#1053393 - 09/13/17 11:36 PM Gauge Pod
Crusher Offline
Crusher  Offline
Jersey Shore
I need the gauge pod that bolts to the dash and holds the gauge cluster and headlight switch. Headlight switch mounting points need to be intact and not stripped. I also need the radio/heater bezel for an 86/88.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
http://SSMonteCarlo.com
#1053410 - 09/15/17 02:02 PM Re: Gauge Pod [Re: Crusher]
Kevin, new radio/heater bezels are available from Mikes.
As far as the gauge pods go you'll find it's very hard to locate one that doesn't have some, or multiple bosses /screw holes that aren't broken. The ABS plastic over time deteriorates, become soft. You can glue the bosses with a model car ABS cement such as PlasTruct or Tamiya ABS cement. They can be found at hobby shop stores. I keep at bottle of PlasTruct on the work bench.
On the bosses that are really broke apart you can epoxy a screen mess around the boss and this will reinforce it prevent it from falling apart again.
My current cluster has about 10 repairs done to it, none visible, Have about 6 clusters in a box and they all are in some state of broken bosses.
As far as the headlight switch bosses you can repair that with the screen/epoxy method and then install a metal headlight switch bracket from Mikes.
http://www.mikesmontes.com/86-88-Headlight-Switch-Bracket-Free-Shipping_p_2614.html
#1053421 - 09/16/17 11:57 PM Re: Gauge Pod [Re: Crusher]
Crusher Offline
Crusher  Offline
Jersey Shore
I'm aware the bezels are available. I'm looking for a used one to experiment with for mounting two gauges in it so don't want to buy new. Thanks for the info on repairs. Hopefully I can find one that it is pretty good shape.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
#1053438 - 09/18/17 04:49 AM Re: Gauge Pod [Re: Crusher]
Are you in need of the radio/heater bezel or cluster? I'll look through what I have and see if there is a donor cluster you can destroy.
#1053439 - 09/18/17 12:26 PM Re: Gauge Pod [Re: Crusher]
Crusher Offline
Crusher  Offline
Jersey Shore
Radio heater bezel. 86-88 style. Are you talking about the gauge cluster? If so, then no. I need the bezel and a gauge pod.
1988 502/502
ProCharger SC
Fast XFI Fuel Inj.
564 RWHP 574 TQ
by donzss
519/thumbs/DSC00025.JPG
by Ted88SS
500/thumbs/Monte_trunk1.jpg
by nickg
500/thumbs/motor.jpg
by NYmonteSS
500/thumbs/SS_grill_new.jpg
by IowanSS
Rob Forbes
techjay
