Page 4 of 4 1 2 3 4
#1046868 - 01/05/17 08:39 PM Re: Supercharger install complete [Re: Tunedss86]
Monte_ExpreSS Offline
Oshawa, Ont. Canada
Originally Posted By: Tunedss86
Sorry I didn't read every post, wondering if its been dyno-ed yet?
We did dyno it if you go back to page 2. Made 617rwhp but we maxed out the injectors. I have since picked up a set of ID850 injectors and built a new air intake. However due to the weather,I probably wont be able to get it back in for the final tune until the spring
#1046870 - 01/05/17 08:51 PM Re: Supercharger install complete [Re: Tunedss86]
Oshawa, Ont. Canada
Is the fluid reservoir for the SC the stock Monte coolant overflow tank? Where did you get fittings for it?
It is a Monte coolant overflow mounted 90*. The fittings are 3/4" barbs from a fish tank lol! A little backyard ingenuity
I was trying to keep it as OEM looking as possible
#1046872 - 01/05/17 08:58 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I thought maybe that's what you used. Good idea.
I have one to put on my LS2 also, someday. I put LS3 heads on it though, so no need for adapters, & I have the CTSV lid. I'll prob need to change cams, mine is like .611/.610 lift, 230/236, 114 (I think, I'll have to find card). I have the holley bracket with the SD5 or SD7 AC compressor. I guess I will have to change all that.
#1046873 - 01/05/17 09:01 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Oshawa, Ont. Canada
LSX Concepts makes another spring loaded tensioner kit. Originally I was looking to use that but due to a lack of belt length selection for the application, There was nothing that would work with the extra 1/2" height from the adapters. You may be able to get that tensioner to work with your current a/c bracket being youre not using port adapters
#1046874 - 01/05/17 09:07 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
I had already went that route. Their stuff won't work with the Holley bracket.
#1046875 - 01/05/17 09:10 PM Re: Supercharger install complete [Re: Tunedss86]
Oshawa, Ont. Canada
Darn, looks like youll have to grab their ac bracket as well
#1046876 - 01/05/17 09:14 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
And a new AC compressor. I have the small one, the SD7, and they dont have a mount for it. Like this:
#1046877 - 01/05/17 09:18 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
My other thought is to push the Vette bracket out to the truck spacing using the Holley spacers & come up with a way to mount it all on one belt like:
#1046878 - 01/05/17 09:26 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Great job on this build.
#1046879 - 01/05/17 09:34 PM Re: Supercharger install complete [Re: Tunedss86]
Oshawa, Ont. Canada
Im sure you could resell your current ac stuff to recoupe some funds for the new setup.
Ive seen the truck spaced setup, its nice but $$ for the one in the pic. I like the LSX concepts stuff because it has good belt wrap and you dont have as much pontential for slip.
Thanks!!
#1046881 - 01/05/17 09:54 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Yep, Concept One stuff is expensive. Maybe I can do it with parts I have & some modifications.
#1046884 - 01/05/17 11:33 PM Re: Supercharger install complete [Re: Tunedss86]
mondotti Offline
mondotti  Offline
Plainfield,IL.
I really liked the finished professional look and researched Concept One 1st.
2 things that were deal breakers for me.
1. All in one drive system limits boost capability. They advertise no more than 10 PSI..
2. Power steering pulley sticks too far out and would hit my gear box.
Regards,
1986 Maroon SS Notchback, Stage LS9 Hyperspace Chip with G&M 4L65E Shift Kit
#1047287 - 01/18/17 05:23 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
So doing some research last night, I found that Holley now has a lower pass side mount for the Sanden S7 compressor. I may try that & use the OEM drive for the SC.
What isolator did you use?
#1047298 - 01/18/17 09:53 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
Oshawa, Ont. Canada
Is that going to clear the frame?
#1047315 - 01/19/17 03:18 AM Re: Supercharger install complete [Re: Monte_ExpreSS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Not sure.
#1047325 - 01/19/17 02:47 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
steve40 Offline
steve40  Offline
Windsor, Ontario
where did you find out that info?
#1047326 - 01/19/17 02:54 PM Re: Supercharger install complete [Re: steve40]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
https://holley.com/products/accessories/drive_brackets/brackets_only/parts/20-159
#1047327 - 01/19/17 03:10 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
steve40 Offline
steve40  Offline
Windsor, Ontario
thanks
#1047962 - 02/09/17 04:54 AM Re: Supercharger install complete [Re: Monte_ExpreSS]
guitars Offline
guitars  Offline
Toronto, Canada
Hey J', are you showing your car at the Speed and Custom(?) Show at the International Center in March?
#1047992 - 02/10/17 01:57 AM Re: Supercharger install complete [Re: guitars]
Oshawa, Ont. Canada
No, I dont have any plans to attend that. TBH, I dont go to too many shows. Ill hit a local cruise night from time to time, but mostly just drive the car when I have the opportunity
#1049951 - 04/14/17 07:15 PM Re: Supercharger install complete [Re: Tunedss86]
WFO_SS Offline
WFO_SS  Offline
dallas, tx
IMHO, i would not even consider this, especially on a belt driven supercharger. look at how much wrap you have on the crank pulley with that setup....about 90 degrees. that belt is going to slip just on regular accessories. it's going to be a huge problem once the blower starts loading it up.
completely stock except for engine, tranny, exhaust & rearend.
#1049954 - 04/14/17 07:19 PM Re: Supercharger install complete [Re: Tunedss86]
WFO_SS Offline
WFO_SS  Offline
dallas, tx
Not sure.
supposedly, it only clears the g-body frame at the truck/ls3 accessory spacing and (maybe?....can't remember) the middle spacing (ls1 f-body, gto.)
i'll let you guys know. already installed the brackets & tensioner. compressor should be here monday.
#1051169 - 05/31/17 02:23 AM Re: Supercharger install complete [Re: Monte_ExpreSS]
305hoSS Offline
305hoSS  Offline
Millstone, NJ
Monte_Express nice way to fill your engine bay!!I wanted to send you a pm but you are over your limit.
87 ss- Almost sold my SS then changed my mind...Now working on an LS swap
#1051174 - 05/31/17 01:52 PM Re: Supercharger install complete [Re: WFO_SS]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
WFO_SS, did you buy this Holley AC bracket? How does it fit?
#1051235 - 06/04/17 03:21 PM Re: Supercharger install complete [Re: Monte_ExpreSS]
jmireles Offline
jmireles  Offline
El Paso, Tx
I'm really late on seeing this thread....great job!! I also want to thank you for your help in making my LS2 swap work.
in '08. 3K
Page 4 of 4 1 2 3 4
500/thumbs/motor4.jpg
by Big Hitter
950/thumbs/20459_331257609828_744889828_5009489_3076656_n.jpg
by 1bad84mc
1129/thumbs/photo8.JPG
by GBODY88
500/thumbs/engine21.JPG
by Ted88SS
981/thumbs/IMG_2025.JPG
by Robs86MCLS
