#1040447 - 06/20/16 12:26 AM GBODY steering shaft upgrade question.
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1040450 - 06/20/16 01:12 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
MoreHPplease Offline
New Jersey
It's no big deal.
Rob
#1040451 - 06/20/16 01:30 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
#1040469 - 06/20/16 12:52 PM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
#1040514 - 06/21/16 01:09 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1040522 - 06/21/16 01:54 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
#1040585 - 06/22/16 04:59 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
Fred SS Online content
Fred SS  Online Content
Glassboro, NJ
#1040737 - 06/25/16 12:40 AM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
#1040797 - 06/26/16 01:00 PM Re: GBODY steering shaft upgrade question. [Re: WESTWOODSS]
WESTWOODSS Offline
WESTWOODSS  Offline
WESTWOOD MA
Installed.
Huge improvement!
500/thumbs/sp51.jpg
by RocknSS
500/thumbs/brokentranny2.jpg
by johnz138
500/thumbs/IMG_5708.jpg
by T-TopGene
989/thumbs/my_monte_21.jpg
by 85montanezcarloss
506/thumbs/100_0805.JPG
by 85_SS
