#1050031 - 04/17/17 12:13 AM VSS info for Ls Swap
benen Offline
benen  Offline
Fort Wayne, IN
I posted a question in the quick chat box to the left from a computer but I cannot seem to access that same quick chat box from my phone and I will not be around a computer for some time now.
My question is if I still need my factory VSS system for a LS swap? I'm swapping in a 4.8/4l60e. the reason why i'm asking is because i'm a noob at this and I cannot for the life of me get the VSS part that connects to the rear of the transmission off
#1050039 - 04/17/17 02:12 AM Re: VSS info for Ls Swap [Re: benen]
86ttop Online grandpa
86ttop  Online Grandpa
can you post a picture of what you are trying to remove??
#1050041 - 04/17/17 02:14 AM Re: VSS info for Ls Swap [Re: benen]
WV Hillbilly Offline
Tornado, WV
I've seen you asked this question on facebook, gbody forum & now here......the vss on your monte is located at the speedometer, what you think is the vss is actually a speedometer gear (inside the transmission), the 4l60e will not directly drive your stock speedometer, you will either need a speedometer convertor box (Dakota Digital or Cable X) or an electronic speedometer
1987 Monte Carlo SS, LT1/T56 & 8.5 rear w/3.73 posi
http://www.cardomain.com/ride/3898808
#1050045 - 04/17/17 02:46 AM Re: VSS info for Ls Swap [Re: WV Hillbilly]
benen Offline
benen  Offline
Fort Wayne, IN
yes! I wanna make sure I understand something 100% and get the most replies I can get before I really screw something up lol. I researched this a little deeper after posting this and I think I understand it now. I think I will go with the electronic speedo. thanks for the replies
#1050051 - 04/17/17 05:03 AM Re: VSS info for Ls Swap [Re: benen]
What WV Hillbilly said, that is just the speedo driven gear and speedo cable. Some PB Blaster could help to remove that is in your picture, good luck!
#1050109 - 04/18/17 01:52 PM Re: VSS info for Ls Swap [Re: benen]
Just in case, since you said "Plugs" into the transmission, the ribbed ring unscrews the normal way from the transmission housing, you can try a pair of good condition Channel-Lock pliers LIGHTLY gripping it to loosen it. Don't mangle it. the cable sticking out doesn't rotate, once the ring is loose it will slide straight out.
Leo's right as well, PB Blaster or your favorite similar product can help.
#1050113 - 04/18/17 02:25 PM Re: VSS info for Ls Swap [Re: benen]
MCSASK88 Offline
MCSASK88  Offline
Saskatchewan
Save yourself some real headaches especially if you new to the LS swap community, and get the Dakota digital dash with the expansion module OBD-II / CAN Interface that connects directly into the obdii port for exact readings it's the best thing I've ever bought for my ls swap
1988 Monte Carlo SS LS2, Hooker Blackheart 3“ Exhaust, 4l60e transmission, 8.5' 3.42 Grand National rear end
500/thumbs/monte58.jpg
by juan r
by BOHNZ
500/thumbs/Full_Motor.jpg
by 468beast
by Big Reazon
by TestMySS87
Rob Forbes
