#1051625 - 06/20/17 09:50 PM 1984 Monte Carlo SS
steve40 Offline
steve40  Offline
Windsor, Ontario
1984 Monte Carlo SS - Protouing/G-machine build
Car has power steering, power brakes, all power options from the SS are still intact and working (Locks, Windows and Trunk release)
6.0 iron block LS
- forged rods and pistons, stock crank
- ported LS3 heads and intake with 90mm throttlebody, Tick Performance Cam
- ARP hardware in bottom end and head studs
4L80e transmission
- mild build with Transgo HD2 shiftkit
Quick performance 9" rear end
- 3.50 gear with Tru-trac posi
- welded on lower control arm relocation brackets
Brakes
- upgraded booster and master cylinder
- Corvette C6 front brakes
- LS1 F body rear brakes with working parking brake
Suspension
- Ridetech coilvers on all 4 corners
- Ridetech front upper and lower arms, front sway bar and bump steer kit
- UMI double adjustable upper and lower rear arms
- UMI rear sway bar
Wheels/tires
- Boss motorsports 338's in gray and polished lip
- BFG tires
Interior
- Dakota digital gauge setup (working functioning lights like a modern car)
- Modified late 2000's Impala console swap (original comes with car as well)
- Hinges, seals, door handles are all redone
- Relay kit added to power windows
- Mike's Montes anti rattle kit installed on both windows
I have a ton of pictures from the build of the car. It was torn down to a bare frame and redone all the way back up. Everything is new, as in brake lines, fuel lines, tank and pump, mounts/bushings, bolts, etc.
I have approximately 3200 km on the car since running. I'm also willing to sell the car as a rolling chassis.
I forgot to mention I have another used gm front fascia that comes with the car.
Looking for 17,000 cdn or $13,000 usd obo
Car is in Windsor, Ontario
#1051626 - 06/20/17 09:51 PM Re: 1984 Monte Carlo SS [Re: steve40]
steve40 Offline
steve40  Offline
Windsor, Ontario
#1051627 - 06/20/17 09:52 PM Re: 1984 Monte Carlo SS [Re: steve40]
steve40 Offline
steve40  Offline
Windsor, Ontario
#1051628 - 06/20/17 09:52 PM Re: 1984 Monte Carlo SS [Re: steve40]
steve40 Offline
steve40  Offline
Windsor, Ontario
#1051685 - 06/22/17 06:09 PM Re: 1984 Monte Carlo SS [Re: steve40]
tigerss Offline
tigerss  Offline
greensboro nc
Do you have familiarity with buying/selling between us and canada? I love this car. Wow.
#1051706 - 06/23/17 11:29 AM Re: 1984 Monte Carlo SS [Re: tigerss]
steve40 Offline
steve40  Offline
Windsor, Ontario
I have asked a friend that knows a broker with this experience. He was going to look into it for me.
I'll post up what I hear back
#1051729 - 06/23/17 08:57 PM Re: 1984 Monte Carlo SS [Re: steve40]
steve40 Offline
steve40  Offline
Windsor, Ontario
#1051816 - 06/26/17 03:09 PM Re: 1984 Monte Carlo SS [Re: steve40]
BStewart84SS Offline
Myrtle Beach, SC
That center console looks great. How much modding was needed to make it fit like that? very nice car you have there. I don't imagine it will take long to sell.
400sbc, TH350 w/shift kit
#1051824 - 06/27/17 12:28 AM Re: 1984 Monte Carlo SS [Re: BStewart84SS]
steve40 Offline
steve40  Offline
Windsor, Ontario
I think it was a 09 Impala, its definitely a later 2000's Impala. Most of it was just test fitting and cutting more off as you go. There is a console thread on this board where I got the idea, some good pictures show you what you have to cut off.
Thanks, hopefully, being in Canada slows it down a lot.
#1051840 - 06/27/17 02:21 PM Re: 1984 Monte Carlo SS [Re: steve40]
mclellan83 Offline
mclellan83  Offline
Pittsburgh, PA
Very sharp car, has a lot of the stuff that mine has or is going to have done.
84 SS 350sbc bored .40 over, cammed, roller rockers, and air ride
#1052621 - 07/28/17 09:06 PM Re: 1984 Monte Carlo SS [Re: steve40]
steve40 Offline
steve40  Offline
Windsor, Ontario
sold........
527/thumbs/88SS_console2.jpg
500/thumbs/Monte_Drop_Spindles.JPG
by 85RESTOSS
876/thumbs/monte_44.jpg
by inkandsteel
563/thumbs/m_e87d10911a421002c5bb2deaae4fa6d0.jpg
by WhiteMonteSS
500/thumbs/side3.jpg
by mdecker211
Rob Forbes
techjay
