#1048063 - 02/11/17 10:43 PM Rear ls brake swap
mrmadwrench Offline
mrmadwrench  Offline
aberdeen md
So I'm getting ready for OC cruise week and have hit a bit of a problem maybe you guys can help me with. I'm doing a rear ls brake swap and cant find anyone who just sells the flange spacers. Need to move the bracket out about 1/8 of a inch. Does any one know where I can get these and maybe a part number. Really don't want to just stack washers.
#1048064 - 02/11/17 11:23 PM Re: Rear ls brake swap [Re: mrmadwrench]
#1048065 - 02/11/17 11:23 PM Re: Rear ls brake swap [Re: mrmadwrench]
#1048068 - 02/12/17 12:34 AM Re: Rear ls brake swap [Re: mrmadwrench]
I've been gathering parts for the swap, I assume this spacer is required?
#1048071 - 02/12/17 01:21 AM Re: Rear ls brake swap [Re: mrmadwrench]
mrmadwrench Offline
mrmadwrench  Offline
aberdeen md
Perfect thanks. I guess you really dont need them. But as the pads wear the inside pad might come out of the bracket and create a problem. I just wanted it done right. I've searched and see people using washers or cutting the center out of the old backing plate. I need quite a bit more than the 2/32 or so thickness that that would give.
#1048090 - 02/12/17 03:18 PM Re: Rear ls brake swap [Re: mrmadwrench]
Joe87monteSS Offline
Memphis,TN
I would say that it is required. They center the rotors in the middle of the abutment brackets. I made a pair of spacers out of some thick aluminum bar that I had.
I also adapted my factory Ebrake cables to work with the Camaro hook.
I used this as a guide.
http://www.elcaminocentral.com/showthread.php?t=58834
Joey
Engine/head builder/machinist
2004 Silverado
Facebook
#1048091 - 02/12/17 03:18 PM Re: Rear ls brake swap [Re: mrmadwrench]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
The calipers float, I don't understand what you mean that the inside pad can fall out?? I've been running the ls1 fbody setup for 5yrs with no issue...
2015 GMC Sierra Denali
#1048093 - 02/12/17 05:39 PM Re: Rear ls brake swap [Re: mrmadwrench]
mrmadwrench Offline
mrmadwrench  Offline
aberdeen md
If there is to much clearance between the bracket and rotor as the pad wears out the cllearance becomes to much and the pad backing plate will go past the edge of the bracket. Plus you run the risk of over extending ithe caliper pistons. If you keep good pads and don't let them wear to far you'll probably never have a problem. Hope that makes sense.
#1048094 - 02/12/17 05:42 PM Re: Rear ls brake swap [Re: mrmadwrench]
mrmadwrench Offline
mrmadwrench  Offline
aberdeen md
How many of you guys modified your proportioning valve by removing the the residual piston. Or are you just running a adjustable valve? 1LE valve ? What seems to work best?
#1048105 - 02/12/17 10:35 PM Re: Rear ls brake swap [Re: mrmadwrench]
Jameson Offline
Jameson  Offline
Elizabeth City, NC
My abutment bracket was centered over my rotor when I did my swap. Didn't need to shim. And I'm running a disc/disc combination valve from Speedway Motors.
#1048111 - 02/13/17 12:36 AM Re: Rear ls brake swap [Re: Jameson]
yours was centered just bolting the ls1 backing plate to the axle?
#1048115 - 02/13/17 01:33 AM Re: Rear ls brake swap [Re: mrmadwrench]
mrmadwrench Offline
mrmadwrench  Offline
aberdeen md
Did you use a bracket or using the camaro e brake backing plate? Maybe that's the difference.
#1048124 - 02/13/17 04:35 AM Re: Rear ls brake swap [Re: mrmadwrench]
RenoReno2 Offline
RenoReno2  Offline
Chicago, IL
I did a trace of the bracket and had a friend use the trace to laser cut shims. They own a sheet metal and fabricating shop so it wasnt a big deal
88 Monte SS
500/thumbs/signature71.jpg
by toddztoyz
500/thumbs/Monte_overlooking_river.JPG
by Ricks88SS
560/thumbs/MM_05_23.jpg
by NYmonteSS
500/thumbs/DSC_0014.JPG
by wanadrv
1188/thumbs/4_-_Copy.jpg
by mclellan83
