Page 1 of 3 1 2 3
#1054704 - 12/05/17 02:42 PM Turbo Monte 88 SS Build
beatboy77 Offline
beatboy77  Offline
Colorado Springs, CO
I was lucky enough to find a low mileage (28,000 miles) 1988 SS car from Texas a couple of months a go. No rust, other than just a very small amount on the corner of each door and scale underneath. The car has some very minor dents on the drivers side door, where it looks like someone leaned on the car consistently over the years. That is my guess any way. The paint is thin in a few areas from all of the years of polishing, as such it will need a re-spray. It also looks like one of the previous owners put 85-86 decals on it. I have to say, I actually like how those look better.
So being a child of the 80's, I always loved the look of the Maroon Monte Carlo cars from that time, however always loved the power of the turbo Buick Grand National. With this build I am going to try to combine the best of both of my likes. I am going to remove the 305 in the Monte and replace with a new crate engine 350 with twin turbos. Getting a new radiator and going with a 700R4 trans. Also getting new disc brakes all around and installing some lowering springs to drop the car 1.5" to 2". I am aiming to keep the rest of the car stock. The interior is immaculate and has never been smoked in. The original radio was at one point removed and replaced with a single DIN. I am going to replace that with the original looking RetroSound NEW-264-269-660, only with modern technology like Bluetooth, etc.
Here is how she sits as now
Josh
#1054705 - 12/05/17 04:23 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Looks like a great starting point, clean car! Interesting choice to use the 85/86 decals by the PO, looks like it had headlight covers at one point too.
#1054706 - 12/05/17 04:33 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Welcome to the board.
Looks good, and sounds like a plan!
#1054708 - 12/05/17 08:56 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
thepezking639 Offline
Livonia, MI
Nice clean car. Good luck with the build.
Unless you're hellbent on a 350 for nostalgic 80's reasons, I'd strongly suggest you look into a 6.0L LS based motor with a 4L80e.
In the case of forced induction you'll be in a much better starting point cost wise with an LS based motor. 9.4-1 compression, aluminum heads. Fuel Injection from the factory.
Even if you do decide to go with a 350, for the power levels you'd be looking at twin turboed, a 700R4/4L60 is not the trans you want for those power levels.. 2-3 shift will be mush at WOT. even rebuilding the stock 200-4r for power is a better choice.
#1054711 - 12/06/17 01:39 PM Re: Turbo Monte 88 SS Build [Re: thepezking639]
beatboy77 Offline
beatboy77  Offline
Thank You for the advice. I am using the 350 as I have it on hand and purchased for an amazing price. Also there is a little 80's nostalgia there too, as this car is built in a way I wish GM would have made a Monte to compete with a Grand National back at that time. I chose the 700R4 as I have one on hand and it is being re-built currently. We have a Good shop in town which does this and we are having him re-build using the heavy duty option he offers. I will try it and if over time this trans annoys me, I will try something different.
Josh
#1054713 - 12/06/17 03:00 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Don't forget to keep the stock parts, that's a clean survivor and you might want to go back to stock some day. Stock and original is generally worth more when you sell.
BTW, those door dents are from a someone using their body to close a partially shut door. Stubborn door closing is often caused by sagging hinges which causes a misalign at the door striker. Then some fat ash tries to close the door all he way by pushing on the door panel. Shameful abuse by careless people. My car had those dents too.
#1054714 - 12/06/17 06:30 PM Re: Turbo Monte 88 SS Build [Re: upflying]
Witness86SS Online content
Witness86SS  Online Content
Hatfield, PA
my kids keep trying to make those dents. No you don't need a running start to close the door...
Justin
1986 Black SS
#1054722 - 12/08/17 12:30 AM Re: Turbo Monte 88 SS Build [Re: beatboy77]
tigerss Offline
tigerss  Offline
greensboro nc
Nice car
I prefer the 86 stripes so I might consider that option when I repaint my 88. It does hurt my brain a little to think of 86 stripes on an 88 though.
I think its more weird he swapped stripes on a sub 30k car more so then that somebody would change them.
#1054726 - 12/08/17 02:55 AM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
As we wait for parts to come in, we started to sand it down and prepare for the re-spray today
#1054728 - 12/08/17 05:07 AM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Very nice pallet to start with.
As you prep the car for paint don't forget it's lacquer originally.
#1054738 - 12/09/17 12:02 AM Re: Turbo Monte 88 SS Build [Re: beatboy77]
gmachinz Offline
gmachinz  Offline
Des Moines, Iowa
Umm...wait a minute-how bad was the OE finish? I'm surprised you "getting at it" paintwise when it looked pretty damn good in the pics you posted.
gbodyparts1234@yahoo.com
HARNESSWORX
#1054742 - 12/09/17 01:33 PM Re: Turbo Monte 88 SS Build [Re: gmachinz]
beatboy77 Offline
beatboy77  Offline
Not Great and there we several small dents throughout, especially on the doors. Speaking of the doors, there were some small rust spots on the corners, about the size of nickel as well. I want to fix those properly.
Josh
#1054743 - 12/09/17 01:34 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Continued sanding today. Making progress
#1054745 - 12/09/17 03:33 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Got to ask. Is that a chopped 49 Merc in the background?
#1054747 - 12/09/17 05:18 PM Re: Turbo Monte 88 SS Build [Re: Richie Cat]
beatboy77 Offline
beatboy77  Offline
It is a 51 with a 49 window
#1054778 - 12/12/17 01:34 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
And More Sanding.....lol
#1054889 - 12/19/17 01:12 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Continuing to sand and prep. Needed just a little filler on pillars at the factory weld seam. Also just a touch in a couple of spots on the lowers doors where some minor rust was repaired. This car is remarkably clean for a 29 year-old car. I guess that makes sense since it is from Texas.
#1054890 - 12/19/17 01:14 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Got the engine and trans out. The intercooler also arrived.
#1054910 - 12/19/17 11:02 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Making quick work of it! You've done in 2 weeks what I would have done in 2 years smile
#1054943 - 12/22/17 03:01 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Finally finished sanding and prep. Then primed.
#1054944 - 12/22/17 03:04 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Radiator and Intercooler painted
#1054945 - 12/22/17 03:07 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Basic mock up of the Twin Turbo 350 going in the car
#1054947 - 12/22/17 06:29 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
Can you give us some info on the engine build? Also the exhaust "headers" and turbos? Being it's a mock up is this a dummy engine also?
#1054965 - 12/23/17 10:39 PM Re: Turbo Monte 88 SS Build [Re: beatboy77]
84ss355*4spd Offline
Edmonton,AB,Canada
Good job.tjat motor looks like would be fun . Keep the pics coming
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1054970 - 12/24/17 12:47 AM Re: Turbo Monte 88 SS Build [Re: beatboy77]
beatboy77 Offline
beatboy77  Offline
Time for a "Block Party!". Started to block it today. Found a couple of small areas which will need some attention. Other than that, all is coming along nicely. After blocking, we are going to strip the engine bay and re-paint that. Then install the engine before final paint.
Page 1 of 3 1 2 3
548/thumbs/Exhaust_Hooker_Headers.JPG
by 84supersport
618/thumbs/front_angle.jpg
by Wisconsin
1189/thumbs/PS_Door2.jpg
by Joe87monteSS
500/thumbs/HPIM1398.JPG
by Kyle82757
888/thumbs/monte_SS_2_1.JPG
by SSCopperhead
Rob Forbes
techjay
