Page 2 of 2 1 2
#1051811 - 06/26/17 02:10 PM Re: New member's SS [Re: tedgley]
Those are some tall/meaty looking tires, the car looks good. Rubbed the wheel well all the way through and into the e-brake cable, wow.
Lance is really close, stock size is 215/65/15.
I also wanted to chime in that Photobucket is extremely annoying and feels pretty junky at this point. Transferring all of my photos from there to Imgur seems daunting but might be worth the effort.
#1051815 - 06/26/17 03:05 PM Re: New member's SS [Re: tedgley]
I run a 5" backspace rim and my tires just touch the sway bar and frame at full lock. I would think a 4" backspace rim would be fine, pretty sure stock rims are 4.25: back space. There are other factors involved though, alignment, camber and caster settings all affect where the wheel sits in regard to the frame.
#1051831 - 06/27/17 10:19 AM Re: New member's SS [Re: SSLance]
tedgley Offline
tedgley  Offline
Covington, KY
What is a good alignment setup? I am thinking maybe -0.5 camber, 2.0 caster, and maybe 1/16 toe in.
#1051838 - 06/27/17 01:42 PM Re: New member's SS [Re: tedgley]
Well... laugh That depends...
I currently run about -1.75 camber, +9.75 caster and zero toe and I love it. Your results may vary though and it does take some work to get that much caster out of a stock G body spindle. If you try to get that much caster with a drop spindle, your tire will be into the rear fender well pretty badly.
#1052271 - 07/14/17 12:52 PM Re: New member's SS [Re: tedgley]
84ss355*4spd Offline
Edmonton,AB,Canada
Those tires are the issue for sure. Tall tire with a drop .tire is sitting close yo the wheel well as it sits.
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1052329 - 07/16/17 02:02 PM Re: New member's SS [Re: 84ss355*4spd]
tedgley Offline
tedgley  Offline
Covington, KY
There have been a few comments about these tires being tall. And I have asked if I can run 8" rims with P245/60R15 in the front and P255/60R15 tires in the rear. Wouldn't that wheel/tire combination be pretty much just as tall as the ones I have on there now?
At this point, I'm not sure if anyone has really said whether I can run this wheel/tire package without cutting the frame and/or rolling the fender lips or that I would be fighting a losing battle. If I can run them, what changes will it take to do it?
#1052739 - 08/04/17 02:38 AM Re: New member's SS [Re: SSLance]
merky45 Offline
merky45  Offline
Hinesville, GA
Sounds a good alignment set up. What tires you have? One buddy here got another 1985 Monte Carlo SS and he's looking for either Goodyear or Toyo tires as he got them on his trucks.
Page 2 of 2 1 2
500/thumbs/84-brad.jpg
by 1984Monte
1132/thumbs/256.JPG
by CashMoneyMotorsports
862/thumbs/control_arm.jpg
by 02intimidator
500/thumbs/After_Bath.jpg
by The New Kid
by mikeasis
