#1049436 - 03/31/17 05:50 PM 84 Monte Carlo SS with 350 set up and hose routing
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
Hey guys, I just purchased this 1984 Monte Carlo SS with a 350 engine headers, I think Edelbrock manifold holly carburetor. I'm not sure if all these hoses and connections are correct is there a diagram or somebody that could help me with making sure all the Vacuum hoses etc. I set up correctly?[b][/b]
#1049437 - 03/31/17 05:57 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
#1049445 - 03/31/17 09:31 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: upflying]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
I WILL.
I can't figure out how to post a pic on here. I do not have a foto bucket or any of that stuff. But yes. The 84 Monte ss . 350 was installed. No more AC etc. Air pumps etc. Holley carb. Intake. I will see what I can do.
#1049452 - 04/01/17 12:49 AM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: upflying]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
<a href="http://s1126.photobucket.com/user/GBODPICS/media/16939234_10154063236221642_4615378538672679921_n_zpssh7frdei.jpg.html" target="_blank"><img src="http://i1126.photobucket.com/albums/l620/GBODPICS/16939234_10154063236221642_4615378538672679921_n_zpssh7frdei.jpg" border="0" alt=" photo 16939234_10154063236221642_4615378538672679921_n_zpssh7frdei.jpg"/></a>
#1049455 - 04/01/17 01:31 AM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Code
[img]http://i1126.photobucket.com/albums/l620/GBODPICS/16939234_10154063236221642_4615378538672679921_n_zpssh7frdei.jpg[/img]
Justin
1986 Black SS
#1049457 - 04/01/17 03:06 AM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
Congratulations! That's a clean engine!
The only thing i can see from the picture, is the vacuum line to the heater diafragm
may be missing (?), which could leave a vacuum leak in the hard line coming from the HVAC AC/heater controls in the dash.
#1049463 - 04/01/17 11:38 AM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: 84 ZZ4]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
Thanks. It looks better in pics. I think the chrome timing cover is leaking. I just got this car. I have has 6 SS's. First Blue.
First one with 350. I will take better pics without aircleaner. I think that is not the only issue.
#1049465 - 04/01/17 11:42 AM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049467 - 04/01/17 12:33 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: Witness86SS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049468 - 04/01/17 12:35 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: Witness86SS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
This site could be a lot easier! What is that link you sent? I copied and pasted it to google.
#1049469 - 04/01/17 12:35 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049476 - 04/01/17 03:13 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
#1049482 - 04/01/17 06:12 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
When the weather clears up I will take better pics. I know the Dist is not stock. It does not look it.
#1049521 - 04/02/17 11:47 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049522 - 04/02/17 11:48 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049523 - 04/02/17 11:50 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1049524 - 04/02/17 11:52 PM Re: 84 Monte Carlo SS with 350 set up and hose routing [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
I did a little clean up today. So these pics should show a couple issues.
That actuator. I do not know why it's there. The hose is going to intake like it should but what does that other part of the actuator do? Do I even need it?
That little white hard line comes out over near where AC condenser is. No more AC... Goes to? The black canister is broken and will buy a new one.
500/thumbs/thmb_mikesss.jpg
by BadAssSS
500/thumbs/ssdec93.jpg
506/thumbs/100_0566.JPG
by 85_SS
500/thumbs/IMG9540491967528704.jpg
by Louhenry
500/thumbs/Gauge_Pod.jpg
by QuikZilver
