#1052328 - 07/16/17 01:45 PM Rear end gearing
ray6914 Offline
ray6914  Offline
pittsburgh pa
I have a 84 Monte Carlo SS Street car 350 bored 40 over with a automatic turbo 350 3-speed transmission with a 2400 stall converter looking for recommendation on gear ratio it's a 10 bolt I believe it has 342 gears in it right now
#1052330 - 07/16/17 02:15 PM Re: Rear end gearing [Re: ray6914]
tedgley Offline
tedgley  Offline
Covington, KY
What's wrong with what you have in it now? 3.42 isn't a bad all around gear.
#1052331 - 07/16/17 02:48 PM Re: Rear end gearing [Re: ray6914]
3.42 is fine with a non-OD trans like the TH350. You don't want to lose MPG and increased engine wear with lower (higher numerically) gears.
#1052418 - 07/19/17 12:23 AM Re: Rear end gearing [Re: ray6914]
TooSlow406 Offline
TooSlow406  Offline
Friendswood, TX
I agree too, as long as you're looking for MPG. You could even go 3.55s, but that a lot of work just to go up 1 size. But if you really want performance and don't care so much about the cost
of fuel, go 3.73s. If you ever get a OD, those would still be good or you could go up to 4.10s like I have. That being said, it's a lot of road noise with that low of gear.
500/thumbs/84-brad.jpg
by 1984Monte
1132/thumbs/256.JPG
by CashMoneyMotorsports
862/thumbs/control_arm.jpg
by 02intimidator
500/thumbs/After_Bath.jpg
by The New Kid
by mikeasis
