#1050196 - 04/21/17 12:27 PM Hydraboost brakes
pearl83SS Offline
pearl83SS  Offline
Chicago
A while ago I swapped my vacuum assisted brakes for a hydroboost setup out of a turbo Regal. They are all Factory parts so it bolted right up. However ever since then my pedal has been extremely mushy and my brakes inconsistent. I tried bleeding the calipers again and I got a few bubbles out of them, but I am wondering if the master cylinder was not bled properly? Is there a chance that air is trapped in there? I bench bled the master cylinder with the bleeder kit and thought I got it all, but maybe is it possible that my plunger isn't going the full stroke of the master cylinder?
#1050203 - 04/21/17 03:35 PM Re: Hydraboost brakes [Re: pearl83SS]
Always possible it didn't bleed the whole way. I'd give it another shot when you can...
#1050204 - 04/21/17 03:37 PM Re: Hydraboost brakes [Re: pearl83SS]
84ss355*4spd Offline
Edmonton,AB,Canada
Air for sure.when u bled it on the bench it should be barelt moving when bled because will have pressure. Plunger maybe move an 1/8 . Or u have a eheel cylinder seepin in the drum and making it go spongy if rest checks out
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
500/thumbs/monte58.jpg
by juan r
by BOHNZ
500/thumbs/Full_Motor.jpg
by 468beast
by Big Reazon
by TestMySS87
Rob Forbes
