#1051573 - 06/19/17 01:14 AM Junkyard 17" rim options?
Are there any easy options for cheap 17" rims? The front rims from GTA's fit, right? What about any steel rims from something else? S10? Spare tire rims? Something I can scrounge from the U Pull It yards or Craigslist for $30 each or something.
My 14's are getting long in the tooth and short in the tread, eventually I want to end up with magnum style 17's (link below), but budget won't allow new wheels and tires at the same time. I might have a chance of upgrading if I can get cheap 17" wheels and new tires, then run those until I can buy the rims I want. Otherwise I need to buy a couple tires for the 14's which are getting more expensive and aren't helping performance in the least...
https://www.yearone.com/Product/wheels/cmws1
#1051581 - 06/19/17 03:10 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
PB86SS/87LS Online beer
PB86SS/87LS  Online Beer
GTA's are 16"s, 17"s didn't start until somewhere in the 4th gen f-body years, that would probably be the cheapest way to go or Vette rims (?). But looking for used rims aftermarket or oem might get you some deals on various styles in that size too, depending how picky you are on style and condition.
#1051582 - 06/19/17 03:31 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
What Corvette rims fit off the shelf? C4 fronts, I'm guessing? I'll look at the later F body rims and see what's what on those. I might be able to scrounge those from the local yard. I'm not too picky on style, if anything uglier rims will get me more motivated to get money together to buy the rims I want...
#1051585 - 06/19/17 06:09 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
88ss408 Offline
88ss408  Offline
miramichi, NB
I know the w body montes and impalas came with 17s 07 a day up I think. Not sure of width or back space though.
1988 monte carlo ss 408 sbc 11:1 compression a.f.r.195cc heads accel ignition system comp cams .507/.510 air gap intake 800cfm edelbrock carb th350 trans 3000 stall torque headman headers 3" dual super 40's 3.73:1 limited slip
1984 monte carlo cs 400,headers,th250c,air gap intake
#1051586 - 06/19/17 06:19 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
I've seen this style of C3 Corvette alloys fitted on all four corners of a 3rd gen Monte SS. Only come in 15" though. Nice looking wheels!
1986 Monte Carlo SS
#1051589 - 06/19/17 07:18 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
I don't know a lot about Vette wheel specs or b-body, I think b-bodies generally are 5x5 bolt patterns though but could be mistaken.
Browsing the Turbo Regal forum and saw this, in TX, so thought I'd share. Not cheap but for all that's included and possible wiggle room, might not be a bad deal: http://turbobuick.com/threads/17-wheels-with-new-tires.451411/
#1051591 - 06/19/17 07:34 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
200kSS Online goatee
200kSS  Online Goatee
Bloomsdale, MO
And I would love to have those drag radials off the rear wheels. It's a shame shipping would kill the deal, as I happen to have access to some matching front tires as well...
#1051596 - 06/19/17 08:42 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I tried the cheap wheel game 2 months ago. I couldn't make it work. I got a lot of advice here, I browsed a couple thousand craigslist posts. I found about a dozen wheels that might work. Prices, distances, quality all made me say no.
There are tons of nice rims on CL, but 95% of them are modern rims that mount on the outer edge while ours are mounted in the center. So of that 5% you have an even smaller set that are compatible with our cars.
I felt even less good about finding a compatible set from the junk yard.
I don't think I saw a single set of compatible wheels with decent rubber on them.
Justin
1986 Black SS
#1051597 - 06/19/17 08:52 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
I'm fine with buying a set of tires to go on the junk rims, because then I can swap them over to the nicer ones at a later date. I just can't get them all in one fell swoop with the funds available right now.
Hmm, that would be a heck of a deal, and I'd be fine with those rims for quite a while... FYI for those who don't want to click the link, here's the text. It's a bit of a drive from here though, so I'd have to factor in another hundred for gas nearly.
Eagle alloy 17x8 wheels with like new tires, less than 100 miles on the set
Front- Nitto 555, 245/45/17
Rear - Mickey thompson drag radial, 275/40/17
I won't separate, local pick up only Montgomery Texas area
Message here or text xxxxxxx
$900 obro
#1051599 - 06/19/17 08:59 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
Summit has a selection of 17x8, 4 3/4 on 5 wheels starting at under $100.
https://www.summitracing.com/nv/search/part-type/wheels/wheel-material/steel?sortby=Default&sortorder=Ascending&N=4294920860%2B4294920856%2B4294920356%2B4294947557
#1051602 - 06/19/17 10:53 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
Bloomsdale, MO
Crager Soft 8's? Those are about the cheapest 17 inch aftermarket wheel I know of that is readily available and will bolt on.
#1051623 - 06/20/17 07:18 PM Re: Junkyard 17" rim options? [Re: Hunter79764]
thepezking639 Offline
Livonia, MI
86 SS 6.0L LQ4, TBSS GEN IV intake, 92mm TB, 30lb injectors, LS3 cam and valvesprings, stainless long tube headers, Microsquirt ECU, Built 200-4R, B&M Megashifter, Torsen LSD, QA1 Lvl 3 Suspension Kit, UMI Front & Rear Braces. Check out my build thread: http://www.pro-touring.com/threads/126188-SSLOW6-0-Build
#1051633 - 06/21/17 12:16 AM Re: Junkyard 17" rim options? [Re: Hunter79764]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
cheap is kind of relative =p
Justin
1986 Black SS
500/thumbs/Redo_84Monte.jpg
by 84sfast
560/thumbs/IMG_4430.jpg
by STREET FIGHTER
500/thumbs/p8210021.jpg
by zombiedeth
by Intmdatr3
by Martinez
