Page 3 of 3 1 2 3
#1049913 - 04/13/17 05:22 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Thanks!
I hear that little squeak too. It was worse when the alternator was crooked and I think it still was in that video. Belts are old and probably on there too tight to prevent slipping. No clue when they've been changed, but no signs of cracking. They are on the list.
This year's budget is running on fumes after that wheel purchase.
I would like to replace the floor pans and I'm starting to think it would be the way to go. Going to attempt the scrape and patch this year. If it comes back to haunt me, they will be part of a future budget. If I do it I'm going full floor replacement. My inner rockers are rough. When I reach up there i feel peeling paint. I'm potentially getting a free full sized lift in the next month so I've stalled my cleanup of the underside until then. That will be much easier if I'm on my feet and not my back. Still going to patch it now.
No matter what I do, I don't intend to drive the car in the rain and it is always in a garage. That should buy me a bit of time no matter how I clean it up.
Fan system cost me about $45. $25 for fans at the u-pull and $20 for the wiring kit
Justin
1986 Black SS
#1049966 - 04/15/17 12:55 AM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Pro Tip: welding can start a fire
Almost lost the monte today. Was welding in the plate over the hole and didn't notice the smoke through the welding mask. I set the insulation on the firewall on fire.
A scary 5 minutes of stamping it out with welding gloves while smoke poured out of the dash.
Now I'm afraid to do the passenger side due to fuel lines.
Justin
1986 Black SS
#1049967 - 04/15/17 01:08 AM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I hammered the floor as flat as possible by jacking my sledgehammer up to the floor and then hammering it flat with my regular hammer.
I ground down all the edges and stripped off the paint.
Cut the patch to match and drilled several holes around the edge to plug weld it.
Cut a few tabs to bend down into the areas that didn't flatten.
Patch and welds work pretty good. Forgot to take a pic of it with epoxy paint. much cleaner with paint.
Ran out of epoxy paint so I have to wait to hit it with some sealant goop.
I know what floor worms means now. I'm spotting little holes here and there like i had worms eating the metal.
I took the kids out in her tonight. My son was screaming "I don't want to die!" while I never took it over 45.
Highest praise I've ever had for my car =)
Justin
1986 Black SS
#1049977 - 04/15/17 03:34 AM Re: Witness Me! [Re: Witness86SS]
84ss355*4spd Offline
Edmonton,AB,Canada
I used a steering shaft from a older cherokee in my 84 and it bolted right in . Similar lookin shaft though. Makes the cars steering feel much nicer
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1050060 - 04/17/17 02:09 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
The patch with paint
Justin
1986 Black SS
#1050092 - 04/18/17 01:21 AM Re: Witness Me! [Re: Witness86SS]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Keep up the good work. Bonus points for the son's comments on the Monte
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1051022 - 05/22/17 08:08 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I finally figured out how the gauge cluster comes apart. I got the speedo out and Swapped in 10 LED lights. They were the $10 ten pack from amazon linked on some thread here about LED's. I'm happy with the results. It's a nice pale white illumination of the gauge cluster. It's kind of ghostly.
Got the voltage meter working again. Got the tach to show signs of life but it is way off. I don't think i'm shifting at 8k
I used about half a can of contact cleaner on the whole deal and scraped the contacts on the stubborn lights.
This is one of those, have to do it 4 times to get it right kind of jobs. Every time i put it back together i realized i goofed something up. forgot the turn signal green piece, take it apart again. forgot to test the turn signals, take it apart again. Tach stops reading, take it apart again.
Somehow I managed to only break 1 clip and a light socket this time. I'll have to do without the seatbelt warning. The whole assembly, every part of it is very brittle.
Temp and oil pressure sensors are still dead. I'm going to have to test those connections with a meter.
Justin
1986 Black SS
#1051122 - 05/26/17 09:54 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I've been going back and forth on how I want to make this car look and I think I'm going with the 80's.
Was a debate between that and mad max style(I have the rust for it)
Swapped out the white lights for purple/pink
Redid my tach by following the guide on here. I also removed the contacts from the tach and gave the board and the contacts a little sandpaper.
Tach is working great now.
Only need to fix or replace the temp and oil sensors now.
Looks like i shift at around 1800 RPM at light throttle, 3000 RPM's at 50% throttle. Car idles at 1000 on cold start. Slap pedal and it drops to 600. After a couple minutes car idles at 520 in drive at a stop.
Justin
1986 Black SS
#1051166 - 05/30/17 10:29 PM Re: Witness Me! [Re: Witness86SS]
TooSlow406 Offline
TooSlow406  Offline
Friendswood, TX
thats why i prefer my fans on a switch. No drain on the battery except when *I* want it. can make the car hard to start if its already hot. and you dont really need them when you're at speed.
#1051426 - 06/12/17 02:23 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I'm going to need a switch for that at some point.
I got the floors finished this weekend
I patched up the tiny holes with JB weld
Justin
1986 Black SS
#1051819 - 06/26/17 04:05 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I did some rust removal around the windshield. This was the last part of the body that wasn't cleaned up.
Crack in the pillar
Time for a new ceiling. Tired of it looking like the car is haunted
Scrapped the foam off by attaching my wire wheel to my vice grips. It took about an hour to fully scrape it.
Pretty sure this is the second time this has been done to this car. Shell had some cracks held together with tape
Taking the passenger seat out made it pretty easy to get the shell out
I was able to smooth out the back after this pic
Still need to replace or remake visors
big mess
Justin
1986 Black SS
#1051823 - 06/26/17 11:33 PM Re: Witness Me! [Re: Witness86SS]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Nice work, the headliner looks great! I'm sitting here trying to figure out my next move and you just made up my mind. How hard was it to remove the trim around the headliner?
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1051826 - 06/27/17 02:44 AM Re: Witness Me! [Re: WB of NOLA]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Thanks!
The pillars come out easy, then the front trim should slide out of place. Mine could be broken and you may need to pop yours
Then I undid the visors.
The trim above the door pops out. You just have to kind of twist it the right way and it pops. I'd research a good way.
Remove passenger seat.
Under the trim at the door is 3 clips, unscrew them.
Next remove the back window trim, 2 screws.
Then the 2 hanger hooks.
Then pop the dome light cover, use a blade to get under the 2 "snapper" things on the posts. Not sure what they are really called. They don't unscrew, they pop on and off.
Cut the wire and tape it.
Remove Body by fisher rails along door.
Remove the trim on the back edge of the door jamb.
I think the ceiling is free at this point except for the big plastic pieces in the back seat.
I got in the back seat and inched my shell out one inch at a time. You can slide it past the rear trim and up onto the dash. Shimmy it side to side.
now you slip out the passenger side and swing the shell out.
Honestly, the hardest part was getting the visors back in. The screw pattern is a PITA to guess right through the fabric. Remove the visor from the mount. Makes it so much easier. Take a photo of the angle they mount at(i didnt).
I did not wrap my fabric around the shell like others show to do. I cut it along the edge. the trim gives great overlap. It would not shimmy back into place otherwise.
You will need exactly 1 large can from joanne fabric. I used a little bit of it for something a few weeks ago and came up a little light on the second surface. Can't go wrong with 2 cans.
don't let them fold your fabric at the store. Roll it back up. I had wrinkles
Justin
1986 Black SS
#1051827 - 06/27/17 02:49 AM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
It smoothed out pretty good today
Justin
1986 Black SS
#1051940 - 07/01/17 07:42 PM Re: Witness Me! [Re: Witness86SS]
Edmonton,AB,Canada
Good job . I haave to do the same on the 85. Its haunted as well lol
86 ss gone
85 ss new
85 z28 tpi
#1052088 - 07/08/17 01:01 AM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Thanks!
Just got my first trophy =)
Kind of a participation trophy due to the weather, but hey I'm going to ride this high.
Justin
1986 Black SS
#1052964 - 08/16/17 06:39 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Monte got real wet in the rain yesterday for the first time.
Now today the electric fans aren't kicking on at the right temp.
Exhaust sounds like something is opened up.
Fuel line is leaking at the fuel filter.
ignition cylinder isn't releasing the key or the shifter unless i position it just right
All this happens in one day =[
And my van is grounded. Leaf spring shackle broke and part doesn't come in until monday
Not a good week.
Justin
1986 Black SS
#1055468 - 01/22/18 03:16 PM Re: Witness Me! [Re: Witness86SS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Chased down my electrical gremlins yesterday. I cleaned up the connection for the main ground cable last week. It was on painted metal. Patched an exposed wire that was grounding on the trunk hinge. Took my relay trigger wire off of the distributer and hooked that to the electric choke. Really wish I heeded that advice sooner. Just kind of assumed it only needed the tiniest bit of current to trip that relay. Seems like it was sending a lot to it.
I was able to start the car without using the gas pedal for the first time. I didn't really gain any performance but it just feels so much smoother. Best way to describe it is the car used to rumble and now it purrs when I press that pedal
Justin
1986 Black SS
#1055822 - 02/11/18 02:46 PM Re: Witness Me! [Re: Witness86SS]
Edmonton,AB,Canada
Cool good job finding those pesky gremlins .
86 ss gone
85 ss new
85 z28 tpi
Page 3 of 3 1 2 3
500/thumbs/Redo_84Monte.jpg
by 84sfast
560/thumbs/IMG_4430.jpg
by STREET FIGHTER
500/thumbs/p8210021.jpg
by zombiedeth
by Intmdatr3
by Martinez
