#1053341 - 09/11/17 02:38 PM 1987 Monte Carlo SS - Part Out
Picked this one up a few weeks ago, mostly stripped with a little left to go. Another rust bucket, body/shell is shot, frame is solid. Had centerlines all around and a fiberglass cowl hood (seller kept the hood and the front wheels, rears are stuck on yet), was probably setup this way with the red paint(originally maroon) in the 90's and pretty nice looking back then. Engine cranks ok but doesn't start, didn't put much time looking into it, car sat for the last 10 years due to a no spark issue, according to the owner.
I won't be selling any sheet metal, either bolt on parts due to rot issues (not worth it) nor am cutting anything apart from it.
L69 (assumed, not verified it's original yet), cranks but non running, minus intake/carb/accessories - $50
Engine accessories, manifolds, carb - Inquire
200-4r, CZF code, fluid looks good but unsure of condition (assumed but not verified yet D5 convertor) - $250
Driveshaft - $20
3.73 non posi rear - $150
Fan shroud - $100
ECM harness, intact, no damage - $75
Engine harness, intact, no damage - $75
Radiator, Modine copper/brass original style unit, appears good - $50
Complete A/C setup from condensor to A/C controls, high pressure line is damaged - $125
Steering box - $60
Sway bar set - $50
Jounce bars - $25
Stock air cleaner complete from bracket on core support, duct, and cleaner, cleaner is a little rusty - $40
SS front end/nose setup complete, front cover has some damage - $200
Laydown spoiler, very nice shape - $125
1/4 Glass set - $50
Front & Rear window black trim (3 pieces) - $40 each set
Side mirrors, both remote and good shape - $75/pair
Rear bumper cover and plastic supports, passenger side has some damage - $75
Left tail light with housing, pretty good shape - $80
Right tail light with housing, lower of lens chipped - $50
Rear license pocket with lights - $50
Bucket seats, tracks good, seats fair - $150
Lower rear seat - $20
Carpet - $20
Door panels, power windows/manual locks - $100
A-pillars - $30
B-pillars - $30
Visors(no mirror option) - $20
Maplight (87/88 option) with complete wiring to fuse box - $25
Power window regulators/motors and all wiring/switches complete and working when pulled - $100
Seat belt set, rears have some rust - $50
Brake light with wiring/bracket - $30
Steering column, tilt/cruise/delay w/key - $125
SS steering wheel with cap - $50
Dash, one large crack, good tabs - $50 (if no other damage after removal)
Cluster and console/shifter aren't available, there are plenty of small items I didn't list, if you are interested in anything I didn't list or mention, feel free to inquire via PM or post.
Not interesting in shipping large parts but may consider it.
Buyer to pay all shipping costs. Located near Milwaukee, WI.
-87'LS 350 MAF/SD TPI- CRF2004r-7.5" 3.42 -248/340@RW - 14.55 @ 96
#1053343 - 09/11/17 04:25 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Witness86SS Online content
Witness86SS  Online Content
Hatfield, PA
Paul's new Monte of the month =)
Your neighbors must think you are a nut.
Wish you lived a thousand miles closer
Justin
1986 Black SS
#1053345 - 09/11/17 04:35 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
It's been a busy year with this stuff, looking forward to a break in many ways. Neighbors haven't complained or given me any looks (yet) and we are spaced apart enough and where the car(s) sit outside, when they are outside, isn't obnoxiously visible. And I usually cover them since they aren't exactly a thing of beauty laugh .
#1053364 - 09/12/17 05:03 AM Re: 1987 Monte Carlo SS - Part Out [Re: Witness86SS]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
^^^^^^^^That!
The dash looks quite good. Better than mine, which due to the Florida sun is covered in cracks. Even a dash cover doesn't cover them all frown
1986 Monte Carlo SS
#1053365 - 09/12/17 12:17 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
The dash has one large crack but that was it, then one of the top 7mm screws was spinning, so upon removal a little more damage occured around it. It's better than the other cars I've parted for sure and maybe useful to someone but not crack free. Would be a pickup only type thing.
#1053387 - 09/13/17 08:04 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
You just trying to take all my pocket change. Would you take a pic of the maplight and wiring
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1053390 - 09/13/17 09:22 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Haha.
Once I finish removing it this weekend I'll get you a pic. Finish removing the dash and wiring behind it is one of the last and next things to do.
#1053401 - 09/15/17 12:39 AM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Zach Offline
Zach  Offline
Lawrenceville, GA
What size is the sway bar set ? Interested in that and steering wheel
Also steering box and pitman arm 30519
First car I bought was an 88 Mc ls when I was 16 been in love every since. Currently running 82 Mc cl with holley sniper efi 200-r4 4:10 gears work in progress
#1053408 - 09/15/17 07:06 AM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Steering box would be $60 plus shipping, they fit in a large flat rate box, so $79 total.
Steering wheel is $50, shipping would be about $20.
Bars are 1.25" in front, not sure on rear off hand. I shipped a set before by tying/wrapping them together, would be $75 shipped for those. Unfortunately due to their sizes/weights combining shipping isn't really an option.
#1053409 - 09/15/17 12:20 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Derrick Offline
Derrick  Offline
beaver Dam WIsconsin
3/4" is the rear sway bar if I remember
1985 Monte Carlo SS
1985 Grand National
#1053413 - 09/16/17 01:02 AM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
AllenMH Offline
AllenMH  Offline
I'm interested in the rear license pocket. How much would shipping be to 21754? The plastic snapped off mine where one of the license plate brackets screws in over the weekend when I was getting gas, need to get one of the stay down plate holders soon in the future.
#1053415 - 09/16/17 04:01 AM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Looks like $18 to ship it, so $68 total
No damage just normal wear and one spot the black rubbed off from maybe the trunk lid.
#1053418 - 09/16/17 11:38 AM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
AllenMH Offline
AllenMH  Offline
Pretty sure I'll take it, can you send me a picture?
#1053419 - 09/16/17 02:13 PM Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Will send a PM soon
#1053475 - 23 hours ago Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Lalo8889 Offline
Lalo8889  Offline
Corsicana, TX
I'm interested in the front bumper and the spoiler, how much for shipping to 75110
#1053476 - 23 hours ago Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Selling the front end all together, if still interested let me know.
#1053477 - 22 hours ago Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Lalo8889 Offline
Lalo8889  Offline
Corsicana, TX
Can you send me a picture of where the front cover has the damage
#1053489 - 10 hours ago Re: 1987 Monte Carlo SS - Part Out [Re: PB86SS/87LS]
Here are pics.
I am willing to ship the entire setup, would have to go Greyhound though.
500/thumbs/DSC_0016.JPG
by wanadrv
530/thumbs/Trunk13.jpg
by Phoenix
500/thumbs/Copy_of_DSC00109.JPG
by Aeroaddict
500/thumbs/engine31.JPG
by mightymonte10
500/thumbs/monte34.JPG
by JeffNKarolynss
Contributors this
Past Month
notsocleaverusername
