#1047345 - 01/20/17 02:40 AM 2004 5.3/4l60e Dbw cam swap
1988SilverBulletMCSS Offline
Daytona Beach, FL
I wanted to know what will be a good cam to install in my dd mc. I have a bone stock 5.3 and just want a cam swap...
#1047358 - 01/20/17 04:23 PM Re: 2004 5.3/4l60e Dbw cam swap [Re: 1988SilverBulletMCSS]
The LS6 cam is a popular upgrade, along with decent intake and exhaust should run pretty strong with good idle and vacuum. Above that, you start to make tradeoffs for a DD, and only you can decide how much trade to make. Lowest cost options will be stock takeoffs, of course the aftrermarket is wide open, but here's a good writeup on some of the different ones available.
http://www.hotrod.com/articles/ls-cam-test-comparison/
#1047363 - 01/20/17 08:27 PM Re: 2004 5.3/4l60e Dbw cam swap [Re: 1988SilverBulletMCSS]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
LS9 Cam or GMPP Hot Cam would also be a good choice for the 5.3. Remember you will also need the appropriate springs with whatever cam you choose
#1047640 - 01/30/17 02:56 AM Re: 2004 5.3/4l60e Dbw cam swap [Re: 1988SilverBulletMCSS]
Daytona Beach, FL
#1047648 - 01/30/17 03:16 PM Re: 2004 5.3/4l60e Dbw cam swap [Re: 1988SilverBulletMCSS]
You'll lose some torque down low, based on the Hot Rod article, I'd guess 45+ ft lbs at 2500, but will gain quite a bit up top. I'd guess a good tune would be pretty close to mandatory though. You would likely need to pay attention to your converter choice, it might be critical too. Basically, it's a relatively big cam, so the typical big cam advice applies.
1139/thumbs/photo_1.JPG
by O.G.
875/thumbs/ss_delete_it_i_dare_you.jpg
by BADRACR1
500/thumbs/image32.jpg
by Blown Monte
500/thumbs/P1010096-small.JPG
by ProTourAero
500/thumbs/monte_carlo_ss1.jpg
by shockerman80
