#1053166 - 09/01/17 06:24 PM Converting '88 CCC distributor to HEI-Wiring Q
Diamond Dave Offline
Livonia, MI
I have a 1988 MCSS that I plan to de-computerize with a non-CCC Quadrajet and HEI distributor. All of the emissions equipment had been removed from the car before I bought it and the carburetor needs to be rebuilt, badly, so since I'll be messing around anyways, I'd like to clean up the engine bay and simplify tuning and troubleshooting.
My question is how to wire up the new HEI. My car is an '88 so it has an external coil and smaller distributor cap as opposed to the typical "large cap" HEI with internal coil.
As you can see, there's a fairly thick pink and white wire running from the main harness to the coil, and then thinner pink and white wires from the coil to the distributor. Would I simply splice the heavier wires (currently going from main harness to the coil) to a pigtail for the HEI battery/tach wires?
Is there a way to do this without cutting up the harness? I plan to keep all the CCC stuff in case I ever want to go back to stock.
I read the sticky and didn't see this covered.
Thanks in advance.
#1053172 - 09/02/17 03:43 AM Re: Converting '88 CCC distributor to HEI-Wiring Q [Re: Diamond Dave]
to start with, it's already HEI, why not get the carb repaired, I have the perfect place, www.customrebuiltcarbs.com I've had two E4ME carbs done there and they both were basically bolt on and go, click on my link and give the place a call, the owners name is Phil and he answers the phone and good luck!!
#1053183 - 09/02/17 05:48 PM Re: Converting '88 CCC distributor to HEI-Wiring Q [Re: Diamond Dave]
88ss408 Offline
88ss408  Offline
miramichi, NB
See the big pink wire there. That's your power wire that you need to put the the HEI. You need to change the terminal on it. Just crimp a spade on it or get the proper one from summit. Many companies make them.
1988 monte carlo ss 408 sbc 11:1 compression a.f.r.195cc heads accel ignition system comp cams .507/.510 air gap intake 800cfm edelbrock carb th350 trans 3000 stall torque headman headers 3" dual super 40's 3.73:1 limited slip
1984 monte carlo cs 400,headers,th250c,air gap intake
#1053339 - 09/11/17 02:16 PM Re: Converting '88 CCC distributor to HEI-Wiring Q [Re: Diamond Dave]
DLV555 Online wavey
DLV555  Online Wavey
Findlay, OH USA
It's very simple, Yes, just splice those wires from the main harness with a new connector and connect it to the new coil. Summit, Jegs, and Speedway all sell the pigtail connector to make it a quick swap. I think Accel makes the connector. It's pretty cheap. HOWEVER, as Leo said, stick with the computer and the CCC Q-Jet and HEI if you can. For one, you've already got them, and two, they work great. Only heavily modded motors with low idle vacuum really need to ditch the computer.
500/thumbs/IMG_8474.JPG
by Elco86
525/thumbs/HighwayMike.jpg
500/thumbs/65d4cdae779619484573c9a50b577d100_large.jpg
by crazyhorse1983ss
523/thumbs/DSC_0624.jpg
500/thumbs/Wheel.jpg
by RocknSS
Rob Forbes
techjay
