#1051552 - 06/17/17 11:30 PM Weird Electrical Issues
Alonzo Offline
Alonzo  Offline
Oakland,CA
Hi! I been having some weird electrical issues lately. The first being that my left turn signal doesn't flash in and outside of the car when my lights are on but manages to stay completely lit up in the cluster and works just fine when the lights are off but yet my right turn signal is completely functional. The second is that my high beams do not work at all, I replaced the bulbs and when I use my turn signal lever to engage the high beams they do not turn on but then again my wipers do not start when I use the lever. Any tips on how to get to the wiring of the lever and fix it? If the wipers still do not work after I fix the wiring on the lever, what would be cause of its failure? Finally my third and final issue is that my tachometer is reading completely wrong and the speedometer is jumping constantly and fails to accurately read my speed. Thank you in advance I appreciate all your help guys!!
#1051553 - 06/17/17 11:42 PM Re: Weird Electrical Issues [Re: Alonzo]
Alonzo Offline
Alonzo  Offline
Oakland,CA
Also my cluster lights do not work at all but I think this is just simply bulbs.
#1051555 - 06/18/17 01:47 AM Re: Weird Electrical Issues [Re: Alonzo]
86ttop Online grandpa
86ttop  Online Grandpa
some of your light problems are most likely tied to poor grounds, the dash lights may simply be bulbs, good luck!!
#1051557 - 06/18/17 04:41 AM Re: Weird Electrical Issues [Re: 86ttop]
Alonzo Offline
Alonzo  Offline
Oakland,CA
The grounds that are connected to the looms of the headlights? I checked those and they are fine
#1051565 - 06/18/17 05:51 PM Re: Weird Electrical Issues [Re: Alonzo]
You might want to invest in this manual. It will explain exactly how to chase down your electrical problems, step by step. It also has very clear wiring diagrams, I wore my manual out during my LS swap. Could be the best $8 you ever spent.
And welcome to the forum, I grew up in Oakland, Skyline High School, class of 1972.
http://www.ebay.com/itm/1988-GM-Chevy-Monte-Carlo-Caprice-Electrical-Diagnosis-Supplement-Manual-OEM-/352086140396?hash=item51f9f825ec:g:J1UAAOSwajVUOZV-&vxp=mtr
#1051571 - 06/19/17 12:01 AM Re: Weird Electrical Issues [Re: Alonzo]
ChasUno Offline
ChasUno  Offline
Bradenton, FL
Lights - almost certainly an earth issue by what you describe.
Wipers - possible switch, motor failure or another possible bad earth (time to get that multimeter out!)
Tachometer - A known issue where part of the diode pack fails with age and the tacho become more and more inaccurate, to the point where they stop working or peg out. This thread shows you how to fix it:
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=1051121#Post1051121
Speedo - it's mechanical, so either a dry/ worn cable, or the speedo head itself is faulty. Likely the cable.
As upflying says above, grab the electrical supplement manual. It's worth its weight in gold.
1986 Monte Carlo SS
#1051753 - 06/24/17 02:17 PM Re: Weird Electrical Issues [Re: Alonzo]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
Alonzo, did you get your issues resolved you described in the first 2 posts above?
#1051763 - 06/24/17 07:50 PM Re: Weird Electrical Issues [Re: Ole Blue]
Alonzo Offline
Alonzo  Offline
Oakland,CA
Time has been slim lately since I work full time and am a full time student but it's coming along little by little, thank you for asking! Another thank you to the people who have replied, it's been a tremendous amount of help!
#1051784 - 06/25/17 11:24 PM Re: Weird Electrical Issues [Re: Alonzo]
Ole Blue Offline
Ole Blue  Offline
Lugoff, SC
Sounds busy!
I was asking in case you were stumped on any of the electrical and was still needing help/advice. If you do, I was willing to offer some input for you. I fought a few myself to keep mine running through the years.
Let us know how you make out or if you need any more help.
500/thumbs/Redo_84Monte.jpg
by 84sfast
560/thumbs/IMG_4430.jpg
by STREET FIGHTER
500/thumbs/p8210021.jpg
by zombiedeth
by Intmdatr3
by Martinez
