheel.
But your question was brand....right now I prefer Nitto 555 tires.
#1055677 - 02/06/18 08:25 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
200kSS, is your car lowered with that tire size and any rubbing? I have the 17'' N90 ( 8'' wide x 4'' backspacing) with 245/45 and need new rubber and would like to get as wide as I can .BTW, I have been studying ALOT of tires and am leaning toward at the Dunlop DIREZZA ZII for price and performance.( 200 tread wear)
#1055680 - 02/06/18 01:19 PM Re: 17" tires [Re: Richie Cat]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
Yes, the car is lower than factory height. B-body spindle swap up front and I honestly don't recall which springs are in the car as it's been together for 15 years now.
I also run the 17" N90 wheels (4.25 BS) and have no rubbing issues at all in the back, the front may rub slightly at full lock but I don't recall the last time I felt any rubbing even when parking.
In the past I've run a 275/40/17 on 4th gen Camaro SS wheels. Those did rub the front inner fender at full lock.
#1055682 - 02/06/18 02:15 PM Re: 17" tires [Re: Richie Cat]
popcorn
Following for others insight, I will be purchasing a new set of 17"s this spring sometime, 255/45/17 on a 17x8. Current 245/45/17 BFG Comp T/A's(I think?) are from 2002, tread is ok but think they've lived a long enough life that a combination of safety/stickiness at that age is my concern. And if all goes as planned might even be buying another set in the same size for later in the year as a wheel change/swap is on the horizon.
#1055705 - 02/07/18 02:34 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
well, I am running cooper zeon rs 3s ( 245-45) . the rear have about 7/32 tread left and this tires suck! .I spin from a dig or at 25 mph. I have been called out this week by a 1999 WS6 and had to turn him down I want to step up to a 255( 40 or 45 ?) sticky but best bang for the buck anybody?
#1055857 - 02/12/18 04:10 PM Re: 17" tires [Re: Richie Cat]
I just noticed Discount Tire Direct has some new rebates going on through 2/19, depending on which tire but for example the BFG g-force Comp 2's will get you a $75 gift card rebate with a full set. I was personally waiting for one of these deals this spring, they pop up from time to time but it's an incentive to buy.
#1055879 - 02/13/18 08:10 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
hey Fred SS, can you tell me the tread rating on those fire stones? I looked them up but did not have that info.
thanks. axld
#1055887 - 02/13/18 08:20 PM Re: 17" tires [Re: Richie Cat]
I found 340 AA for the Firestone Firehawks. I'm contemplating them myself, good reviews and nice price point too.
#1055894 - 02/14/18 08:08 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
thanks PB, my Cooper's have a 300 and do fairly well in some tight twisty's we have. from a dig no . 200ks, those Nitto's are they good for autocross style driving as well?
#1055895 - 02/14/18 12:35 PM Re: 17" tires [Re: Richie Cat]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
Resident autocross expert Lance started out with Nitto 555's but I'm sure he would recommend a better/stickier tire for full autocross performance. My brief experience autocrossing with them just reinforced how I need suspension and driver mods before worrying about high end tires. Also I'm more of a drag racer so I run Drag Radials on the rear of one car all summer.
I place the Nitto as a good all around tire. Yes you can autocross, have decent traction on dry surfaces and they work in the rain.
#1055911 - 02/15/18 11:30 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
ok thanks everybody for all informative info. I am going to try them, NITTO 555, I have spare rims to mount a DR for the drag strip.
#1055912 - 02/15/18 11:34 AM Re: 17" tires [Re: Richie Cat]
axld Offline
axld  Offline
lakeland,fl
oh and BTW, csmith your car has that perfect stance! could you tell me what you did ? can pm me if you prefer.
#1059810 - 11/12/18 12:38 AM Re: 17" tires [Re: axld]
csmith4153 Offline
csmith4153  Offline
Mi
Beltech drop spindles, and if I remember correctly (and my notes are correct) moog 5662 springs.
rear I used some rear springs from a late 80s Firebird GTA, I cut them till I liked the way it sat.
BTW, wish I would get notifications of replies.
1983 Blue SS
1985 Black SS
1986 White SS
1986 Black SS
1987 Silver SS
500/thumbs/Monte_Fuse_Blk.jpg
by ls1_monte
500/thumbs/Monte_Carlo5.jpg
by miker82
594/thumbs/100_0354.JPG
by Kyrik
500/thumbs/0725081719.jpg
by WhiteMonteSS
500/thumbs/DSC02786.JPG
by Joe87monteSS
Rob Forbes
techjay
