#1048228 - 02/16/17 02:00 AM Door won't close (latch stuck close)
dmeow Offline
dmeow  Offline
Honolulu, HI
My driver door won't close, where the door is supposed to close seems rotated, blocking the door from closing... pics here https://goo.gl/photos/tGgu4mEfzZQxM8wV9
Is it the cable that needs to be replaced?
#1048229 - 02/16/17 02:12 AM Re: Door won't close (latch stuck close) [Re: dmeow]
If you hold the door handle in the up position while you rotate the door latch hook upward this should unlatch the door mech. The latching mech may be worn out, broke, but this should allow you to close the door if the latch remains in the open position after rotating the latch.
#1048233 - 02/16/17 04:36 AM Re: Door won't close (latch stuck close) [Re: dmeow]
dmeow Offline
dmeow  Offline
Honolulu, HI
Cool, Will try this tomorrow, thank you!
#1048267 - 02/17/17 08:41 AM Re: Door won't close (latch stuck close) [Re: dmeow]
dmeow Offline
dmeow  Offline
Honolulu, HI
Sadly it didn't work. This mean s I'll have to replace the latch mechanism? (is this what it is called?)
#1048279 - 02/17/17 02:54 PM Re: Door won't close (latch stuck close) [Re: dmeow]
DiamondSnake Offline
Québec, QC
That used to happen on my brother's Jeep. Did you try prying it with a screwdriver?
#1048289 - 02/17/17 10:50 PM Re: Door won't close (latch stuck close) [Re: dmeow]
dmeow Offline
dmeow  Offline
Honolulu, HI
Yeah I did, with the handle up as well. The thing won't budge an inch, seems like it somehow rotated inward and is stuck there.
#1048295 - 02/18/17 12:57 AM Re: Door won't close (latch stuck close) [Re: dmeow]
Silly to say but do you have the door lock knob pulled up?
#1049573 - 04/04/17 09:22 AM Re: Door won't close (latch stuck close) [Re: dmeow]
minuteofdecay Offline
Dennison, OH
Lol I had a Monte that always did this but I could rotate it with my fingers.
#1049607 - 04/04/17 11:10 PM Re: Door won't close (latch stuck close) [Re: dmeow]
Sounds like you tried to close the door with the closed latch in place. This shoved and bent the latch into the lock. Try tying a strong wire between the latch and the door striker on the B-pillar. Swing the door open while you hold the door handle up.
When I bought my car, my latch and striker were pretty beat up due to sagging hinges. Check your hinges for sag but lifting the end of the open door.
500/thumbs/P3090603.JPG
by STINGER-427
500/thumbs/PICT0279.JPG
by Hey-O
697/thumbs/PHOT0013.JPG
by MikeySS406
500/thumbs/555.jpg
by steve1984ss
826/thumbs/IMG_1489.JPG
by cj84ss
Rob Forbes
