#1053008 - 08/20/17 12:01 AM LS Swap Dragstrip results
thepezking639 Offline
Livonia, MI
13.27 @ 107 and I beat a Hellcat owner who didn't know how to launch.
86 SS 6.0L LQ4, TBSS GEN IV intake, 92mm TB, 30lb injectors, LS3 cam and valvesprings, stainless long tube headers, Microsquirt ECU, Built 200-4R, B&M Megashifter, Torsen LSD, QA1 Lvl 3 Suspension Kit, UMI Front & Rear Braces. Check out my build thread: http://www.pro-touring.com/threads/126188-SSLOW6-0-Build
#1053009 - 08/20/17 12:15 AM Re: LS Swap Dragstrip results [Re: thepezking639]
Very nice! What are your specs again?
#1053010 - 08/20/17 12:18 AM Re: LS Swap Dragstrip results [Re: Hunter79764]
Livonia, MI
6.0L LQ4, TBSS intake 92mm TB, 30lb injectors, LS3 cam and valve springs, Ebay 3/4 inch primary long tubes with a 3 inch collectors, to the 2 1/4 inch garbage exhaust and mufflers, controlled by a Microsquirt. I have a built 200-4r and run a 3.73 gear with a worn out posi. For tires I was on a 245/45/17 Bridgestone Potenza RE-71r. The car is set up to autocross with a full QA1 level 3 kit.
#1053011 - 08/20/17 02:01 AM Re: LS Swap Dragstrip results [Re: thepezking639]
Congrats, theres a lot more in it also! My ls2/6 speed ran 7.50 and 96.25 mph last spring in the 1/8th. What was your 1/8 mile times/speed? 60'?
#1053013 - 08/20/17 02:12 AM Re: LS Swap Dragstrip results [Re: thepezking639]
Jason, you had a little advantage on him, tires?
Travis, sweet, as Jason said there is lot more to be had. getting to the other end of the track before a Hellcat, priceless.
Glad you got heat in that engine, keep tweaking.
#1053015 - 08/20/17 03:06 AM Re: LS Swap Dragstrip results [Re: Onebadbowtie86]
Livonia, MI
RT .471
60ft 2.164
1/8th ET 8.756
1/8th MPH 85.16
1/4 et 13.279
1/4 mph 106.98
Car leaves pretty soft or roasts the tires. Needs some time on the dyno to get the motor dialed in. Still at 13.2 AFR at WOT under load. Needs slicks, an 8.5 or 9 inch rear, a corner balance and to set the pinion angle correctly.
#1053024 - 08/21/17 12:02 AM Re: LS Swap Dragstrip results [Re: thepezking639]
Tires alone will put you into the 12's. Running an auto, you may be suprised how long the stock rear will hold up even with slicks. I ran my stock rear into the 7's in the 1/8th with a manual, and know quite a few guys who have been faster then that/still running one. A bigger rear is money well spent though.
#1053225 - 09/05/17 02:26 AM Re: LS Swap Dragstrip results [Re: thepezking639]
jmireles Offline
jmireles  Offline
El Paso, Tx
Congratulations, very impressive! I have yet to take my SS to the track...I have yet to get it on a dyno too. wink
in '08. 3K
#1053348 - 09/11/17 07:07 PM Re: LS Swap Dragstrip results [Re: mmc427ss]
Small town USA
Getting to the other end of the track before a Hellcat, priceless.
He'll need quiet a bit more motor. Hell cats can run high 10'S stock with tires. My bone stock challenger scat pack will knock down high 11'S.
Ron.
#1053350 - 09/11/17 07:48 PM Re: LS Swap Dragstrip results [Re: 1 Slow SS]
Livonia, MI
Ron.
Not at Lapeer dragway it won't lol. The track is garbage. My friends with fast cars (sub-10 second) wont run there because the surface is bumpy and the prep is almost non-existant.
This was just a couple of friend with street cars seeing what they could do.
#1053382 - 09/13/17 05:46 PM Re: LS Swap Dragstrip results [Re: thepezking639]
Ran what I thought was just a Challenger at the track two Fri ago, it ran a 19.8 with a 4.4 sec 60', HUGE cloud of smoke he left at the tree. Got back to the lanes and looked at his car, damn, I beat a Hellcat. He screwed up the launch programming and fried the tires. They had to sweep up after him it was that bad.
#1053912 - 10/17/17 08:59 AM Re: LS Swap Dragstrip results [Re: thepezking639]
axld Online content
axld  Online Content
lakeland,fl
nice, btw, what converter did you use to mate to the LQ4? ( I bought a early long flange and was told it would not work with my 4L60E with out a custom converter ).
86 SS 5.3/4L60E. custom paint-17'' N90 wheels -quick 9'' - custom dyno tune- UMI/BMR suspension- Headman mids with x pipe -and a lot of other $ parts.
#1053913 - 10/17/17 12:27 PM Re: LS Swap Dragstrip results [Re: axld]
Livonia, MI
I run a 200-4r and I used a flex plate spacer to help it meet. I have a stock ish patriot? 2200 converter
If you have a long flange crank you need a an early 4l60e. You might get away with a 4.3l bell housing? I'm not familiar with 4l60e's other than they break if you look at them wrong.
#1053996 - 10/22/17 12:12 PM Re: LS Swap Dragstrip results [Re: thepezking639]
axld Online content
axld  Online Content
lakeland,fl
lol, you got that right! I pulled the trigger and bought a LQ9 style crank. Planned on upgrading to a level 3 trans with this new 6 .0 build. looking back now I should have went with a stick like I originally had planned with the LSX swap. thanks.
#1054088 - 10/26/17 09:17 PM Re: LS Swap Dragstrip results [Re: thepezking639]
Ahh, I should have seen this earlier... I've got a 4L60e that was a 99 model used in a van with a 350, meaning the bellhousing would work to mate a later case with the earlier crank spacing, I believe... It's currently installed in a car, but it's about to come out in a week or so. If you have a new crank, problem solved though. Good luck.
500/thumbs/84-brad.jpg
by 1984Monte
1132/thumbs/256.JPG
by CashMoneyMotorsports
862/thumbs/control_arm.jpg
by 02intimidator
500/thumbs/After_Bath.jpg
by The New Kid
by mikeasis
